Thread Tools |
#1 |
Changing from staggered to square setup (A noobs experience)
So I'm going to try to explain my thoughts/feelings about going from the OEM staggered setup to a square setup. Please keep in mind that this is my first season auto-xing, track driving, anything. Hell, I just got the car in April. So I may be wrong on some of my assumptions.
I've been to about 4 or 5 autox's this past season and 3 HPDE events. Up until my last autox and my HPDE yesterday, I was running on the OEM 225/50/17 (FR) and 235/50/17 (RR) setup on stock RE040's. I knew this setup gave me some understeer and to be honest it felt comfortable. At autox's I felt significant understeer, but that could also be because I was going into the corners too hot. But on the track, I felt I could turn the wheel harder in corners and even if the car began understeering, I could add some oversteer just by control of the throttle. Overall it felt comfortable. Last month I switch to 255/40/18 Falken Azenis 615's all around on 18x8.5 Track rims. Immediately I noticed how much less steering angle I needed to make normal stop light turns. Now to performance driving: For Autox's, I noticed the car had better response ( may just be due to better tires and wider footprint), I also felt the car was very predictable like most people say. You could definitely start feeling the rear come loose and be able to control it with throttle. It was also easier to control if you entered a corner too hot. So for Autox's I give the square setup a thumbs up! For tracking driving, I had a completely different experience. So I've only been going to our local track this season, and I've developed a good rhythm with the car. In the past I'd be able to push the car pretty hard through each turn and pretty much be one of the fastest in my group. Yesterday I attended a HPDE with my new setup and it was not comfortable at all. Maybe it was me, but I felt the car was very unstable, and I was very uneasy driving it. Turns where I'd have to slowly increase my steering angle felt scary cuz I would think the rear end was coming out all the time. And there was even one time where I had throttle on oversteer and almost lost it but that was just bad driving. Even my instructor (who is a Porsche cup car racer) mentioned he could tell I knew the lines, I knew exaclty when to turn it and when to apex. But it seemed like I would input an action but not know how the car would react, which was true. So I guess i'm trying to say/ask a couple things. 1) Is this normal? Do I just need to get used to the car again? Cuz where I would normally be passing people, I was getting walked all day. Maybe I just suck. 2) How do I improve on this? 3) I've noticed a lot of the pro drivers running staggered setups, maybe I should go back? I definitely like track driving more than autox. 4) For all the people dumping all these mods into their cars, be careful. All I did was change my wheel/tire setup and the dynamics of the car totally changed. This is a good reason why people should get as much seat time as possible and learn about their car before doing mods. I was gonna do swaybars and coilovers in the winter, but now I'm a little hesitant cuz I don't even feel comfortable with the car now. Thanks. Lesson from the day: I want a Porsche 996 GT2. Those things are balls fast!!!! |
#2 | |
Fabricator
1) Most likely its normal and you're just not used to a neutral (not oversteering) car. A balanced tire setup on an otherwise stock 350Z does NOT change the balance into an oversteerring balance. It reduces the existing understeer and makes the car closer to neutral.
2) Learn how to drive the car with its new balance. 3) You're not a pro driver, ignore what they are doing with their car setups. There are lots of reasons (rules, sponsorship, driver preferences, power upgrades) that may require a staggered setup. You're not in that situation. 4) Track time and instruction will make you more comfortable. You're heading in the right direction regarding car setup. EDIT: Quote:
__________________
John Coffey |
#3 |
Regular
My square setup (275/40-17 RA1s) is a little "loose" at times...but I use that to my advantage. And I adjust that with tire pressure changes and Sway Bar adjustments...to change behavior.
I currently run my rear sway bar on max-soft, the front bar is one-hole up from full soft...and normally run a 2 lbs lower rear tire pressure. However, This is still a little on the loose-side, but great for HPDE, and just having fun. But I have now gotten into Time Trials, and will go back to a stagered setup, 275/40-17 and 295/40-17 running Kuhmo 710s. I think this will give me that extra traction/comfort when driving at 100% and more overall speed. Note: I have the Hotchkis TVS kit, that has adjustable sway bars, and SPL F & R Camber arms, but still run stock shocks.
__________________
Time Trials today, W2W when my kids get real jobs Last edited by laze1; 08-15-2008 at 02:46 PM. |
#4 |
Enthusiast
Your reaction sounds pretty normal the way you describe it.
My first step up in tire and wheels was for a square set up, with 275 all around and some more aggressive front negative camber at -2.5 degrees. Took it out to Buttonwillow, California and ran #13CW and the difference over the stock 225F/245R was jaw dropping. The wider grip and neg camber up front had the car biting into the turns where before it was pushing, and I began experiencing a lot more rotation of the back end. That totally changed where I had to get on and off throttle, the driving line in the corner entry phase.....I was a mess the first few laps trying to survive. And yes, slower. But after a few sessions, hands down faster, several seconds a lap in fact. The next iteration was more power, and the need to get more grip in the rear to hook it up. So.............back to a stagger set up and 275F and 315R. And back to school again. Hang in there, drive it some more, and I think you will find that you will ultimately be quite a bit quicker with it once you get more comfortable with knowing where the edge of control lurks.
__________________
http://forums2.freshalloy.com/showthread.php?t=145627 http://www.youtube.com/watch?v=r5Tz4WZPjp0 It has nothing to do with taking it to the edge. It has everything to do with keeping it there. |
#5 | |||||
Quote:
and it's going to be a little steeper learning curve because the car full potential is just increased. Quote:
Quote:
Quote:
have more track time, have FUN! that's the important part... have your quota of turn sideways, spins and you'll be more confident Quote:
__________________
Magnetic Black Nismo Z #867... cusco RS 1.5 100%, berk metallic HFC, alpine ida x100, pdx 2-150, focal k2p, concealed V1, hks hypermax 3 sport, JIC spartan Ti, more stuff coming
#6 |
a couple things to keep in mind:
as track speeds increase, a neutral car will become loose (and scary), and a car that understeers at low speeds will feel just right. make sure your tire pressures aren't too high after you get your tires hot at the track. azeni's get a little greasy when too hot. if tire pressures check out, then it's just a matter of getting more seat time. |
#7 |
just need more time on the setup to get comfortable rotating the car. sometimes properly rotating the car can feel like youre throwing it almost out of control depending on the turn. Some adjustable sways could help dial out a little on-the-limit oversteer and also hitting those azenis with water after every session will help keep them from getting greasy and loose.
__________________
06 Base. back from rehab and no longer addicted to oil :] |
#8 | |
Fabricator
Quote:
Well... let me quality my statement. Its not true unless there are aero changes to the car's balance. A car's velocity has little affect on balance until the driver does something inappropriate at the higher velocity (turns the wheel too fast, stomps on the throttle, slow in corrections, etc.) As speeds increase, driver inputs need to be more subtle and quicker.
__________________
John Coffey Last edited by betamotorsports; 08-15-2008 at 03:48 PM. |
#9 |
What tire pressures were you running? I've got the same tires as you do (with the exception of 245 in front) and the car feels very balanced. I keep the tires at 38f/36r (hot)
__________________
"I'm running a springless setup with single adjustable length pressurized air damper. Five free castors (plastic wheel with steel axle) and free center support axis. The body has adjustable height arm rests, adjustable tensioned back support, and short throw height adjust lever. Lately I've noticed my wheel bearings starting to go, but I can still get a solid 8 rotations if I tuck my legs in." |
#10 |
Yea I agree with everybody with the fact that I need more seat time. Somebody said that the cars potential increased with the square setup? Is that true? Is the only reason people run staggered is because of the large amounts of horsepower?
And I definitely felt the azenis get more slippery towards the end of each session. Maybe these are better autox tires than road course tires. As far as tire pressure goes, I wasn't playing with that because I wanted to get a full understanding of my setup first. I was at 38f/38r hot. Next time I'll probably drop the rears a bit like Slow*Jim to get some more rear grip. |
#11 | |
Enthusiast
Quote:
Some skid pad time would be a real good idea. Just get it going in a circle and find out where it starts sliding, do some weight transfer exercises, play with triggering throttle on and throttle off oversteer. Try a corner until you push, then do some brake into the entry to load up the front a tad and take it the same velocity and see if you can get it to bite and take a set where before you were pushing, just from controlling weight transfer. Just make some smoke. Then track it again. And try starting out with your psi at 30 cold. If you are more than 36 hot, draw it down just a skosh. This is fun stuff. Enjoy every moment of it! Cheers, Ed
__________________
#12 |
Geez Rob, way to write a novel on this!! Glad to see you getting the hang of the Z.
Slow*Jim, what's up? Ross here. When are you letting missy drive your car? Just so i know to stay very far away from the course that day
#13 | |
Quote:
Ross! Hey man! She thinks she is driving it tomorrow but I just tell her that so she doesn't dump me You need to come out to a NASA HPDE some time!
__________________
#14 |
I'd bet at least some of it is the fact that the 615 is easy to get to change from grippy to greasy vs the overall-lower-grip-but-harder RE040. Also check your tires pressures (likely too high?) - seems pretty normal reaction / behavior tho...
#15 | |
Quote:
#16 | |
Quote:
__________________
Sure therapy, but screaming obscenities is cheaper. |
#17 |
MY350Z.COM ![]() |
Remember that the OEM understeer setup is placed in there for safety and driver comfort. Most people are more comfortable with a car that pushed and scrubs off speed on it's won vs one that is loose and has a lot more rotation. It is a learning curve, and one that well all have to do if we change anything fundemental on the car we are use to driving.
But over all a loose car will be quicker once the driver is use to it and can properly rotate it. It will mean that you will have greater slip angles and at each corner exit you will be pointed in the right direction sooner allowing you to apply more throttle sooner. Just have fun with it and slowly increase the spped back up. And have fun with it. I find a looser car to be more fun after a while. I good friend of mine once said "I tight car scares the driver and please the passenger, a loose car pleases the driver and scares the passenger".
__________________
Marty Howard President Triangle Z club Track Events Logistics Coordinator TZC/THSCC
#18 |
I think I see what you mean Marty. I can see a very experienced driver throw a neutral car into a corner faster than one with understeer. But for me to get to that level will take years. Oh well, this is only my first season and I'm pretty young (23) so I should have a lot of time ahead of me.
As for everybody commenting on the 615's, maybe they're a better autox tire than road course tire? My next tires will probably be R-01R's There's a lot of really good info in this thread regarding what some ppl are saying about turn in points changing and such that I'll have to read more deeply to understand it all. And I think Ed's idea of playing on a skidpad is an excellent idea to get an understanding of the vehicle's new dynamics. I've been trying to use autox courses for that, but it's totally killing my road course smoothness. So where am I gonna find a skid pad......... Last edited by AznSky; 08-18-2008 at 10:07 AM. |
#19 |
MY350Z.COM ![]() |
I wouldn't be so sure it will take you years. It's just a matter that you are driving an almost a brand new car, so it will take some getting use to, especially one that isn't tuned to OEM specifications.
As far as skid pads, a lot of track day groups and HPDE's are now offering optional skidpad time, so I would check with the organizations you tipically register with.
__________________
#20 | |
Quote:
| Thread Tools | |
