Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > General > Motorsports > Autocross/Road
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 02-10-2007, 06:30 PM   #1
Robert_K
Robert_K's Avatar
Points: 11,863, Level: 71
Points: 11,863, Level: 71 Points: 11,863, Level: 71 Points: 11,863, Level: 71
Today's Activity: 47.0%
Today's Activity: 47.0% Today's Activity: 47.0% Today's Activity: 47.0%
Send a message via AIM to Robert_K Send a message via Yahoo to Robert_K
Question SCCA Solo 2 Classing???
OK so I've auto-x before with the military and never an SCCA event. I've been told that I should run in BSP and I'm curious why? What makes one car go to one class vs. another. Also What makes me go to BSP? I've included a list of mods that I believe are relevant to auto-x classing.
Engine:
- AutoTechnic CF Shroud
- JWT PopCharger w/ Heatshield
- MotorDyne 5/16" Spacer w/ ISO Gasket
- UR Underdrive Crank Pulley
- Gates Belts
- APS 2.5" Test Pipes
- TurboXS UTEC
- TurboXS Tuner Wideband w/ Bosch O2 Sensor
- Royal Purple 10W30 Engine Oil
- Royal Puple MaxGear 80W-90 Diff Oil
- Redline Oil MTL/ MT-90 Mixed Tranny Oil
Suspension & Brakes:
- Hotchkis Stage 1 TVS Kit (Hotchkis Lowering Springs, Hotchkis F&R Adjustable Sway Bars, Bushings, and Brackets)
- StopTech Stage 2 OEM Brake Kit* (StopTech Slotted Rotors, Axxis Ulitmates Pads, StopTech Stainless Steel Lines, Motul RBF600 Fluid)
* Might run OEM rotors w/ EBC YellowStuff brake pads.
Wheels/Tires:
- 225/45-18F & 245/45-18R BFG KDW
- OEM Touring 18's
__________________
"A government big enough to give you everything you want, is strong enough to take everything you have." -Thomas Jefferson
Robert_K is offline   Reply With Quote
Old 02-10-2007, 06:37 PM   #2
Points: 9,436, Level: 65
Points: 9,436, Level: 65 Points: 9,436, Level: 65 Points: 9,436, Level: 65
Today's Activity: 99.9%
Today's Activity: 99.9% Today's Activity: 99.9% Today's Activity: 99.9%
Do you have a copy of the rule book? You can get one here: http://www.moutons.org/sccasolo/
__________________
370Z 2009 Sport Package
davidv is offline   Reply With Quote
Old 02-10-2007, 06:45 PM   #3
DavesZ#3
Administrator
DavesZ#3's Avatar
Points: 21,928, Level: 92
Points: 21,928, Level: 92 Points: 21,928, Level: 92 Points: 21,928, Level: 92
Today's Activity: 18.7%
Today's Activity: 18.7% Today's Activity: 18.7% Today's Activity: 18.7%
Stock class (BS) implies that the car is totally stock with only a few allowed modifications (i.e. catback exhaust, R-compound tires, etc.)
Beyond that, you drop to Street Prepared (BSP) when you make more extensive modifications, like wider wheels, suspension changes.
After that, you drop to Street Modified.
In your case, things like the non-stock brake system, test pipes and Hotchkis TVS drop you out of stock and into BSP. You might even have to drop to SM2 as I'm not sure the UTEC is allowed in BSP.
You can download a copy of the SCCA rules from here:
http://www.scca.com/_FileLibrary/File/2007SoloRules.pdf
It explains what each class (Stock, Street Prepared, Street Modified, etc.) allows and disallows.
__________________
2004.5 Daytona Blue Track
Nismo • JWT • Motordyne • Thermo-tec • Pi-Thon • Volk • Michelin • Hotchkis • Endless • Centric • Goodridge • Koni • Powergrid • B-Cool • Classic Soft Trim • Tommy Kaira • Kenwood • Sirius • Infinity • KP Technologies • Valentine {Stealth} • Zaino • EVO-R
New to MY350Z? Have a question? Please read this thread first: Top 100 Questions Thread (CLICK)
DavesZ#3 is offline   Reply With Quote
Old 02-10-2007, 06:55 PM   #4
Robert_K
Robert_K's Avatar
OK... So a stock Nissan 350Z can run BS class. What makes me run in BSP?
Suspention? Intake? Brakes?
__________________
Old 02-10-2007, 07:00 PM   #5
Robert_K
Robert_K's Avatar
I didn't read anything on SM2 about EMS.
__________________
Old 02-10-2007, 07:34 PM   #6
ULLLOSE
All three.
__________________
2005-2006-2007-2008 SCCA BS Natl Champ
ULLLOSE is offline   Reply With Quote
Old 02-10-2007, 07:38 PM   #7
ULLLOSE
Engine:
BSP- JWT PopCharger w/ Heatshield
BSP- MotorDyne 5/16" Spacer w/ ISO Gasket
BSP- UR Underdrive Crank Pulley
BS- Gates Belts
BSP- APS 2.5" Test Pipes
BSP- TurboXS UTEC
BSP- TurboXS Tuner Wideband w/ Bosch O2 Sensor
BS- Royal Purple 10W30 Engine Oil
BS- Royal Puple MaxGear 80W-90 Diff Oil
BS- Redline Oil MTL/ MT-90 Mixed Tranny Oil
BSP- Hotchkis Stage 1 TVS Kit (Hotchkis Lowering Springs, Hotchkis F&R Adjustable Sway Bars, Bushings, and Brackets)
BSP- StopTech Stage 2 OEM Brake Kit* (StopTech Slotted Rotors, Axxis Ulitmates Pads, StopTech Stainless Steel Lines, Motul RBF600 Fluid)
Wheels/Tires:
BS- 225/45-18F & 245/45-18R BFG KDW
BS- OEM Touring 18's
__________________
Old 02-10-2007, 07:47 PM   #8
Robert_K
Robert_K's Avatar
Engine:
BSP- JWT PopCharger w/ Heatshield (Can be removed)
BSP- MotorDyne 5/16" Spacer w/ ISO Gasket (Can't really tell)
BSP- UR Underdrive Crank Pulley (Have to look for)
BS- Gates Belts
BSP- APS 2.5" Test Pipes (Have to look for)
BSP- TurboXS UTEC (Hidden)
BSP- TurboXS Tuner Wideband w/ Bosch O2 Sensor (Hidden)
BSP- Hotchkis Stage 1 TVS Kit (Hotchkis Lowering Springs, Hotchkis F&R Adjustable Sway Bars, Bushings, and Brackets) (Don't know if I could hide)
BSP- StopTech Stage 2 OEM Brake Kit* (StopTech Slotted Rotors, Axxis Ulitmates Pads, StopTech Stainless Steel Lines, Motul RBF600 Fluid) (Can't hide)
* Might run OEM rotors w/ EBC YellowStuff brake pads. (Can't hide the Yellow pad)
Wheels/Tires:
__________________
Old 02-10-2007, 07:49 PM   #9
ULLLOSE
Engine:
BS- Gates Belts
Wheels/Tires:
So you would rather cheat then run in the right class? That is class.
__________________
Old 02-10-2007, 07:54 PM   #10
Robert_K
Robert_K's Avatar
Quote:
No... Just having fun.
__________________
Old 02-10-2007, 08:01 PM   #11
DriveI65
Why would you want to hide modifications and run in B Stock instead of B Street Prepared? That is the car you have built so be proud of it.
Over the last couple of years I've seen quite a few 350Z cars show up with mods like yours and they had a ball running in BSP against each other. Even though stock class was faster.
DriveI65 is offline   Reply With Quote
Old 02-10-2007, 08:11 PM   #12
Robert_K
Robert_K's Avatar
I run Auto-X to race against myself and the clock.
__________________
Old 02-11-2007, 11:09 AM   #13
jun14scr
Points: 3,362, Level: 36
Points: 3,362, Level: 36 Points: 3,362, Level: 36 Points: 3,362, Level: 36
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
Send a message via AIM to jun14scr
k.. then run the legal class. your car is a BSP car! you are missing half the fun if you only run against yourself. Where's the competitiveness in that? We're guys. it's our innate disposition to be better than the next guy. testosterone? all i know is when i get out there, i could care less what my times are.. as long as i beat the guy next to me.
unfortunately that doesn't happen very often! :P
jun14scr is offline   Reply With Quote
Old 02-12-2007, 11:06 AM   #14
Resolute
Resolute's Avatar
Points: 5,234, Level: 46
Points: 5,234, Level: 46 Points: 5,234, Level: 46 Points: 5,234, Level: 46
Robert, this is why I have no mods besides R-comps. B stock is pretty limited. I could swap out dampers, run a cat back exhasut, engine grounding kit and swap my air filter for a drop-in K&N unit, and that's about it. I can't even swap out my rotors to a Track model's Brembos, or use wider Track model wheels. It kinda sucks, but it keeps the cost down and the competition fairly even. Except I gave up on auto-x for Time Trials, better bang for the buck and the Z fairs much better in it's class against those damn RX-8's on a track vs a tight auto-x course.
The mods you have aren't even close to stock, and having seen your ride I can tell you there's no way you're going to hide anything past the tech inspection, much less your competitors. BSP is a fun class, you'll have a ball in it.
If you're really lookinginot doing this, I'd say buy a set of R-comps before PMI and use them for auto-x days and at the track, it will be the single best mod you've done -hands down. Toyo Proxes RA-1 (are the new R888 out yet?) or ADVAN AO48 will get you to and from the track just fine and hold up well for multiple track days and auto-x events. There are others, but these are the two I have experiance with. David Muramoto used the newer Falken Azenis 615 on his B14 racer, they aren't true R-comps but had good turn-in and a nice, easy, transition to break away.
Will
Resolute is offline   Reply With Quote
Old 02-12-2007, 11:21 AM   #15
Robert_K
Robert_K's Avatar
Thanks Will!!! Talking with the wife might hold off on that kit till I get a good (great) paying job. Might get some Work CR Kai 18's, Koni's and maybe a cat-back instead. I'll take a look at those tires. Any suggestion size for my OEM Touring 18's?
__________________
Old 02-12-2007, 11:31 AM   #16
Resolute
Resolute's Avatar
As wide as possible Maybe a 265 front and a 295 rear.
Will
Old 02-12-2007, 11:32 AM   #17
Robert_K
Robert_K's Avatar
Quote:
Will
We'll talk more. Wider = more $$$ Won't be till April/May any how.
__________________
Old 02-12-2007, 11:45 AM   #18
Resolute
Resolute's Avatar
Yeah, pricing sucks like that, LOL. I have no idea what you can cram on those factory rims, but there are lots of guys on this board actively racing on stockers and they'll tell you what fits and what doesn't.
I hear you about the cost, that's why I'm going to PMI on my all-seasons. I can't justify buying new R-comps just yet. So... I'll be sure to wave you by me on the straight!
Will
Old 02-12-2007, 11:45 AM   #19
larson
Default 18'' Wheels
Is it legal to swap to 2007 wheels? I noticed the 07 enthus. now has 8'' X18 front and 8.5''X18 rear. What is the rule on that? I have a 05 Enthus. Thanks
larson is offline   Reply With Quote
Old 02-12-2007, 03:54 PM   #20
DavesZ#3
Administrator
DavesZ#3's Avatar
Quote:
Nope, you have to retain YOUR stock wheels size. Changing sizes bumps you to BSP.
__________________
My350Z
350 Z
Paid Advertisement
Tags
350z, david, muramoto, r888
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
