Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > Do It Yourself Guides > Audio, Video & Electronics (DIY)
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 05-22-2007, 06:52 PM   #1
Ichigo
Ichigo's Avatar
Points: 6,952, Level: 55
Points: 6,952, Level: 55 Points: 6,952, Level: 55 Points: 6,952, Level: 55
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
Default DIY Rear View Camera Install
SO it was spring cleaning at the stereo shop I work at part time and I noticed a box I know I had seen at least twenty times before but never read. Whoa its a Farenheit rear view camera. SNATCHED (with permission of course). I already have the interior out of the car because I'm upgrading my sub and amplifiers so that just makes it easier to route the wires. Now the pics:
*ADDED - Camera model # - Farenheit LP-1CA
  1. The rear view view camera -itself
2. The contents of the box
3. The contents sorted on the floor
4. Removed plate and old license plate holder
5. The inside of the rear, notice the large grommit in the center. This is where I ran the wire inside the car
6. Once the grommit is removed, you can cut a small slice in it to run the wires through
7. Once the wire from the frame is inside the car, it must be connected to a small box that was included with the frame. the image processing is done inside this box and then images are sent from the box to your headunit. Be sure to tuck it away so it doesn't get crushed.
8. Reverse wire. Dont forget the reverse wire. Without this connection the Avic Z1 wont switch to rear camera when you shift into reverse. Pioneer included a specific wire for this connection so I tapped into the reverse light in the rear as opposed to finding the wire up front.
9. Once the wires is tapped it's time for a little wire management.
10. Through the rear strut bar and out the compartment behind the passenger seat.
11. I ran the wires down the center, its a lot easier then pulling up the carpet. Time for the Z1 to come out again.
12. Find the wire for the reverse gear input and connect it to the wire that you tapped into the reverse light in the back.
13. Time to tap into some power for the camera. It doesnt really matter where you tap into the power, but since this camera has the power wires attached on the end of the cables that get attached to the head unit, I tapped the constant power from the head unit and the oem ground. The headunit has its own separate ground now. Here is a shot of the power wire prepped for install
14. The last connection, the actual video feed from the box mounted in the rear.
15. Turn on the car and test it out before securing down the head unit. Make sure all of your speakers and devices attached to the radio are functioning. It gets really tight behind the head unit and its easy to disconnect wires when reassembling. I had to change a setting on the headunit to accept camera feed for the rear.
Here are some pics of the images from the camera
With old school cheap a$$ pager on the ground for scale
with some needle nose pliers
From the side
The finished product
Enjoy.
BTW since the license plate camera frame is substantially thicker then your average frame, I had to replace the screws and the mounting clips. When I bought the car the stealership used some horrible little screws that stripped the nuts inside the oem clips. A quick trip to lowes for two new coarse thread phillips head bolts, two body clips and two plastic black screw caps did the trick.
__________________
Originally Posted by Hraesvelg You're ghey, you smell like Kimchi, and were probably that fat Korean kid who beat everyone at Street Fighter in the arcade.
Ichigo is offline   Reply With Quote
Old 05-23-2007, 06:09 PM   #2
Voboy
Voboy's Avatar
Points: 4,584, Level: 43
Points: 4,584, Level: 43 Points: 4,584, Level: 43 Points: 4,584, Level: 43
Today's Activity: 12.1%
Today's Activity: 12.1% Today's Activity: 12.1% Today's Activity: 12.1%
very clean install. Let me know if you find another box I've been looking for a clean license plate rear view camera but the ones on ebay are fugly.
Voboy is offline   Reply With Quote
Old 05-23-2007, 08:57 PM   #3
Ichigo
Ichigo's Avatar
Agreed, I really liked the idea of a frame mounted camera, but most of the ones I've seen are plasti-chrome.
Here's a link if you want one:
http://cgi.ebay.com/ws/eBayISAPI.dll...ype=osi_widget
__________________
Old 05-24-2007, 02:11 PM   #4
DesiZ_06
DesiZ_06's Avatar
very orginal license tag ichigo kurosaki....
DesiZ_06 is offline   Reply With Quote
Old 05-24-2007, 02:33 PM   #5
behjjeh
Vendor - Former Vendor
behjjeh's Avatar
Points: 7,258, Level: 56
Points: 7,258, Level: 56 Points: 7,258, Level: 56 Points: 7,258, Level: 56
Send a message via AIM to behjjeh Send a message via MSN to behjjeh
hmm i wonder see if you can hook up this to FARENHEIT screen...
behjjeh is offline   Reply With Quote
Old 05-29-2007, 09:17 AM   #6
HitLines
HitLines's Avatar
Points: 1,953, Level: 26
Points: 1,953, Level: 26 Points: 1,953, Level: 26 Points: 1,953, Level: 26
Today's Activity: 0.4%
Today's Activity: 0.4% Today's Activity: 0.4% Today's Activity: 0.4%
Send a message via AIM to HitLines Send a message via Skype™ to HitLines
Could you also use different screws with an unique bolt patter to prevent theft? I'm sure most won't even notice your license plate bracket is also a camera but it's an idea.
I used these screws to secure my amps. You can get them in all shapes and sizes. Sure you can bust out the windows but the amps are screwed down to the frame. A phillips or flathead will not do the trick.
__________________
2003 Super Black/Burnt Orange Touring (6MT) [Grind/new tranny @ 30k] — 19" Bronze D5R Speed Star — F: 245/35ZR/19 & R: 275/30ZR/19 — Slot drilled rotors — Hotchkis swayJWT Popcharger — S2k Short Antenna — JDM Clear Reflectors20% tintV1 InvisiCord — Shaved rear wiper: http://www.my350z.com/forum/showpost...5&postcount=44
HitLines is offline   Reply With Quote
Old 05-29-2007, 09:22 AM   #7
SirSpeedyZ
SirSpeedyZ's Avatar
Points: 3,033, Level: 33
Points: 3,033, Level: 33 Points: 3,033, Level: 33 Points: 3,033, Level: 33
Today's Activity: 34.5%
Today's Activity: 34.5% Today's Activity: 34.5% Today's Activity: 34.5%
very nice write up, good job
__________________
With spring comes the mod bug....
SirSpeedyZ is offline   Reply With Quote
Old 05-29-2007, 10:32 AM   #8
fairlady350z33
fairlady350z33's Avatar
nice write up and pics...the license plate camera doesn't look too bad... i'm just afraid people here in cali will steal it.
__________________
OLD 2006 MB MODS: JWT Popcharger w/ Heat Shield -- Motordyne 5/16 Iso-Thermal Plenum Spacer -- nismO Catback Exhaust -- s2000 antenna -- Solargard 5% tint in the back and 20% in the front -- SOLD APRIL 14th 2007 NEW 2007 PPW - HKS True Dual TI exhaust - Pioneer Avic D3 - s2000 antenna.
fairlady350z33 is offline   Reply With Quote
Old 05-29-2007, 06:56 PM   #9
Ichigo
Ichigo's Avatar
Thought of that and bought some security bolts, good call though!
Only problem was they were too short so I had to go with ones that would fit the body clips, I believe I looked at some like the ones you pictured but the they were for furniture and wouldn't fit the clips. Hell if they really wanted to be d1cks they could just tear the whole thing off. Next time the rear bumper is off I'll spot weld the rest of the screw thread, That'll fixem
If someone steps up to the plate to jack my stuff, I'll be happy if all they take is the camera.
__________________
Old 06-21-2007, 11:27 AM   #10
HockeyZ39
HockeyZ39's Avatar
Points: 3,759, Level: 38
Points: 3,759, Level: 38 Points: 3,759, Level: 38 Points: 3,759, Level: 38
Today's Activity: 3.8%
Today's Activity: 3.8% Today's Activity: 3.8% Today's Activity: 3.8%
Send a message via AIM to HockeyZ39
Is there a way to make my screen switch to the camera when I throw it in reverse with my JVC KD-DV5100 it has alot of inputs? and or a direct link to the screen with a toggle switch mounted some where to swtich on the fly?
See sig for my stuff.
__________________
03 Track Lemans Sunset. MODS: * AEM CAI * Borla TD exhaust * Test Pipes * Lightweight Flywheel * KP Technologies Window up module * JVC KD-DV5100 * Farenheit T-7000MHR *
HockeyZ39 is offline   Reply With Quote
Old 07-04-2007, 04:56 PM   #11
IDriveRealSLow
is there any way to get it to work on a stock 350z navigation ?
IDriveRealSLow is offline   Reply With Quote
Old 07-07-2007, 06:33 PM   #12
IDriveRealSLow
any1 kno if it works with stock navi
Old 07-11-2007, 10:56 AM   #13
usmanasif
usmanasif's Avatar
Quote:
Yes. You will have to buy a conversion box that the camera will plug into. tvnav2go makes one, as do others. Google them.
__________________
2K6 Redline GT 6MT:: Nismo :: Veilside :: Greddy :: INGS :: Toyo==FS: OEM Redline Spoiler== Only 100 miles!==PM Me
usmanasif is offline   Reply With Quote
Old 07-11-2007, 10:58 AM   #14
usmanasif
usmanasif's Avatar
Check its specs for reverse camera input. If it has it, then yes; just follow directions above on the reverse wire tap.
__________________
Old 07-11-2007, 11:10 AM   #15
HockeyZ39
HockeyZ39's Avatar
Quote:
Well I know it doesnt have a reverse input, but I was wondering if there is some way to use a relay that takes the reverse signal as an input to switch av's. In theroy is sounds do able, I just wouldnt be 100% on how, or if AV's can even be split?
__________________
Old 07-11-2007, 11:11 AM   #16
DIMERYDER
does it only work during reverse?
the reason i ask is because my rearview mirror broke off due to my loud subs. i have a monitor in the center front console, but i don't use it at all anymore. it came with the car and it's aftermarket.
i was thinking of using the monitor as a rearview mirror at all times. will it work?
__________________
http://www.myspace.com/nismo3fiftyz
DIMERYDER is offline   Reply With Quote
Old 07-11-2007, 11:24 AM   #17
HockeyZ39
HockeyZ39's Avatar
sure if u you use it for nothing else.
__________________
Old 07-11-2007, 11:29 AM   #18
dkmesa350z
Points: 3,541, Level: 37
Points: 3,541, Level: 37 Points: 3,541, Level: 37 Points: 3,541, Level: 37
Today's Activity: 3.5%
Today's Activity: 3.5% Today's Activity: 3.5% Today's Activity: 3.5%
Nice write-up, I've been wanting to do this.
does the little box that came with it reverse the image for you, or does it appear opposite?
dkmesa350z is online now   Reply With Quote
Old 07-11-2007, 11:34 AM   #19
rich harris
rich harris's Avatar
Points: 5,787, Level: 49
Points: 5,787, Level: 49 Points: 5,787, Level: 49 Points: 5,787, Level: 49
Nice write-up...clean job
__________________
BigRich Orlando Z Owners Club,Inc. Co Founder/Director
rich harris is offline   Reply With Quote
Old 07-11-2007, 11:38 AM   #20
Ichigo
Ichigo's Avatar
If you use a head unit that allows you to have the camera image on at all times yes. The Avic-Z1 does allow this.
__________________
My350Z
350 Z
Paid Advertisement
Tags
350z, backup, boyo, camera, car, diy, ebay, g37, infiniti, install, installation, installed, jdm, rear, reverse, view
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
