Thread Tools |
#1 |
CF Hatch And Balance
I want to replace my hatch with a CF hatch and lexan.
My car already has a Greddy TT setup up front which added about 80 lbs up there. More like 100 but I have a 3lb dry CF shock tower brace replacing the heavy stock one. Would removing approx 75lbs from the rear going to upset the balance? I also have removed the spare, jack, carpet etc. A 4 point cage in going in there next to add some weight to the rear and I will relocate the battery to the trunk. Would all these changes end up being a negligeable affect on balance or detrimental?
__________________
Read My Auto Blogs Biches @ http://www.cardomain.com/ride/3083811 Last edited by JETPILOT; 07-18-2008 at 04:39 PM. |
#2 |
Keep in mind the hatch is located quite high in relation to the rest of the car. Reducing weight there should reduce the Zs center of gravity with negligible effects on weight distribution.
Having said that, the changes you're making to your car won't do you any favors if you decide to compete in any organized class. Most likely will place you in unlimited classifications against cars with HUGE HP and changes... |
#3 |
Fabricator
Taking weight out is generally more important then balance, unless you're limited in some odd way by rules. Remember, cars with 65F and 35R weight distributions can be made to get around a race track very quickly.
__________________
John Coffey |
#4 | |
Quote:
My car is so very far from OEM. I agree on the lower CG, but I'm not convinced about the little effect on balance.
__________________
Read My Auto Blogs Biches @ http://www.cardomain.com/ride/3083811 |
#5 | |
I'm Online R U?
do it...
__________________
07 Silver Alloy Nissan Nismo 350Z #0191 "Lin'da" On this road of life there signs...please read them, if not your bound to get lost... ![]() Quote:
#6 |
You do it..... then report back.
__________________
#7 |
You caaannnnnn dooooooo IT!!!!!!
__________________
2005 G35 Twin Turbo Sedan www.performancefactory.com |
#8 | |
Quote:
I can say, that I would certainly like to do it. You'd have to think that it would change the weight distribution %, but not as much as you'd think. Compensate by running a slightly softer rear shock setting or maybe 1 lower PSI in the rear tires? |
#9 | |
Quote:
If you're that concerned about balance, the best way to find out is to locate a local shop with corner scales and the knowledge to use them. After getting baseline figures, roll the car off and remove the rear hatch. You can even add a few pounds in the rear to simulate the lightened hatch and record the new F/R balance. |
#10 |
I believe the lexan glass replacement, though it saves the most weight, will be the mod to put you into really rediculous competition categories. Not sure of the street legality, either, though convertibles run with plastic rear windows. Moving the battery won't make much difference, seeing as it is already close to the middle, on the passenger side to balance some of the weight of the driver. The roll cage should help balance things out though, as you mentioned.
#11 |
Why not CF doors?
#12 | |
MY350Z.COM ![]() |
Quote:
It's a very expensive area to run, and going against Ultimas and Radicals can be frustrating. Just keep that in mind.
__________________
Marty Howard President Triangle Z club Track Events Logistics Coordinator TZC/THSCC
#13 |
hey Jet are you planning on competing with your car or just continue
doing track days? i think a lot of the members are getting that impression from what i am reading but i have not gotten that from our previous discussions. I forgot to ask before, but is this car your daily driver? mine is but i do not have half mods that you do.
__________________
#14 | ||
Quote:
Quote:
My car is not a daily driver. It's just not a comfortable car to drive around anymore.
__________________
#15 |
i have a 5 point rear roll over bar (weld in), cf hatch, but stock glass, pretty much the same setup as you Jet, but obviously not as powerful :P (but i probably have more carbon than you!)
i had the car corner balanced when i did my alignment. i didnt notice that much of a balance difference, the scales said i'm 53% front, 47% rear weight distributed, with me in the seat. car feels good.. during acceleration, probably would shift more to the rear, getting close to 50/50.. i would say lexan and cf hatch would be negligible for your z.
__________________
Cheston |
#16 | |
Quote:
Do you remember what it weighed? I'm just curious.
__________________
03 SS Track-Nismo/TC Kline/SPL/Cusco/every bolt on. |
#17 |
Hit up member "SpoilsofWar" he's turbo'd with a CF hatch and Lexan.
__________________
13.8 @ 101 completely stock. Auto-x extraodinaire. 260whp/242lb ft Dynojet - Utec, Nismo catback, test pipes = 98 decibels |
#18 | |
Quote:
im getting re-corner balanced/aligned next week (hopefully) i'll post the specs up. i've added stuff since last time-
__________________
Cheston |
#19 |
Thak you for the information!
__________________
#20 |
Jet, a few things come to mind....
If you are going to go with big HP and run the super unlimited, you will need to lighten the car as best you can. CF doors, CF fenders, CF hood, CF trunk, lexan, drop the entire interior, etc. If you are going to lighten the car up and run big HP, get a NASCAR style cage. You are entering an area with your car that can bite you with only a very little mistake. I have driven a Z such as yours and say this from the heart...don't skimp on the safety stuff with that kind of performance. You may not live to regret it. It's not the HP that kills you, it just can kill you faster. If you are lucky, you only end up If I am reading correctly, you are an HPDE'r and have not actually raced yet. I REALLY suggest you think about starting with less HP before you crank it up to that level. Remember the saying "you have to slow down to go faster?" It applies to the learning curve, too. Figure out what class you want to run before you dump a ton more money in the car. You may find you built a car that won't compete and has a very limited area to run in. I have seen a lot of people build a car that is just useless and then spend just as much making what they should have in the first place. One suggesting I have is endurance racing. It's more about car preservation and consistency. Don't get me wrong, you're still hauling ass, you'e just not at full tilt the whole time like a sprint race. I think they are great and every racer should try them. Some try them and don't go to sprints again. lastly, you are entering the point of no return with the streetability of the car...even for weekends. With the mods you are doing and where you are going with it, you really should decide if you want to drive it on the street anymore. Oh, something to think about, CF parts are not designed for street use due to their make up and their ability to stand up in a crash. Again, think about your safety level and what the car is really being built for. Just some things I think are important. GL with whatever you choose to do. Last edited by Fooshe; 07-23-2008 at 07:44 PM. |
| Thread Tools | |
