Cancel Airbag Light (Proper Way) and 07 Weight Sensor Bypass
#45
hi, my airbag light is constantly on! it doesnt flash nor go off on "on position" nor motor on! I bought my car at a auction, and the airbags were never deployed, only one seat belt is jammed! Because of the price of the seat belt I wantd to buy an after market sport seat belt. How can I get that airbag light off?
Heritage (06-28-2016)
#47
on
OP (from 2007) Nice job on the directions. This cured my flashing light. It was going to make me crazy.
Thanks so much for pulling it together so clearly and organized.
#48
on
Originally Posted by Tac-M
the reset info is correct, but the actual sensor is different on 06-07 z... it can be extracted , but say good by to your seat... pix tomorrow....
i have installed it under my bride seat cushion, but i am not sure if it will work , i mean if it will accurately detect wieght of my passengers ( no fat chicks here )
the sensor is way different then the bladder that is sown here.
It sounds like the 07's have a weight sensor vesrus the bladder dsicussed in this write-up. IS that correct? Did your by-pass method work? Can you show pics and describe what you did?
#49
on
i have an 07 and the sensor is the bladder
#52
on
OK, I'm getting confused... the "bladder" is only in the passenger seat right?
on the driver side the 2 / 2.2 ohm resistor + ecu reset does the job... or am I missing something?
#53
Yep the bladder is in the passenger seat only. I've tried the resister and reset ecu and didn't work for me. I don't know if the steps I took were wrong but I tried following the steps in this thread and no luck.
#59
on
My airbag light used to came on and stayed on. I got the dealer to fix it..yesteday, the light came on again while I was just driving and start blinking...What do you think the problem is? and do the warranty still cover airbag if I bought in 2005?
