Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > General > Motorsports > Autocross/Road
Old 08-26-2008, 03:29 PM   #1
Chebosto's Avatar
rocks stuck between caliper and wheel.. any prevention?
i probably know the answer to this question.. but just throwing this out there..
from a recent stint at Streets of willow.. 3 of my 4 wheels (my beloved RE30s none-the-less ) now have grooves shaved into them thanks to pebbles/rocks stuck inbetween my calipers and the barrel of the rim...
prbably just one of my bad-luck cases.. but anyone else suffer the same problem? i guess just live with it?
__________________
Cheston s Sponsors: TechnoSquare Inc., StopTech, Cosworth, Toyo Tires, OS Giken USA, KW Suspension, Motul, GT Spec, HAWK Performance, B&M Racing, Performance Nissan, Rays Engineering, Finishline Autocraft, M-Workz. Special Thanks to: Z1auto, Status Auto Design, Intense Motorsport, HKS, Alex@Phase2MotorTrend, Alex@BattleVersion, and Sharif@ForgedInternals for their continued support. All your trunks belong to us: Join the Salad Bar Club.
Chebosto is offline   Reply With Quote
Old 08-26-2008, 03:37 PM   #2
consigliere
UnderPressure's Avatar
don't run off track. that's about the only advice. get better tires/brakes/driver
UnderPressure is offline   Reply With Quote
Old 08-26-2008, 05:04 PM   #3
Chebosto's Avatar
1. didnt go off track at all
2. r888 , stoptech 6piston/4piston 355mm kit on hawk race pads
3. billy johnson driving.
__________________
Old 08-26-2008, 05:40 PM   #4
Billhyco's Avatar
sounds like the wheels may have been squeezed on there a little tighter then normal. get a bigger clearance rim
__________________
Bill R.
a few add on's, but we can sort it all out on the track
Billhyco is offline   Reply With Quote
Old 08-26-2008, 07:10 PM   #5
Possibly put something on the caliper (strip of rubber, thick tape, etc.) that will fill the space between the caliper and rim to prevent rocks from getting in there but is soft/flexible/spongy enough not to cause drag/wear on the rim. Of course, you don't want it to melt either.
thinking is online now   Reply With Quote
Old 08-26-2008, 07:33 PM   #6
Enthusiast
Eagle1's Avatar
Billy is a superb driver. He took my car around Streets in 1:23 and change. If he did not go off and you got scoring on your rims...........are you sure it is pebbles? Did you look at the calipers carefully and determine whether they might have been making contact themselves with a distortion/flex of hub and wheel under extreme cornering pressures?
Let me ask a question. Assuming you were running clockwise full course with the bowl and the bypass........was the wheel unscored the inside right rear? Was the worst the front left?
__________________
http://forums2.freshalloy.com/showthread.php?t=145627
http://www.youtube.com/watch?v=r5Tz4WZPjp0
It has nothing to do with taking it to the edge.
It has everything to do with keeping it there.
Eagle1 is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
