Thread Tools |
#1 |
Help with setup.
First of all I hope to meet a few 350z owners in the near future, as me (the co-driver) and the owner of the car that I am driving will start to attend more national events starting next year. We are both 350z owners but mine is a little limited (5at). We want to prep the car for BS and yes that is going to be a very tough class to compete in. Just being able to run with some of the top BS drivers will be awesome in itself. Although I am all for the move to FS is that ever gets proposed
![]() We will be driving a Brickyard 03 Enthusiast. So far he has taken the muffler off for events, kn air filter, and 275 kumho's on the stock 17's. Right now I am trying to gather info on what has worked and what hasn't. Right now shock/struts and a front sway is going to be on the list next followed by wheels. The cobb sway bar has caught my attention but I see that most are running the hotchkis. I also see that most are on the koni's, while that is proven, i'm sure we will go the koni route. But we are still open to others. I'm sure alignment we will have to play with, to suit our driving style. But I am also open to alignment specs. So far the only ones I have found are pretty close to stock specs...The car will be a street car and will drive to events but other then that it will not drive very much, so that will open a little more aggressive alignment... I'm sure I am missing a lot. I am also open to good/bad comments, anything that will help ![]() Oh and we will be at the tri-state event for Arkansas/Tennessee/Mississippi... Now I will continue my searches on this forum and others
#2 |
My settings (which placed 10th in Topeka last year, and was basically what was used this weekend):
* Hotchkis 34mm hollow FSB, set to full soft * Koni double-adjustable shocks set equivalent to 2.5 turns from full soft front, 1.5 turns from full soft rear (we were up to the equivalent of 1.75 turns in the rear which made the car a bit more "nervous" in the rear, but keeping co-driver happy was important). The DA shocks are good when I have to set up for rain, otherwise the single-adjustable are OK. * Stock alignment ('05 suspension, '03 should be very similar but will eat your street tires a bit more) * Stock exhaust -- the weight of the muffler/resonator is in absolutely the ideal location (low and at the rear where the car is already a bit "light") * 3/8 tank of fuel (between 5/16 and 7/16 is OK, 3/8 is ideal on my car) * For tires, you'll probably be looking at 275/40R17 DOT-R tires (Kumho V710s for longer wear or Hoosier A6s for a *very* limited number of runs per set) * Wheels - Enkei RPF1 in 17x8. |
#3 |
can ya run a non-stock sway in BS? myself i have no clue, just always wondered that. I thought between the sway and shocks that would put ya in BSP or T1
__________________
Bill R. a few add on's, but we can sort it all out on the track ![]() ---Special Thanks to http://ProjectAutoSalon.com & http://My350Z.com
#4 |
Stock - front Sway, intake filter element (OE style), cat-back exhaust and shocks are open...that's about it.
__________________
'05 Super-Black enthusiast: Thanks to all of my Sponsors: Altered_Atmosphere, Strup, Unorthodox Racing, click to see more details
#5 |
whats your record at national tour/Pro-Solo this year first350?
Hotchkis/Cobb sways are virtually identical...one is red one is blue. If youve got big money and you guys are really anal about how the car handles you can always get Moton double/triple adjustables. I dunno if triple adjustables with the seperate slow/high speed compression is really necessary for autox applications though.
__________________
06 Base. back from rehab and no longer addicted to oil :] |
#6 | |
Quote:
__________________
2005-2006-2007-2008 SCCA BS Natl Champ |
#7 | |
Quote:
Wow! did not know that. btw anybody know why moton clubsport D/A's are twice the price of TC Kline Koni D/A's? other than the external reservoir?
__________________
#8 |
Thanks for all the input so far. The hotchkis/cobb sway bar are identical on other cars too...thanks for reminding me about that
![]() Did I mention I'm a former rx8 owner LOL.... |
#9 | |
Quote:
Packwood is large enough to run the side-by-side style ProSolo, but that means the courses are on the order of 30s - R/T's will be a larger factor...I better start practicing my launches!
__________________
#10 | |
Quote:
__________________
06 Base. back from rehab and no longer addicted to oil :] Last edited by ke0ki2k; 08-20-2008 at 05:44 PM. |
#11 | |
Quote:
__________________
#12 | |
Quote:
__________________
#13 | |
Quote:
__________________
#14 | |
Quote:
I also spent several years tuning car setups before I started autocrossing (something that most people don't know about). |
| Thread Tools | |
