Wicked cas glove box sub box subwoofer enclosure special - Page 2 - MY350Z.COM Forums
Closed Thread
Thread Tools Search this Thread
Old 02-27-2010, 06:34 AM   #21
Nazar
Nazar's Avatar
Quote:
Originally Posted by scoobyrex247 View Post
hey is the special still valid?
Call me today.
Nazar is offline
Old 03-09-2010, 09:00 AM   #22
davidc81
hi nazar- i sent you payment for this box on 2/25/10. when should i receive my box?
davidc81 is offline
Old 03-14-2010, 05:49 PM   #23
silents1ick
how much shipped to 30458?
silents1ick is offline
Old 03-15-2010, 07:27 AM   #24
Nazar
Nazar's Avatar
Quote:
$299.95 Shipped.
Nazar is offline
Old 03-22-2010, 09:50 AM   #25
J. Dub
J. Dub's Avatar
Wow, good stuff. Thanks for making these.
J. Dub is offline
Old 03-24-2010, 08:53 AM   #26
J. Dub
J. Dub's Avatar
Do you have anymore pics available of these installed? The pics in original post are difficult to see.
By chance a pic of the box installed without subs loaded in them as well?
Thanks.
J. Dub is offline
Old 03-24-2010, 09:01 AM   #27
Nazar
Nazar's Avatar
Nazar is offline
Old 03-24-2010, 09:04 AM   #28
tylerxfire
tylerxfire's Avatar
pics of finished product?
tylerxfire is offline
Old 03-24-2010, 10:36 AM   #29
J. Dub
J. Dub's Avatar
Quote:
Originally Posted by Nazar View Post
This is where I'm getting confused on. From this pic it looks like there is no where to put the subs? Am I retarded? It looks like there is no hole there for the 10.
J. Dub is offline
Old 03-24-2010, 12:12 PM   #30
Nazar
Nazar's Avatar
Quote:
You will not see any subs. They fire down.
Speaker / Subwoofer mounts to the bottom.
Nazar is offline
Old 03-24-2010, 01:35 PM   #31
J. Dub
J. Dub's Avatar
Also, does this come w/ instructions on how to install? Any cutting required to fit this box?
What holds the box in area upon aggressive stopping?
Thanks in advance, as you can tell I'm highly interested but need much more info. Your website is vague... Very vague.
J. Dub is offline
Old 03-24-2010, 02:34 PM   #32
J. Dub
J. Dub's Avatar
Quote:
I found some pics that may help people like you and I.
http://www.wickedcas.com/gallery/v/m...s/350z/ZR350Z/
J. Dub is offline
Old 03-26-2010, 02:07 PM   #33
J. Dub
J. Dub's Avatar
I thought of more questions.
JL recommends a sealed box for the 10W3v3 to be 0.625 cubic ft -- 18.0 inches wide x 11.0 inches height x 9.0 inches deep
I have read your box is .85 cubic feet Is that true?
What are the dimensions of your box?
When we order the box and we want the 10W3v3... Do you send us the 10W3v3-2 or 10W3v3-4??
Thanks in advance.
J. Dub is offline
Old 04-01-2010, 05:13 PM   #34
07rdsterGT
So is there a special price as well for the box with the JL AUDIO 13Tw5 Subwoofer as well?
07rdsterGT is offline
Old 04-01-2010, 05:20 PM   #35
SnyzzleZ
SnyzzleZ's Avatar
im also interested and have questions... is that the actual finished product??? I dont want it to look like that behind my seat or can you put the glove box 'lid' over that so you wont see any of it? Also, why does it fire down? where would the pressure escape to? And do you have instrusctions on how to install it with a sub/wiring?? Again though, very interested and a good idea.. i really need my trunk space back..
and one other question.. my car came with factory navi.. so i only have the glove box on the passenger side.. Im sure you've done work on one before and was wondering if it was even possible to install one of these on the driver side and still keep the navigation functional. Thanks ahead of time.
SnyzzleZ is offline
Old 04-02-2010, 05:59 AM   #36
Nazar
Nazar's Avatar
Thanks in advance.
When you order a Box with 10w3v3 I can send you a 4 ohm or 2 ohm sub as long as you specify what you want. If you are not sure call me and I will look up the specs of your amp. If you don't have an amp Well i have plenty you can buy from
Quote:
On our website we sell the 13tw5 box for $899 However is you guys are interested I will sell the 13tw5 Glove bos for you guys for $649.95 + Shipping Yes you heard it right. 13tw5 And Glove box $649.95 + shipping Must call your order in. 603-642-4222 Ask for Me Nazar
Once the installation is done in the glove box (which is not an easy install But it is totaly stealth when done) You should be able to put yor stock covers back on.
Bass is not directional, however the way you create a wave in the car is very imprtant. We have done several tests in this car and facing the sub down is the best results if you are using that spot behind the seat. The bass will travel inside the car no worries.
Nav will be no problem, obviously you will need to use the opposite side glove box for the sub...
Here is a picture of the sub installed and finished, Looks stock... 100%
IF YOU WOULD LIKE THE MATCHING LOOK JUST ORDER THE BOSE SUB COVER FOR BOTH SIDE BUT WILL NOT MAKE MUCH DIFFERENCE FOR SOUND.
Nazar is offline
Old 04-02-2010, 09:06 AM   #37
J. Dub
J. Dub's Avatar
Thanks for chiming in Nazar, I was wondering the following:
Does this come w/ instructions on how to install?
Thanks in advance.
J. Dub is offline
Old 04-02-2010, 09:26 AM   #38
Nazar
Nazar's Avatar
Thanks in advance.
The box will need some trimming to fit, you will need to line up the stock bolt holes and use the same sopts and drill through the box and the lip if the box gets bolted in. No chance it is going anywhere no matter how fast you stop. As long as you used atleast 6 bolts 2 on top 2 on the bottem 2 on sides. Or just use 2 on each side.
Nazar is offline
Old 04-02-2010, 11:08 AM   #39
J. Dub
J. Dub's Avatar
Ok thanks for input. I plan on removing all trim pieces this weekend to clean up, lay sound dead'n down and will inspect this area you mentioned.
I presume drilling the fiber glass box won't make it sound bad?
J. Dub is offline
Old 04-02-2010, 03:10 PM   #40
Nazar
Nazar's Avatar
You are only drilling the lip around the face of the box. Which is not part of the enclosure. It is there for mounting purposes.
Nazar is offline
Closed Thread
Thread Thread Starter Forum Replies Last Post
FS: Sparco Helmet Carbon Fiber WTX-7 Air BNIB must see Gruppe-S Body Interior 13 05-16-2016 10:42 PM
Tags
350z, 8, box, enclosure, g35, glove, glovebox, infiniti, location, nissan, replacement, roadster, speaker, stock, subwoofer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright 2002 - 2008, MY350Z.COM All Rights Reserved.
