Help please on speaker setup
Old Feb 16, 2004 | 06:36 PM
Overhill's Avatar
Overhill
Default Help please on speaker setup
First off I have to thank everyone for getting me this far.
I installed a new JVC Deck,all speakers, sub. My back speakers I ran new wire. My Front I used the factory wire. This is where my problem starts. The fronts wont work using factory wire. From what I read I can't due to amps ect. My question is.... a easy way to wire the front speakers.. I dont really wont to pull threw the door. can I splice into the factory wire at the door where it comes in?? If so what color or one is it? Is there a better way? I have the Roadster model. If anyone can help much thanks.
Old Feb 16, 2004 | 07:57 PM
gt3's Avatar
gt3
Hi, you can definitely use the factory wires, but I won't recommended it because they are very thin. Are you using a harness for the Nissan, I recommend it especially because you are planning to use the factory wiring. It will make thing a lot easier since everything is color coded the same way. If you are not, the coloring of the wires for the front speakers to the headunit are as follows:
right front + Gray
right front - Gray / Black
left front + White
left front - White/ Black
At Both doors (at least for nonBose system):
+ is red
- is blue
Hope this helps.
Old Feb 16, 2004 | 09:20 PM
bastard's Avatar
bastard
There's a little plug looking thing on the harness where it comes to the inside of the door. There's 3 red wires and 3 blue wires going in to it. It's just a splitter thing (instead of a real crossover of course) and I believe the middle red and middle blue wires are the ones that go to the plug behind the headunit. You can check this with a multitester before cutting anything: use a flathead screwdriver to pop the insert inside this plug thing out. You can see where it's pressed together on the opposite side of the wire inputs. The center part is actually like 2 E shapes to split the red and blues into 2 outputs. With this removed, you can use a multitester or test light maybe to check which one goes to the headunit plug.
Old Feb 17, 2004 | 03:54 AM
Overhill's Avatar
Overhill
ok, thanks guys Im going to play around tonight. Ya I have the bose system and I cant get the factory wire in the front to work.Right now im not going to amp it.Im going to try to look for that plug by the door.. Thanks
350Z_Al
Oct 29, 2020 07:44 PM
3vilbunny
Jul 18, 2017 05:10 PM
kyin
Oct 15, 2015 05:54 AM
