Complete installation Build Log on 2008 350Z
Well.. you've probably run across one of my posts in the last month or so while I was researching and asking questions.
I've been trying to keep everything in a single thread,.. but since this is the actual build process with pictures I thought it would be appropriate to put this JUST build log into this section,.. could benefit others down the road.
I've been working since Friday on this car,.. don't even know how many hours I've put in now, lost count.
Anyhow,.. Here's some pics of the car:
Car interior stripped 90%:
http://www.flickr.com/photos/111739693@N04/11889851006/
http://www.flickr.com/photos/111739693@N04/11889282053/
http://www.flickr.com/photos/111739693@N04/11889863356/
JL 10" sub wired, and mounted into Custom Box:
http://www.flickr.com/photos/111739693@N04/11889429764/
Factory Mids pulled out (Wow, these are terrible!) -- Had to cut them out of their spacer to reuse it with the new Components I bought.
http://www.flickr.com/photos/111739693@N04/11889999266/
New JBL Components successfully in factory spacers (one heck of a job fabricating those spacers to put these JBL mids!) -- And put the 1" tweeter in stock location (had to cut/fab behind that sail panel quite a bit to get them to fit.. but they fit perfect)
http://www.flickr.com/photos/111739693@N04/11912075985/
Used Rattle Trap Extreme to deaden doors -- Am running out of deadener, and the doors were A LOT better sealed by factory than I anticipated.
If you have some recommendations of where else to put the deadener on these doors let me know.. I have a little left.
http://www.flickr.com/photos/111739693@N04/11921687595/
http://www.flickr.com/photos/111739693@N04/11922142294/
Slot where the Custom stealth box is going,.. Used a ton of sound deadener in this spot.. picture just shows bottom, but it's done up top, sides , etc. Plus there is a 1" rubber mat that is on top of this material, not shown in pic.
http://www.flickr.com/photos/111739693@N04/11921955843/
Rear 6.5" (Late 90's German) MB Quarts installed with X-overs. [I used 5+ sq ft. of sound deadener just up in this area.. that stuff goes fast!]
http://www.flickr.com/photos/111739693@N04/11922141224/
Yes,.. I opted to wire and install a Bass ****. I KNOW many of you go against the notion of using one,.. but I plan on adjusting it on the fly quite often. So here it is mounted in a discreet "Invisible" location in the center console pop up box (top comes down and covers this). Used Industrial Velcro to mount it (worked fantastic!).. and dremeled below it for the phone cord to come through properly. I think it turned out pretty good:
http://www.flickr.com/photos/111739693@N04/11922558236/
The Custom Sub Box installed (It's downward firing). [This thing was a beast to get installed,.. 3 of the 12 bolts lined up .. So more dremel work with a light sanding bit being very careful with that MDF.] Turned out well though.
http://www.flickr.com/photos/111739693@N04/11922553716/
I'd say I'm 90% done now.
I have (not pictured) a carpeted amp rack built to go in the left "glove box" behind passenger seat (which when closed won't be seen).. that's drying right now.
Tomorrow I wire the amp up,.. plug in the headunit,.. and pray. If all works, I dial in the amp, then start re-assembling the vehicle.
Wish me luck!
Wish me luck!
m_0g
06-03-2021 10:05 AM
