Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > Marketplace > Vendor Classifieds > Audio Video
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Closed Thread
Thread Tools Search this Thread
Old 11-28-2008, 03:59 PM   #1
Vivid Racing
Vivid Racing
Vivid Racing's Avatar
Points: 7,847, Level: 59
Points: 7,847, Level: 59 Points: 7,847, Level: 59 Points: 7,847, Level: 59
Today's Activity: 51.2%
Today's Activity: 51.2% Today's Activity: 51.2% Today's Activity: 51.2%
Send a message via AIM to Vivid Racing
Default Upgrade your Nissan's Audio System with Diamond Audio
Diamond Audio Sound Enhancement Package 1 Nissan 350Z
Want to improve the sound system in your 350Z without spending huge dollars? Well Vivid Racing has partnered with Diamond Audio to introduce this Level 1 speaker package to directly replace your OEM door speakers with better quality, better sounding car audio components. This Level 1 kit features the Diamond Audio D3 6.5" component set for the front and rear speakers.
Our new D3 speakers might be the starting point of our coaxial and component range, but they are anything but entry level. We start with the same high density proprietary composite ABS frame found in our D6 convertible systems, add a butyl rubber surround and a graphite injected polypropylene cone and you have the makings of a very good driver. Whether choosing a component or a coaxial system all D3 speakers utilize 1” aluminum dome tweeters. Our D3 component systems use an outboard 18dB high pass/ 12dB low pass crossover with our RAF (Rear Acoustic Fill) circuit so it is easy to add more speakers to your system. You won’t find a better combination of value and performance anywhere.
Level 1 Kit Includes:
Front D363.5 - 6.5" Component Set
Rear D363.5i - 6.5" Component Set
$339 Shipped
Diamond Audio Sound Enhancement Package 2 Nissan 350Z
Don't want the cheap products but don't want to spend a fortune on a car audio upgrade? Well Vivid Racing has partnered with Diamond Audio to introduce this Level 2 Sound Enhancement package to directly replace your OEM door speakers with better quality, better sounding car audio components and add a 12" subwoofer for bass! This Level 2 kit features the Diamond Audio D3 6.5" component set for the front and rear speakers. Next we add a 12" subwoofer with large rubber surrounds and a titanium finish. To power this package, we include for the front speakers a 300 watt D1 4 channel amplifier. The rear 12" subwoofer is powered by a D1 400 watt monoblock amplifier.
The most dramatic improvement you will ever make to any audio system is by adding a subwoofer. D1 series 2 subwoofers make it easy. These new subwoofers have large roll rubber surrounds and larger motors for better power handling than competing models. They are available in either dual 2 ohm or 4 ohm versions. They work equally well in small sealed or medium vented enclosures. They sound great. And best of all they are affordable.
The D1 amplifiers offer just the right mix of features and power and are a perfect match for our D1 subwoofers. D1 amplifiers feature 12dB per octave high and low pass crossovers and 6dB of bass boost. With both RCA and high level inputs it is easy to upgrade your factory system or build a great sounding all out show stopper.
Level 2 Kit Includes:
Front D353 - 5.25" Component Set
Rear D353 - 5.25" Component Set
D110 10" Dual Voice Coil Subwoofer
D1 300.4 - 300 Watt Four-Channel Amplifier
D1 400.1 - 400 Watt Monoblock Amplifier
Wiring, Hardware, Instructions to connect to a head unit is NOT Included.
Professional installation recommended.
$1069 Shipped
Diamond Audio Sound Enhancement Package 3 Nissan 350Z
If you want the best sound quality and premium car audio products in your vehicle, the Vivid Racing Diamond Audio Level 3 package is your answer. Vivid Racing has partnered with Diamond Audio to offer this Level 3 car audio enhancement package to directly replace your OEM door speakers with better quality, better sounding car audio components, add 2 12" subwoofers, and bring all the power from Diamond Audio's premier amplifiers. This Level 3 kit features the Diamond Audio D6 6.5" component set for the front and rear speakers. Next we add 2 12" D3 subwoofers and to power these a D1 400 watt monoblock amplifier. The D6 front speakers are powered by D3 Amplifier featuring 4 channels and 500 watts.
Something different. That was our goal with the new D6 convertible systems. The bass unit uses a butyl rubber surround attached to the same hard-anodized alloy cone that is found on our D6 subwoofers. This cone is lightweight and has the strength needed for tight, accurate midbass and smooth overall response. The frame is made of a high density proprietary composite ABS and is very rigid. These systems have the unique ability to be used as either a component or a coaxial speaker. Depending on your requirements, the tweeter can be installed separately or mounted directly to the midbass/ midrange driver. With the option of either a 1” silk or aluminum dome tweeter you can choose the type of sound that fits your musical taste. Our model specific crossover with RAF (Rear Acoustic Fill) allows an additional pair of speakers to be added without adding another amplifier. The new D6 speakers are the definition of flexibility.
Like our D3 amplifiers, our D3 series 2 subwoofers are the definition of value and performance. With large 2.5” dual voice coils, available in 2 ohm or dual 4 ohm, beautiful polished back plates and dual spiders, with woven tinsel leads, these subs have features found in much more expensive models. All D3 series 2 subwoofers handle up to 400 watts RMS. Our proprietary aluminum dust cap pulls heat away from the voice coil so they play louder, longer.
The perfect blend of value and performance, is our combination of the D1 and D3 amplifiers! With a newly designed heat sink that features 25% more aluminum than the previous generation, these amplifiers are capable of considerably more power than ever before without increasing their overall size. On board 12dB per octave continuously variable crossovers and up to 12dB of bass boost make them very flexible.
Level 3 Kit Includes:
Front D662s - 6.5" Component Set
Rear D662s - 6.5" Component Set
D312.2 - 12" Dual Voice Coil Subwoofers
D3 500.4 - 500 Watt Four-Channel Amplifier
$1789 Shipped!!!
Vivid Racing has put together these car audio packages to enhance your vehicles sound system from the stock quality. We have chosen to partner with Diamond Audio, a Arizona based manufacturer of speakers, subwoofers, and amplifiers. Diamond Audio has several different levels of products to give your vehicle a crisper, cleaner, and more "thumping" sound. Each one of our audio packages includes the direct replacement sized speakers to upgrade your vehicle. We have spec'd out the best size speakers and/or amplifiers to work in your vehicle to produce a great sound system.
__________________
Scott Renner | 480-966-3040 ext:229 | AIM: vividracingscott | Scott@Vividracing.com
Vivid Racing 350Z Catalog
PM ME FOR DISCOUNT PRICING!!
Tanabe Spring Sale!!
Vivid Racing is online now
Old 12-17-2008, 09:37 AM   #2
Vivid Racing
Vivid Racing
Sound systems still here guys!!
__________________
Old 02-12-2009, 11:32 AM   #3
phatbuddha
Too bad they discontinued the Hex series.
phatbuddha is offline
Old 02-21-2009, 10:46 PM   #4
blackz123
blackz123's Avatar
Points: 1,766, Level: 24
Points: 1,766, Level: 24 Points: 1,766, Level: 24 Points: 1,766, Level: 24
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
Front D662s - 6.5" Component Set how bout just for tht
__________________
Special thx to Peter@M1
blackz123 is offline
Old 03-09-2009, 07:56 AM   #5
klaze1
klaze1's Avatar
Points: 1,482, Level: 21
Points: 1,482, Level: 21 Points: 1,482, Level: 21 Points: 1,482, Level: 21
Today's Activity: 0.4%
Today's Activity: 0.4% Today's Activity: 0.4% Today's Activity: 0.4%
Send a message via AIM to klaze1
any one have any of these products that would be able to tell us a rating maybe?
klaze1 is offline
Old 03-17-2009, 01:52 PM   #6
Kuhan
Hibernating
Kuhan's Avatar
Points: 2,055, Level: 27
Points: 2,055, Level: 27 Points: 2,055, Level: 27 Points: 2,055, Level: 27
Today's Activity: 9.3%
Today's Activity: 9.3% Today's Activity: 9.3% Today's Activity: 9.3%
I got Diamond Audio S600S for front speakers, and they sound awesome for the money.
Kuhan is offline
Old 03-18-2009, 10:15 AM   #7
mazymus
Points: 1,532, Level: 22
Points: 1,532, Level: 22 Points: 1,532, Level: 22 Points: 1,532, Level: 22
How does DA compare to JL speakers??
mazymus is offline
Old 03-22-2009, 11:55 AM   #8
Obsidianice
Points: 1,249, Level: 19
Points: 1,249, Level: 19 Points: 1,249, Level: 19 Points: 1,249, Level: 19
Quote:
The diamonds definitely have a better sound than JL speakers.
Obsidianice is offline
My350Z
350 Z
Paid Advertisement
Closed Thread
Tags
350z, 525, 65, audio, bass, boost, california, components, convertible, d6, diamond, g35, infiniti, nissan, southern, speakers, subwoofer, upgrade, upgrades
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
