Thread Tools |
#1 |
What do you guys know about LSD's?
Here's an interesting article about LSD's:
http://www.guardtransmission.com/velocity.htm Sorry it's mostly geared towards rear engined Porsches, but I found the article very interesting, and it confirms how little I understand about how these units affect handling. FYI, I went from the OE viscous unit to the Cusco RS set at 1.5 way and 80% locking. I think Porsche would call this a 80/40 LSD setting (80% locking under acceleration/40% locking under deceleration), which seems to be vastly different than what they spec their track/race cars with (45/65, 50/80, and 80/80). A couple things I noticed when I upgraded to the Cusco unit: 1. More consistent lockup on exit, especially noticeable on sharper turns. 2. More understeer on throttle application. I'm trying to find a way to reduce the amount of understeer with alignment/sway bar adj/different springs/track width as I'm already running a square tire setup. 3. Very stable off throttle and under braking. In fact, the car no longer responds to throttle steer. I'm also considering changing my driving style a bit to take advantage of the cars resistance to off-throttle spinning like braking further into turns. |
#2 |
Good read, thanks for sharing.
Once you get the suspension dialed in, post up your specs and settings! I'm sure your lap times will improve quite a bit.
__________________
"I'm running a springless setup with single adjustable length pressurized air damper. Five free castors (plastic wheel with steel axle) and free center support axis. The body has adjustable height arm rests, adjustable tensioned back support, and short throw height adjust lever. Lately I've noticed my wheel bearings starting to go, but I can still get a solid 8 rotations if I tuck my legs in." |
#3 |
Fabricator
Power on understeer means you need to increase grip in front.
__________________
John Coffey |
#4 | |
Enthusiast
Quote:
Try to increase the amount of negative camber you are running up front as well, if you have not done that already. -2.5 degrees might be a good starting place.
__________________
http://forums2.freshalloy.com/showthread.php?t=145627 http://www.youtube.com/watch?v=r5Tz4WZPjp0 It has nothing to do with taking it to the edge. It has everything to do with keeping it there. |
#5 | |
Z freak
Quote:
#6 | |
Z freak
Quote:
#7 |
I suggest you take yours apart 3 times like I did to change settings
![]() One thing that helped me realize the effects of a limited slip was driving on track in the rain. I really felt the on-throttle understeer with the limited traction of the front tires. Perhaps the 45/65 numbers the article (that I haven't read) refer to are ramp angles. BMW's commonly use ramp angles of 30/90 to tame understeer. It's a different feel than our lsd's in that it takes much more torque to get to full lockup. Different ramp angles are the equivalant to a 1 / 1.5 / 2 way as the japanese lsd's. I'm sure different platforms work better with different ramp angles and breakaway settings.
__________________
NASA TTC 350Z - Team Z Car Garage : NASA TTB champion 2006; TTC 2nd place 2007; 2007 Instructor of the year. |
#8 |
nice info, thanks for the post
__________________
KJR pulley, motordyne 5/16 spacer, rogue short shifter, all amsoil fluids, JWT popcharger, 350evo sways, AAM ypipe, helix tps, UTEC, Tokico HP blue, Tein S |
#9 |
Enthusiast
IF you are going to be running NA, and go to the track only occasionally, you might want to consider a torsion sensing (Torsen) screw type lsd. They are very quiet and smooth, and thus in daily driving applications very civilized. The clutch type mechanical lsd unit, like a Cusco or Nismo, is a "bad boy" that will chatter and chirp and grab in slow speed tight turns in parking lots and intersections. For the hard core high power application, however, I would not recommend it. Quaife makes a nice unit that fits our cars, if that is of interest.
__________________
#10 |
Fabricator
OS Giken also make a nice clutch pack unit. Its very adjustable (out of the car) and has two basic settings - S (Standard) that has a lower preload for street driving and another setting (don't know the term) that is more race oriented. The diff is basically a 1 or 1.5 way but that's completely adjustable.
I'm running one in my 350Z at the race oriented setting and its much smoother in power application then the Nismo unit I ran previously.
__________________
John Coffey |
#11 | |
Quote:
I've been very happy with the engagement of the Cusco RS unit. Yes, the tires chirp in slow sharp corners, but the unit doesn't chatter. It might be due to the WPC treatment of the clutch discs prior to installation. I'm also running the Motul 90PA fluid. When I was using the Valvoline High Performance Gear Oil, the LSD was a bit more jerky. I've upped the front-end negative camber from -2.6 to 3.0 to see if I can get a bit more grip out of the RA1 tires. The rear seems to be gripping and wearing well at -2.2 camber. We'll see how it goes this weekend. If the changes do not work, I'll stiffen my front Hotchkis sway bars from med to stiff. This step puzzles me because it should technically decrease my front end grip, but a few respectable individuals have had success with running a stiffer sway setting up front. If that doesn't work, I'll increase my rear ride height to add some rake into it. It is currently adjusted for equal static height as measured from the ground to the chassis seams. I'm thinking that rear squat under acceleration is causing the rear end to be lower thereby adding a bit of front end lift under med/high speed corners. OE calls for a slight rake (~1/2" higher in the back). The car exhibits a nice 4-wheel drift on slower corners (ie T14 at Thnderhill), so maybe aerodynamics is coming into play here. If that doesn't work, I'm going to increase my front springs to ~600#. This step comes from a Carrol Smith book, AND it works well for daveh. If that doesn't work, I'll add a front splitter. And, if that doesn't work, I'm going to take Daveh's suggestion and take apart the LSD to change the settings --->60% locking (eek!). This is my last step because it seems that rear end grip is very good, which is causing front-end problems....but in the end, I prefer a balanced and well sorted car over one that has the more overall grip but pushes. G35Sedan is right, and I'm using OTS Koni Yellow with Tom Motorsport springs (500/500). These spring rates are 'published', but not verified. I'm maxed out on rear end rebound, but have some more rebound adj on the front if I need to add more. |
#12 |
What Carrol Smith book are you reading this from, I saw he had a few. On your cusco Rs, how hard is the install and changing settings on it.
__________________
KJR pulley, motordyne 5/16 spacer, rogue short shifter, all amsoil fluids, JWT popcharger, 350evo sways, AAM ypipe, helix tps, UTEC, Tokico HP blue, Tein S Last edited by mw9; 08-18-2008 at 12:03 PM. |
#13 | |
Quote:
the first I'll try would be to soften the sway bar. even before touching height, springs.... my cusco is at 100% and I have a pretty nice push.. but as I put a stiffer springs in the rear it's working better... than I made the mistake of lowering the front... more understeer.. so, put the rear at the same height... better. if you have aftermarket swaybars I'd try also to lower the front camber a little bit.. (back to -2) maybe you just can't "load" the wheel before having that angle start working. for me is working pretty well for the added stability.... brake more into the corners, go to the apex a little bit later and than use the full traction to exit as a rocket and is incredibly easy to control if the rear gets a little loose in 3rd gear.
__________________
Magnetic Black Nismo Z #867... cusco RS 1.5 100%, berk metallic HFC, alpine ida x100, pdx 2-150, focal k2p, concealed V1, hks hypermax 3 sport, JIC spartan Ti, more stuff coming
#14 | |
Quote:
#15 | |||
Quote:
Quote:
Quote:
#16 |
I also have the Cusco RS 1.5way @ 80% lock - I absolutely love it! I run BSP for autoX, so my application is a bit different compared to track days...but I would say it's been one of the best additions to my Z - I only wish I did this as my first mod rather than my last!
*if you're worried about understeer, go w/ a 295 R-comp up front
__________________
'05 Super-Black enthusiast: Thanks to all of my Sponsors: Altered_Atmosphere, Strup, Unorthodox Racing, click to see more details
#17 | |
Enthusiast
Quote:
__________________
#18 | |
Quote:
__________________
http://thecarspace.com/Teatang |
#19 | |
Quote:
I run a F295/R315 for autoX...I would assume that on a track, I would have slower times b/c the gain in grip for the corners would not out weigh the penalty in the straights.
__________________
#20 |
I wasn't totally serious about taking apart your lsd. 80% should be good for track use. I just wanted someone to feel my pain
I think you're on the right track beginning with camber (and making only one change at a time). I'll be at the track this weekend and can help you take some temps to attack this more scientifically. I can bring some of my spare front springs too if you really want to get dirty. Also after reading your complaint about push upon throttle application, this describes understeer from apex to exit - correct? A little of this is ok in my book unless it's too excessive since it's happening in the unwinding phase of the turn.
__________________
NASA TTC 350Z - Team Z Car Garage : NASA TTB champion 2006; TTC 2nd place 2007; 2007 Instructor of the year. Last edited by daveh; 08-19-2008 at 11:44 AM. |
| Thread Tools | |
