BE A HERO! GoPro now @ Import Image Racing!!!**********
Old 08-12-2011, 07:16 AM
IMPORTIMAGE
Import Image
IMPORTIMAGE's Avatar
Default BE A HERO! GoPro now @ Import Image Racing!!!**********
WE ARE PROUD TO BRING YOU THE LEADER IN AUDIO/VISUAL TECHNOLOGY FOR MOTORSPORTS AND MORE
MOTORSPORTS AND HELMET CAMS
**SHIP FREE FOR my350z MEMBERS**
IN THE LOWER 48 USA
Import Image Racing OFFERS THE ENTIRE GOPRO LINEUP, BUT HERE ARE SOME OF THE CREAM OF THE CROP
HD MOTORSPORTS HERO $299
STD DEF $149.99
ABOUT:
GoPro’s HD Motorsports HERO is the world’s highest performance 1080p HD on board video and still photo racing camera. Professional quality 1080p, 960p, and 720p HD resolutions records the action at 30 frames per second (60 fps in 720p). The HD Motorsports HERO easily mounts to any helmet, motorcycle, ATV, car, plane, jet ski, boat, snowmobile or other vehicle. The camera’s quick-release mounting design makes it easy to re-position the camera around your vehicle for professional quality HD video from several angles.
Record up to 2.5 hours on a single charge and up to 9 hours total on a 32GB SD card (not included).
GoPro’s obsession with sound has conquered the wind. At 85 mph on a motorcycle, you’ll enjoy the throaty sound of your motor, not the wind. Inside even the quietest street cars, hear the pull of your motor…not the drone of the wind and road.
The camera can also shoot automatic 5MP time lapse photos at 2/5/10/30 and 60 second intervals during your drive or ride, hands free. Press the shutter button once and record up to 2.5 hours of on board action with poster-print quality photos.
Included are mounts for two helmets and three vehicles, as well as a suction cup for maximum versatility and convenience. Also included is a 1100mAh rechargeable lithium-ion battery that lasts for up to 2.5 hours of constant recording. With optional accessories, you can also plug the camera into a wall outlet, cigarette lighter, or with any USB-compatible power adapter, wire it directly to your vehicle’s electrical system. The battery will charge while you record.
Waterproof to 180’ / 60m and protected from rocks and other hazards thanks to its removable polycarbonate housing. Replacement housings and lens kits are available, making repairs or refurbishing your HD HERO camera affordable and convenient.
WHAT COMES WITH IT?
1 HD HERO Camera (5 megapixel)
1 Rechargable 1100 mAh Lithium-Ion Battery
1 Waterproof Quick-Release Housing (180’/60 m)
3 Flat, 3M™ Adhesive Mounts
2 Curved, 3M™ Adhesive Mounts
2 Quick-Release Buckles
1 Vertical Surface “J-Hook” Buckle
1 Suction Cup Mount
1 Three-Way Pivoting Side Arm Assembly
1 USB Cable
1 Component Video (HDTV) Cable
1 Composite Video + Audio Out Cable
Warranty: One Year
TECH SPECS:
Camera Optics
  • Lens Type: Fixed Focus (2ft/.6m – ∞), glass
  • Aperture: f/2.8 (high performance in low-light situations)
  • Angle of View: 170º ultra wide angle in WVGA, 720p, or 960p mode
  • Angle of View: 127º wide angle in 1080p mode
Video
  • HD Video Resolution Modes: (subject to change, pending final firmware release)
    • 1080p = 1920×1080 pixels (16:9), 30 fps, 15 Mbit/s data rate
    • 960p = 1280×960 pixels (4:3), 30 fps, 12 Mbit/s data rate
    • 720p = 1280×720 pixels (16:9), 60 fps, 15 Mbit/s data rate
    • 720p = 1280×720 pixels (16:9), 30 fps, 8 Mbit/s data rate
    • WVGA = 848×480 pixels (16:9), 60 fps, 8 Mbit/s data rate
  • Sensor Type: 1/2.5″ HD CMOS, 2.2µm-sized pixels
  • Light Sensitivity: Super low-light sensitivity (>1.4 V/lux-sec)
  • Video Format: H.264 compression, saved as Windows- & Mac-compatible MPEG4 (.mp4) file
  • Exposure Control: Auto with user selectable center weighted average and spot metering settings
  • White Balance: Auto
Audio
  • Microphone: Built-in, mono with AGC (automatic gain control)
  • Audio Format: 48 kHz, AAC audio compression
  • Resolution: 5 megapixel
  • Capture Modes: Single shot, photo every 2, 5, 10, 30 or 60 secs.; 3 photo burst; self-timer
Storage
  • Memory: SD card (SDHC), up to 32GB capacity (not included)[/CENTER]
  • Average recording times (using 32GB SD card):[/CENTER]
    • 1080p (30 fps): 4h 21m
    • 960p (30 fps): 5h 26m
    • 720p (60 fps): 4h 21
    • 720p (30 fps): 8h 09m
    • WVGA (60 fps): 8h 09m
Camera Connectors & Cables
  • PC Connection: USB 2.0 (data connection and battery charging)
  • HDTV Out: HD NTSC & PAL (component cable incl.)
  • Audio Out: Combo 2.5mm jack with stereo audio and composite video out
  • PC Compatibility: Windows® Vista or Windows® 7; Mac OS® X 10.4.11 and later
Power & Battery
  • Battery Type: Rechargeable 1100 mAh lithium-ion
  • Battery Life: Approx. 2.5 hrs
  • Charging: via USB to computer or optional power adapter
  • Charge Time: 80% capacity after 1 hour with optional power adapter; or 2 hours with a computer’s USB port
Waterproof Camera Housing
  • Depth Rating: Up to 180 feet / 60 meters
  • Construction: Polycarbonate and stainless steel
  • Hardware: Stainless steel
Size & Weight
  • Dimensions (H x W x D): 1.6” x 2.4” x 1.2” (42mm x 60mm x 30mm)
  • Weight: 3.3oz (94g) incl. battery, 5.9oz (167g) incl. housing
WHAT ELSE IS AVAILABLE!!??
HD HELMET HERO $299
STD DEF 149.99
ROLL BAR MOUNT FOR GO PRO $29.99
HEAD STRAP ACCESSORY $14.99
ADDITIONAL SUCTION CUP MOUNT $29.99
TRIPOD ADAPTOR FOR GOPRO $7.99
GRAB BAG EXTRA QUICK RELEASES, MOUNTS ETC.. $19.99
THESE AND SO MANY MORE ACCESSORIES, BATTERIES ETC... ARE AVAILABLE NOW FROM IIR.
ANY QUESTIONS PM OR EMAIL
Billy@importimageracing.com
AIM: ImportImageBilly
Import Image Racing Your Online Source for Aftermarket High Performance Car Parts and Accessories for Subaru WRX and STI, Nissan, Mazda, Misubishi Evolution and others.
Direct Line: 804-690-2452
Shop Line: 239-540-6385
Visa/Mastercard/Discover/Paypal and (amex) Google checkout![/B][/CENTER]
TIME TO TAKE SOME AMAZING PHOTOS, VIDEOS AND MORE ALL IN ONE SPOT SAFELY
FOR YOUR VEHICLE.
CUSTOMERS BE SURE TO SHARE YOUR VIDEOS AND PICS WITH US IN THIS THREAD!
opcorn:
SAMPLE GOPRO HD VIDEO, ALL SHOT WITH GOPRO EQUIPMENT SOLD RIGHT HERE
PIKES PEAK 2011
?GoPro HD: Pikes Peak 2011 Monster Tajima's World Record? - YouTube
HELMET CAM, GOES WHERE YOU GO
GoPro HD: Skateboard Big Air with Andy Mac - X Games 16 - YouTube
Questions: Billy (804)-690-2452
(email)billy@importimageracing.com
AIM- importimagebilly
IMPORTIMAGE is offline
Old 08-19-2011, 08:36 AM
IMPORTIMAGE
Import Image
Friday Bump!
Regards,
www.importimageracing.com
Old 08-24-2011, 12:13 PM
IMPORTIMAGE
Import Image
Wednesday Bump!
Regards,
Old 08-30-2011, 07:43 AM
IMPORTIMAGE
Import Image
Tuesday Bump!
Regards,
Old 08-31-2011, 10:15 AM
IMPORTIMAGE
Import Image
Wednesday Bump!
Regards,
Old 09-06-2011, 08:28 AM
IMPORTIMAGE
Import Image
Tuesday Bump!
Regards,
Old 09-13-2011, 06:08 AM
IMPORTIMAGE
Import Image
Tuesday Bump!
Regards,
Old 09-15-2011, 06:41 AM
IMPORTIMAGE
Import Image
Thursday Bump! Don't forget this week only use Coupon Code: NEWSLETTER on your website for 5% off!
Be sure check out our facebook page as well!
Regards,
www.facebook.com/officialimportimageracing
Old 09-21-2011, 05:36 AM
IMPORTIMAGE
Import Image
Happy Weds! pm/email us and we'll get back to you asap! 239 540 6385 need something and we are not around? call billy at 804-690-2452
or support @ (312) 985-6711
CHECK OUT OUR NEW WEBSITE!!!! www.importimageracing.com
and the daily deal available on there!
We are at the NEW Shop working 9-5 for you!
SUPER SALE going on TODAY ONLY! ask your IIR rep!
for a great deal, send us your list or inquiries and we will do our best for you!
check out our deal of the day!
http://forums.nasioc.com/forums/show....php?t=2244497
check out our new project wrx!
http://forums.nasioc.com/forums/show....php?t=2220117
Yes we have a real warehouse with real inventory, not moms house, an apartment or anything of that sort.
to see who you are really buying from facebook us!
http://www.facebook.com/officialimportimageracing
Old 09-22-2011, 01:22 PM
IMPORTIMAGE
Import Image
Happy Thursday! pm/email us and we'll get back to you asap! 239 540 6385 need something and we are not around? call billy at 804-690-2452
http://forums.nasioc.com/forums/show....php?t=2245013
Old 10-05-2011, 11:34 AM
IMPORTIMAGE
Import Image
Midweek Bump!
Hit us up for your car part needs
Regards,
Old 10-07-2011, 09:44 AM
IMPORTIMAGE
Import Image
Friday never felt so good!
We hope everyone has a safe and wonderful weekend
Regards,
Old 10-10-2011, 09:59 AM
IMPORTIMAGE
Import Image
We hope everyone had a great weekend!
Come on in for Columbus Day sales
Regards,
Old 10-11-2011, 07:32 AM
IMPORTIMAGE
Import Image
Ask us for suspension and exhaust deals today!
Regards,
Old 10-13-2011, 07:01 AM
IMPORTIMAGE
Import Image
We offer multiple part discounts!
Let us know what you need and we'll set you up with an awesome deal
Regards,
Old 10-17-2011, 09:59 AM
IMPORTIMAGE
Import Image
Happy Monday!
Let us know what we can do for you today
Regards,
Old 10-19-2011, 11:54 AM
IMPORTIMAGE
Import Image
It's the middle of the week, halfway to friday!
The weekend can't come any sooner!
Get your parts before the weekend
Regards,
Old 10-20-2011, 11:04 AM
IMPORTIMAGE
Import Image
Ready to make some deals
Need multiple parts? GREAT we can hook it up!
Regards,
Old 10-26-2011, 12:41 PM
IMPORTIMAGE
Import Image
Midweek Bump!
Regards,
Old 11-02-2011, 08:51 AM
IMPORTIMAGE
Import Image
Middle of the week!
Come on in for deals during SEMA week
Regards,
Quick Reply: BE A HERO! GoPro now @ Import Image Racing!!!**********
