Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > 350Z Tech Area > Audio & Video > Audio Builds
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 07-02-2009, 09:01 PM   #1
ChrisNelson
Points: 2,108, Level: 27
Points: 2,108, Level: 27 Points: 2,108, Level: 27 Points: 2,108, Level: 27
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
Default Kenwood Excelon System Build - '05 350z
The audio system will be comprised mostly of Kenwood Excelon components and Stinger Electronics accessories. The install is being done at a stereo shop that I work at and will be the shop demo vehicle.
The wiring is really scary looking in the first pictures, but when it's all finished the wiring will be all neat and nicely tucked away.
Started with zero gauge wiring to connect the new Stinger battery to the original battery. We'll have 2 batteries in the car now.
ChrisNelson is offline   Reply With Quote
Old 07-02-2009, 09:01 PM   #2
ChrisNelson
We removed all of the trim panels on the rear half of the car inside to get access to all compartments.
Old 07-02-2009, 09:02 PM   #3
ChrisNelson
We're putting two amps in the back of the car, so the wiring will go from zero gauge to the second battery and then split into two sets of four gauge to the amps.
Between all of the 4 gauge, signal cables, nitrous wiring, nitrous main line, and speaker wire, we had to make a larger hole between the front and rear compartment:
Old 07-02-2009, 09:03 PM   #4
ChrisNelson
The nitrous bottle will be mounted in the trunk, but where we want it to go there is no suitable mounting spot, so we had to make one:
Notice the foam structure on the drivers side of the trunk:
We removed it and traced it onto 3/4" MDF wood. Then cut the foam board to reuse the "legs" portion of it. After that we mounted the new board onto the foam and now we have a strong mount plate:
Old 07-02-2009, 09:04 PM   #5
ChrisNelson
The first thing to do with the battery wiring was replace the factory ground at the battery. It was a 6 gauge, low-strand cable and we replaced it with the zero gauge oval cable with nice terminals.
In this following picture, you can see a tiny little 10 gauge (or smaller) wire going from the chassis to the engine block, so we added a 4 gauge wire from the battery ground to the motor.
Upgrading all of these grounds will help make all of the electrical systems on the car function better, including alternator output and many times upgrading grounds on your car will increase horsepower by a small amount.
Next comes the switch panel, and finishing up the battery wiring.
Old 07-02-2009, 09:08 PM   #6
ChrisNelson
Here is a pic of the components we used for the front speakers:
6.5" component woofer next to the 10" subwoofer. Both use dry carbon fiber cones.
Base for the amp rack:
Secondary battery and wiring is finished. Just got to make it look pretty:
Getting the right angle for the amplifiers:
Had to cut the old factory speakers out of the mounting brackets:
Amp rack done and everything wired:
Old 07-02-2009, 09:10 PM   #7
ChrisNelson
Had to drill through the Molex connectors in the doors then ran 12 gauge speaker wire from the amps into the doors for the new wiring of the components:
Removed the old factory tweeter, then modified the original tweeter location to accept the new one:
Then at around 2am we started on the sub box:
Old 07-02-2009, 09:15 PM   #8
ChrisNelson
That box is just temporary, I bought a custom fit fiberglass box on this forum to use instead.
Old 07-02-2009, 09:26 PM   #9
ChrisNelson
System Components:
KENWOOD EXCELON:
DNX9140 DVD/Nav/Bluetooth
KFC-172 6.5" Coaxials
KFC-1720P 6.5" Components
KFC-XW1022D x 2 10" Subwoofers
XR1S - Digital Mono 700w Amplifier
XR4S - Digital 4 Channel 120wx4 Amplifier
Stinger SPV44 Dry Cell Battery
Old 11-03-2009, 08:36 AM   #10
ChrisNelson
Considering a new main battery up front - any input on if anything is better then an Optima Yellowtop for this build?
Old 11-03-2009, 12:24 PM   #11
StreetOC192
StreetOC192's Avatar
Since you have a deep cycle dedicated and isolated for the audio system, it could be recommended that you use a starting battery for your main.
The battery that I prefer is the Exide Orbital.
http://links.exide.com/products/auto...t_orbital.html
__________________
It's good to be back
StreetOC192 is offline   Reply With Quote
Old 02-06-2010, 05:03 PM   #12
adamtaylorpcb
adamtaylorpcb's Avatar
Points: 1,938, Level: 26
Points: 1,938, Level: 26 Points: 1,938, Level: 26 Points: 1,938, Level: 26
hate to res an old thread but what brand power wire is that
__________________
06 MBP 6MT Z, Tourenn, JBL MS-8, F90-BT, H.A.T. L841pro-SE, 2x IDMAX, 2-Q1200.1, 2-Q450.4
adamtaylorpcb is offline   Reply With Quote
Old 02-07-2010, 07:57 AM   #13
TomCat0197
Points: 620, Level: 12
Points: 620, Level: 12 Points: 620, Level: 12 Points: 620, Level: 12
Stinger Wire, XPRT series I believe.
TomCat0197 is offline   Reply With Quote
Old 02-07-2010, 08:53 AM   #14
ordinaryme
Points: 1,055, Level: 17
Points: 1,055, Level: 17 Points: 1,055, Level: 17 Points: 1,055, Level: 17
Today's Activity: 0.4%
Today's Activity: 0.4% Today's Activity: 0.4% Today's Activity: 0.4%
Where did u buy that sub box?? I think CAS doesn't offer that and that is just what i've been lookin for!
ordinaryme is offline   Reply With Quote
Old 02-09-2010, 09:09 PM   #15
sintaxeror
Points: 3,616, Level: 37
Points: 3,616, Level: 37 Points: 3,616, Level: 37 Points: 3,616, Level: 37
Send a message via AIM to sintaxeror
Looks awesome. Big fan of the build log with lots of pics =)
sintaxeror is offline   Reply With Quote
My350Z
350 Z
Paid Advertisement
Tags
1720p, 350z, amp, amps, audio, components, excelon, forum, installation, kenwood, putting, radio, stereo, system, tiny, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
