Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > General > Motorsports > Autocross/Road
Old 08-17-2008, 11:35 AM   #1
mw9
mw9's Avatar
Rear end questions
Those who are big into autox and roadracing, what LSD do you guys recommend and have the best luck with. I do autox now and would like to get into some roadracing next year. Also, would changing the gears to a 4.09 be a good idea for roadracing and autox. Over the winter I would like to build the rear end up, just want to start doing some research now. Thanks for any info.
__________________
KJR pulley, motordyne 5/16 spacer, rogue short shifter, all amsoil fluids, JWT popcharger, 350evo sways, AAM ypipe, helix tps, UTEC, Tokico HP blue, Tein S
mw9 is offline   Reply With Quote
Old 08-17-2008, 02:59 PM   #2
Enthusiast
Eagle1's Avatar
IF you stay NA and use this car a lot as your DD, then you might consider a torsion sensing ("Torsen") type unit like the Quaife lsd. Very smooth and civilized, but the folks I know that have run hard on a track with them have had them break.
If you run FI, and drive aggressively, then a mechanical clutch type such as Cusco, Nismo, Kaaz, etc. would be worth your time for investigation. They will chatter, chirp and jerk in parking lots and sharp, slow speed turns from stop signs....but on the track they are smooth music.
__________________
http://forums2.freshalloy.com/showthread.php?t=145627
http://www.youtube.com/watch?v=r5Tz4WZPjp0
It has nothing to do with taking it to the edge.
It has everything to do with keeping it there.
Eagle1 is offline   Reply With Quote
Old 08-17-2008, 07:06 PM   #3
ke0ki2k's Avatar
Quote:
4.08's are worth it if youre on street tires, but if youre on R-comps you'll be against the rev limiter too much in autox (besides that it puts you into Street Mod 2...got to run against an insane RX-7 with a gigantic wing today). just ran at Nashville today with a 55.6 fastest time and a 55 flat wouldve been easy with my stock 3.54 gears...I was pegged against the limiter in at least 5 different areas of the course
I'm running a Cusco RS LSD and its awesome for autox...never get any inside wheel spin, really does a great job of putting the power down.
__________________
06 Base. back from rehab and no longer addicted to oil :]
ke0ki2k is offline   Reply With Quote
Old 08-17-2008, 07:26 PM   #4
Lead farmer
Kirk Lazarus's Avatar
If it's your DD or if you drive it a significant amount, 4.08 gears might be a bad choice.
Keep in mind that on a tight autox course that reaches speeds anywhere from 5 to 40+, you're probably going to be shifting a bit more.
Just my 2 cents.
__________________
Ben
Quote:
Originally Posted by stud_daddy
Pretentious tough-guy avatar picture, owns a sports car, fantasies of people's moms ....... you do realize that you do fit the profile of a small-town, pint-sized male with an ungratifying small penis ...... and you know it don't you?
Kirk Lazarus is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
