ZEnclosures Door Speaker Spacers Back in Stock
Old 06-13-2007, 12:16 PM
mlg9770
ZEnclosures
mlg9770's Avatar
Default ZEnclosures Door Speaker Spacers Back in Stock
ZEnclosures Door Speaker Spacers Back in Stock....
NISSAN INFINITI SPEAKER SPACERS 350Z G35 FX35 AND MORE
CNC Cut!!!!
Please call 1-941-914-0859 for questions or to pay by Visa/Mastercard.
Paypal.... zenclosures@tampabay.rr.com
$20.00 per pair + $7.00 shipping
Spacers are needed to fit aftermarket speakers in many Nissan and Infiniti vehicles.
These speaker spacers will work in the 350Z & G35. We have been told by customers that they will work in the Sentra, FX 35, M35, M45, and more.
MDF Constructed 1" thick.
Uses factory predrilled holes for mounting
Comes with mounting hardware...nuts, bolts, washers, and lock washers.
Important...Please read
Please specify hole size on payment. Different brand speakers require a different size center hole.......Please specify hole size. We have these spacers available with 5.00", 5.25", 5.50", and 5.75" center mounting holes to accomodate 6.5" door speaker.
Thanks Mike
If center hole size is not specified you will receive a pair with a 5" center hole.
mlg9770 is offline
Old 05-11-2008, 11:59 PM
Dieselinvasian
Dieselinvasian's Avatar
these spacers ended up workign perfect with my infinity kappa setup -- such a good guy to deal with ..FTW!
Dieselinvasian is offline
Old 01-18-2009, 06:42 AM
jmark
jmark's Avatar
Mike, Could I get your opinion on these speakers using your spacers?
Thanks!
Quote:
Originally Posted by jmark
What about Polk Audio db6501's mounted in the front doors of the Z?
Here is a pdf with the Polk Audio DB6501 dimensions. Anyone able to look at this pdf and say if they will fit in a 07 with a spacer? Not sure about the tweeter dimensions.....
http://www.polkaudio.com/downloads/d...inedrawing.pdf
jmark is offline
Old 01-19-2009, 06:02 PM
mlg9770
ZEnclosures
mlg9770's Avatar
Thanks!
These polks should work out fine using our spacer with the 5.00" mounting hole. Since they are less than 2 inches deep you won't have any issues with the window hitting the magnet.
thanks mike
mlg9770 is offline
Old 01-21-2009, 11:59 AM
jmark
jmark's Avatar
^ Mike, Do you sell any speakers with your spacers for install in the OEM location?
jmark is offline
Old 01-21-2009, 01:13 PM
mlg9770
ZEnclosures
mlg9770's Avatar
At this time we don't have any speakers. It is in the works though.....
thanks mike
mlg9770 is offline
Old 01-21-2009, 01:46 PM
bigbgballz
bigbgballz's Avatar
Default max clearance without spacer
thanks mike
I have read that is you can squeze up to 2 7/8" without spacer. Can you confirm on that or max its 2" before its hits the window. Thanks in advance.
bigbgballz is offline
Old 01-21-2009, 01:52 PM
mlg9770
ZEnclosures
mlg9770's Avatar
2 7/8" without a spacer won't work.......In my Z I mounted my speakers with the spacers using speakers a little over 2.50" deep and they still rubbed the window. I ended up shimming the front of the spacer to get clear of the window.
If you're using speakers 2.00" deep you will be fine when using the spacers. Its when you use speakers 2.50" deep or more when you starting having issues.
thanks mike
mlg9770 is offline
Old 01-21-2009, 02:07 PM
bigbgballz
bigbgballz's Avatar
Thumbs up Thanks
thanks mike
Thank you for your responce as i am trying to figure out all the components I will need to install some speakers. Basiclly, any speaker with depth bigger than 2.5" depth will require little bit over 1" thick spacer!
Old 01-21-2009, 05:48 PM
jmark
jmark's Avatar
thanks mike
Can you say which brand?
jmark is offline
Old 01-22-2009, 04:01 AM
mlg9770
ZEnclosures
mlg9770's Avatar
Not yet....sorry
mlg9770 is offline
Old 01-22-2009, 05:58 AM
jmark
jmark's Avatar
Not yet....sorry
That's OK. I am sure they'll be top quality. I am just starting to gather items for my stereo upgrade. I have the Clarion DXZ785USB HU and want some good front speakers to pair with it.
jmark is offline
Old 09-14-2011, 04:14 PM
myfirstzcar
myfirstzcar's Avatar
I have some alpine type r 6.5 speakers. Will they work with your spacers? Will I have to modify my door panels?
myfirstzcar is offline
Old 09-15-2011, 02:46 AM
mlg9770
ZEnclosures
mlg9770's Avatar
I've never tried these speakers with the spacer but I would guess they would work without having to modify the panels.
Anyone tried this setup? If so, how did it work out?
Thanks Mike
mlg9770 is offline
Old 09-15-2011, 02:56 PM
myfirstzcar
That's my main concern since pods are $179 unfinished.
I would also like to have good door panels for when I sell the car, eventually.
Old 10-07-2011, 10:07 PM
gu_z33
gu_z33's Avatar
i want to order these spacers but i dont know what size center hole i would need.
the mounting depths are Fronts: 2-3/16 in (56mm) Rears: 1-13/16 in (46.5mm)
lmk i would really like to order some soon!
gu_z33 is offline
Old 10-08-2011, 03:09 AM
mlg9770
ZEnclosures
mlg9770's Avatar
Just let us know the make and model of the speakers you're using and we can determine which spacers you'll need.
These spacers only work for the front doors of the 350z......Thanks Mike
mlg9770 is offline
Old 10-08-2011, 02:25 PM
gu_z33
gu_z33's Avatar
they are kenwood KFC-P709PS
gu_z33 is offline
Old 10-09-2011, 04:40 AM
mlg9770
ZEnclosures
mlg9770's Avatar
These speakers require the spacer with a 5.00" mounting hole. Thanks Mike
mlg9770 is offline
Old 12-16-2011, 08:47 AM
05350ZR
05350ZR's Avatar
Could you tell me which size spacer I'd need for a set of Rockford Fosgate prime R1652-S? I'd like to order these ASAP. Thanks!
05350ZR is offline
Quick Reply: ZEnclosures Door Speaker Spacers Back in Stock
