Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > General > Motorsports > Autocross/Road
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 03-14-2007, 09:59 PM   #1
DRE350
Default Is it possible to use a harness without a roll bar
I've purchased Cobra Suzuka seats and a 5 pt harness and was wondering if anyone has used a harness without a roll bar to attach it to. If you have where are the mounting points?
Thanks
DRE350 is offline   Reply With Quote
Old 03-15-2007, 07:14 AM   #2
z-u-later
z-u-later's Avatar
Points: 2,879, Level: 32
Points: 2,879, Level: 32 Points: 2,879, Level: 32 Points: 2,879, Level: 32
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
Most use a harness bar mounted on the B pillars. Others mount the harnesses on the rear strut bar.
__________________
MY STABLE: 1991 Red Mazda Miata | 1996 White BMW 318i | 1996 Red BMW 328i | 2003 Red Nissan Frontier | 2005 Red Nissan Titan | 2006 Silverstone Nissan 350Z | 2006 Red Porsche Cayenne S
z-u-later is offline   Reply With Quote
Old 03-15-2007, 07:18 AM   #3
12AutoX
12AutoX's Avatar
Points: 2,621, Level: 31
Points: 2,621, Level: 31 Points: 2,621, Level: 31 Points: 2,621, Level: 31
Do a search on this board for "harness bar". That's the only legit way to mount a harness without a cage. Here's mine:
Sparco has them, among others.
You can use some huge washers and eyebolts in the floor/driveshaft tunnel.
12AutoX is offline   Reply With Quote
Old 03-15-2007, 08:31 AM   #4
Stack
Stack's Avatar
Points: 4,175, Level: 41
Points: 4,175, Level: 41 Points: 4,175, Level: 41 Points: 4,175, Level: 41
Today's Activity: 21.7%
Today's Activity: 21.7% Today's Activity: 21.7% Today's Activity: 21.7%
Send a message via AIM to Stack
Do a search for multiple threads on the do's and don'ts (many, many opinions).
I don't think the 350Z is made in such a way that you can mount harnesses without a harness bar. I would NOT recommend attaching it to the strut tower bar... its not made for that type of stress (if you were to get in an impact).
But dude... you're talking about putting a $1800 seat in that car. Why on earth would you want to spend that kind of money, and then compromise your safety with questionable harness mounting?
Find a seat that's half as much, then buy the bolt-in Kirk 4-point roll bar and be done with it.
[EDIT] Just re-read your post (or did you edit it) and see you've already purchased the seats. But still...
__________________
Stacy King (I'm a guy dammit!!) - Owner - Asphalt Ventures
Stack is online now   Reply With Quote
Old 03-15-2007, 08:50 AM   #5
Stack
Stack's Avatar
Sorry, that come off a little harsh...
1st thing is to check with whatever groups you'll be participating with to make sure they even allow harness/fixed seat use without a roll bar. If they do, then its up to you if you want to risk running it that way. Again, plenty of pro/con threads regarding the practice (if you can't tell, I'm one that'll tell you not to do it).
As far as attachment points, its always best to drill a hole, then use backing plates and grade 8 hardware to mount the lap and sub strap belts as per the belt manufacturer's recommendations. There's really no other safe way to do it.
__________________
Old 03-15-2007, 10:57 AM   #6
betamotorsports
betamotorsports's Avatar
Points: 2,510, Level: 30
Points: 2,510, Level: 30 Points: 2,510, Level: 30 Points: 2,510, Level: 30
Today's Activity: 0.4%
Today's Activity: 0.4% Today's Activity: 0.4% Today's Activity: 0.4%
__________________
John Coffey
betamotorsports is offline   Reply With Quote
Old 03-15-2007, 11:49 AM   #7
ChrisLock
There are some other things people should consider before adding "saftey" equipment to their street driven cars. Most saftey gear is designed to work together with other saftey gear. It assumes other apparatus are in place and functioning properly.
*5-6 point dangers: incorrectly installed sub belts(no race seat) = internal injurys, head and neck injurys in rollovers without cage or roll bar, stock seats/sliders are weak, may change position or release while driving or in an incident, resulting in ejection.
*4 point dangers: all of the above + sliding into the footwell in frontal collisions
When something says it isn't for street use, it needs to be installed by an experienced professional, and even then only for track days. Race Seats/harnesses/roll cages are supposed to work together. None of them do their job right without the other two.
If you are doing the occasional auto-X, then harnesses might be ok JUST for the autoX to help hold you in. But if you are doing HDPE or open track, I strongly encourage either going all out on the race gear, or stay entirely DOT.
__________________
Chris Lock
ChrisLock is offline   Reply With Quote
Old 03-15-2007, 11:59 AM   #8
Stack
Stack's Avatar
__________________
Old 03-15-2007, 01:57 PM   #9
z350boy
z350boy's Avatar
YEAH.....what he said ( just no so harsh )!!!
z350boy is offline   Reply With Quote
Old 03-15-2007, 02:25 PM   #10
DRE350
Thanks everyone for their advice and input....even the harsh ones
You've convinced me.
They don't sell the Kirk roll bars here in Oz (as far as I know) so I'm going to a roll cage builder next week to see if he can make one up for me.
Old 03-15-2007, 02:54 PM   #11
tomzz
Points: 3,340, Level: 35
Points: 3,340, Level: 35 Points: 3,340, Level: 35 Points: 3,340, Level: 35
Kirk ships all over the world Their roll bar is the highest value modification you can put on your Z - Do not use a harness w/o a roll bar. be sure and get it padded so you do not break your noggin in a street bump/hit
tomzz is offline   Reply With Quote
Old 03-15-2007, 04:06 PM   #12
DRE350
Quote:
Originally Posted by betamotorsports
Good info. A bit of light reading. Thanks.
Old 03-15-2007, 04:24 PM   #13
12AutoX
12AutoX's Avatar
Maybe next years budget should include a proper seat and roll bar
Those heated leather seats will be missed. The whole idea of a trackable street car is looking more like a streetable track car.
Old 03-15-2007, 04:34 PM   #14
ChrisLock
Building a bracket base that mounts to your stock seat holes is not that tough(have welder, will travel). Then you can run your nice seats on the street, and your race seat on the track. Spending an hour swapping in your race seat and belts the night before is well worth the time and the added safety.
__________________
Chris Lock
Old 03-15-2007, 04:40 PM   #15
first350
first350's Avatar
what do you plan on using the harness for?
I AutoX, and am not worried about crashing or rolling the car (lower speeds, flat surfaces, very few objects to hit)...so I ended up buying a 1.5" X 1.5" L Aluninum bar (1/4" thickness) and cut/drilled it so that it would mount to the rear 2 bolts on the seat frame - it's a straight shot from the 2 rear mounting holes, so no need for custom welding or anything like that. I then drilled the needed holes to mount my harness to the aluminum L. I know that angle of the shoulder straps is not correct, but that only comes into play w/ a collision. (I also do Track events...but I use the OE seat belts for that)
just thought I'd give you one more option...if you're planning to track the car or drive it on the street w/ a harness, then everyone's advice is correct.
*ppl have told me that even with AutoX I shouldn't run my set-up, but if I put a harness bar in, then they'll say that it adds structural support and it's not technically a legal modification....in the end, I'm not worried about b/c the risk of crashing during an AutoX is very very small.
-Peter
__________________
'05 Super-Black enthusiast:
Thanks to all of my Sponsors:
Altered_Atmosphere, Strup, Unorthodox Racing, ZEnclosures , Blue-Batmobile-Overlays, JIC-Magic, Hankook Tires,
click to see more details
first350 is offline   Reply With Quote
Old 03-15-2007, 05:39 PM   #16
betamotorsports
For those weenie protesting autocrossers just make a harness bar that has one tube slide into the other with a tight fit. Make sure the overlap is about three feet. And don't discount the dangers of autocrossing, I saw someone killed in an autocross at the old Lion Country Safari parking lot in Irvine, CA. The driver lost control in a very fast DMod Lotus Elan and hit a light pole.
__________________
John Coffey
Old 03-15-2007, 06:31 PM   #17
MoodDude
MoodDude's Avatar
Wow - Lion Country Safari - I remember going there as a kid, you have sparked some old memories.
This could get into a heated arguement about what is safe and what is not - you need to make you own judgement about what you think is correct and what is not.
I decided to go with the Kirk roll bar with my Suzuka seats, and Kirk builds them correctly with the right geometry, materials, and the fabrication is excellent. They will not build a harness bar due to safety reasons (they believe that if you don't have roll over protection than you shouldn't use a harness) and they don't want you to put the full roll cage in a street driven car since you should never drive in a full roll cage without a helmet!
Here is a picture of my set up:
And Stacy - Cobra seats are not $1800 unless you buy the carbon fiber ones, they are around $500 for FIA approved seat just like the rest of them.
MoodDude is offline   Reply With Quote
Old 03-15-2007, 06:57 PM   #18
first350
first350's Avatar
point taken - I'm not trying to get into a discussion over this, just offering my own opinion and what I've done. we all have to weigh the risks we take.
-Peter
__________________
Old 03-15-2007, 10:32 PM   #19
knight_white99
Welcome to my world, John.
When you get ready to do it, I can help you. I have a Kirk roll bar installed in my car. The hardest part is getting over the psychological pain of having to drill 16 holes in your car...
__________________
Special thanks to sponsors, Rotora, iNTOUCH Computer and Pitstop Performance. Former SCCA National, IMSA and FIA competition licenses, and 12 Hours of Sebring Finisher. Two time podium finisher - Redline Time Attack. Winner - 2006 Silver State Classic, 145mph Class.
knight_white99 is offline   Reply With Quote
Old 03-16-2007, 11:14 AM   #20
Fluid1
Fluid1's Avatar
AdamantMMA
Points: 5,501, Level: 47
Points: 5,501, Level: 47 Points: 5,501, Level: 47 Points: 5,501, Level: 47
Today's Activity: 18.3%
Today's Activity: 18.3% Today's Activity: 18.3% Today's Activity: 18.3%
Can you go into some detail about the Kirk? I have heard that with it in, there is much less room for the seat to be placed (or adjusted)
I have been searching for a suitable cage for quite some time now, and the only place I've been lead is to have a custom one made.
__________________
Like UFC / MMA? http://adamantmma.blogspot.com/
Fluid1 is offline   Reply With Quote
My350Z
350 Z
Paid Advertisement
Tags
autocross, california, country, harness, lion, roll, safari
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
