Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > 350Z Tech Area > Audio & Video > Audio Builds
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 01-15-2009, 11:55 AM   #1
mthoodrocker
mthoodrocker's Avatar
Points: 1,905, Level: 26
Points: 1,905, Level: 26 Points: 1,905, Level: 26 Points: 1,905, Level: 26
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
Default My Audio build. Tips, Tricks & info.
This was done on my 2007 Enthusiast (non Bose) model.
With that said being I'm somewhat of a newbie so I did months of research on this forum before I started my project to get & gather the most info I could to make informed decisions on which route I wanted to take as well as how to remove panels, etc. & I must say doing my homework has paid off in spades.
I wanted to do this write up for other guys who want to swap out their stock system but may feel intimidated or feel overwhelmed by the scope of the project. Fear not, it's easier than it appears & if you take a systematic approach you'll knock it out in no time at all.
Also just wanted to share things I've learned, & things to avoid to make your build even smoother & as pain free as possible.
Ok so first things first. Do change all four speakers. The difference is so stark I cannot even begin to describe it in words. Even if your not an audiophile removing those stock speakers is an absolute must. You'll be amazed at the transformation.
After hours of research I chose Infinity 6022SI shallow mount speakers for the front & back for a number of reasons. 1. Frugality. $57.00 a pair. Bought at Pro Audio Electronic which is an Ebay store. Price included shipping. Their $99 at Best Buy. 2. Sound quality. They sound awesome. 3. Fit the "Z" like they were made just for her. Are there better sounding speakers besides these? I'm sure there are but bang for the buck these will not disappoint you.
So far I've only spent $114.00 for the four speakers & $20 for Dynamat sound deadening material which you can buy at any Circuit city, Best Buy, etc. (used for the rear speakers)
There are a number of great write ups for the front door panel removal for the driver & Passenger side but the ones for the rear speakers are somewhat vague so here are some tips. You have to be real careful while removing those back corner panels. You can crack them quite easily as that piece is pretty thin & you have to use some force so just take your time. Another fragile piece is the door sills. The integrated fasteners break real easy so be very ginger when you pry it up & off.
Also when replacing the front speakers use the existing speaker as your spacer. Works perfectly with the Infinities. Just cut out the stock speaker & mount your new speaker inside the shell.
Also here is the wiring color codes which you need to know. The two front speakers are the same. Red wire= Negative. Blue wire= Positive. For the right rear Gray wire=Positive. Gray/Red stripe is Negative. For the Left rear Orange/Black stripe= Positive. White/Red stripe= Negative.
Next I'll be replacing the head unit with a Kenwood DPX503 for $234.50 on Ebay. I'll also need a PAC SWI-Jack (steering wheel control) $49 also on Ebay. A Metra dash kit $29.99 at Car Toys. You can get these at any Audio place. A Wiring Harness. Schoshe at Walmart for $7.49. I may also need an antenna adapter. If I do add $10.
Total cost of build not including incidentals is $464.98. Not too shabby for a nice system that allows you to use your steering wheel controls & eliminates the need to carry around a bunch of CD's. This H/U has a USB jack allowing you to just load up a thumb wheel or connect an mp3 player.
So if any of you guys are still on the fence I think it's time to finally pull the trigger. This should be the first mod that you do & as you can see you can do it with out breaking the bank & you get the satisfaction of doing the job yourself & becoming more intimate with how your "Z" is put together.
__________________
2007 Solar Orange Enthusiast Infinity Reference Speakers, Kenwood H/U, K&N drop In's, Acura RDX Antenna, Front LED Reflectors, Nismo Rear Spoiler "better Zed than dead"
mthoodrocker is offline   Reply With Quote
Old 01-15-2009, 09:16 PM   #2
jebz240
Points: 3,098, Level: 34
Points: 3,098, Level: 34 Points: 3,098, Level: 34 Points: 3,098, Level: 34
Today's Activity: 1.1%
Today's Activity: 1.1% Today's Activity: 1.1% Today's Activity: 1.1%
getting ready to redo my mids and highs along with a headunit aswell. Just added a 10" sub and amp to the stock radio when i first got the car.
Thanks for the suggestion on the speakers.. did you keep the stock tweeter working?
jebz240 is online now   Reply With Quote
Old 01-16-2009, 12:32 AM   #3
chopperman
chopperman's Avatar
Points: 5,393, Level: 47
Points: 5,393, Level: 47 Points: 5,393, Level: 47 Points: 5,393, Level: 47
Send a message via AIM to chopperman Send a message via Yahoo to chopperman Send a message via Skype™ to chopperman
Thanks for the write up. This helps ALOT. So do you not need that extra harness to hook up the headunit?
__________________
2003 Lemans Sunset Greddy Twins / Sgp built longblock
chopperman is offline   Reply With Quote
Old 01-16-2009, 09:54 AM   #4
mthoodrocker
Yes I kept the stock tweeters. Yes you need a harness regardless of what brand H/U your installing.
__________________
Old 01-16-2009, 10:15 AM   #5
mthoodrocker
Also a thing to think about is this: A lot of guys like to paint those rear panels. While you have those panels off now would be a good time to send them off to the paint shop. You really don't want to be removing & installing those panels multiple times if you can avoid it.
Also regarding those panels to get to the rear speakers. All you need is a screwdriver to remove the door sills & after that it's all done by hand. No tools required to remove all those panels. Just wear a pair of gloves while removing the panels.
__________________
Old 01-16-2009, 06:15 PM   #6
jebz240
So just to clairify your saying tock tweeters still work with the installed door speakers?... I am thinking about getting these infinities. Just got a alpine x300 baseline ipod mechless player. There releasing a power pack which boost's the RMS up to 45x4 and it plugs into the back of alpine head units thus the reason i bought this ($100 new).
I dont wont to install a second amp for mids and highs when i can plug this in for $130
http://www.crutchfield.com/p_500KTP4...ck.html?tp=115
I just wonder how long the stock tweeters will last when i get this thing if i keep them connected.
Old 01-16-2009, 10:35 PM   #7
mthoodrocker
The stock tweeters are unaffected by a speaker change. A lot of guys change out the tweeters as well.
__________________
Old 01-19-2009, 12:32 PM   #8
jebz240
Hey i just looked at these and have seen some mixed reviews of using a 2ohm speaker with a 4ohm head units internal amp. Apparently it can cause heat issues with your amp by using a different impedance. Any thoughts?
Old 01-19-2009, 12:51 PM   #9
adamtaylorpcb
adamtaylorpcb's Avatar
Points: 1,938, Level: 26
Points: 1,938, Level: 26 Points: 1,938, Level: 26 Points: 1,938, Level: 26
The speakers are designed to be driven with a 2 ohm amplifier or head unit; this will give you improved bass response than a conventional 4 ohm speaker system ; the speakers can also operate at 4 ohms -via infinity specs
__________________
06 MBP 6MT Z, Tourenn, JBL MS-8, F90-BT, H.A.T. L841pro-SE, 2x IDMAX, 2-Q1200.1, 2-Q450.4
adamtaylorpcb is offline   Reply With Quote
Old 01-20-2009, 05:18 AM   #10
jebz240
Yea i saw the infinity specs and there more like 3ohms from what i have read.. seems to be a huge controversy over running 2ohm speakers on 4ohm head units. I have burned 4ohm amps running 2ohm subs in the past.. from heat issues.
Old 01-20-2009, 10:03 AM   #11
mthoodrocker
I'm pretty sure the Infinity box says 4 ohms. This will not cause any problems.
__________________
Old 01-20-2009, 10:24 PM   #12
jebz240
Not to stay off subject but the 6002si is a 4ohm speaker per the infinity website and the 6022si is a 2ohm model. http://www.infinitysystems.com/car/p...=US&Region=USA
They also state this "True Four Ohms— All Reference speakers feature two ohm voice coils. Original factory-installed speaker wiring in many cars is 18-22 gauge. This wire, and heating in the voice coil when power is applied, increase the impedance “seen” by the amplifier or head unit. The impedance of Reference Speakers has been adjusted to compensate for this increase and can be safely driven by any head unit. "
So if you keep the stock speaker wire it will protect your head unit... wierd they state them as 2ohm then say there a true 4ohm... i dunno sounds like a wierd sales gimmick I learned about impedence matching along time ago when i blew up some amps and subs... But given the cost its a worth trying i suppose.
Old 09-20-2009, 09:42 PM   #13
nekoni
Points: 1,387, Level: 20
Points: 1,387, Level: 20 Points: 1,387, Level: 20 Points: 1,387, Level: 20
very very helpful!!is your 07enthusiast stick or AT?ive been looking for an automatic dash panel removal instruction for quite a while, but nth was found..mine's the 08enthusiastAT..
nekoni is offline   Reply With Quote
Old 04-29-2011, 12:53 AM   #14
Q_Mofo
Points: 249, Level: 4
Points: 249, Level: 4 Points: 249, Level: 4 Points: 249, Level: 4
Sorry guys, newbie here.
Will this setup work with an 03 touring model?
Q_Mofo is offline   Reply With Quote
Old 04-30-2011, 07:55 AM   #15
350zspl
Points: 2,486, Level: 30
Points: 2,486, Level: 30 Points: 2,486, Level: 30 Points: 2,486, Level: 30
Today's Activity: 18.8%
Today's Activity: 18.8% Today's Activity: 18.8% Today's Activity: 18.8%
you digging up a thread that is years old
where in FL are you
what is your budget
i can do your entire system for you
i am in Boca Raton - Delray Beach area
LMK
thanks Travis
350zspl is offline   Reply With Quote
My350Z
350 Z
Paid Advertisement
Tags
350z, acura, audio, center, dashboard, improve, kenwood, nissan, panel, positive, rdx, remove, stripe, tips, tricks, zedcom
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
