350z wheel offset
on
350z wheel offset
Hi guys ,
was over a discussion with a friend that he was saying that the front wheels of any car should always be wider than the rear to make it turn easier . is this right?
So what if the rear track is wider than the front..... assuming non-staggered setup ( 255/40/r18 +30 , wheel is 18x9.5 all around)
how will this affect the handling of the 350z , cause my front wheels sits flush but my rear is tucked in around 30mm , i thought of putting the H&R 25mm track spacers at the rear.
car is for autocross use.
thanks a lot
thanks a lot
that is not true for one, and second offsets are not the only thing that determine the track width. you would need to see what the car started out with f/r track width. the spindles could be spaced farther out further in the front, making even the same offset on the front and rear not make the track width even. and also, width of the rim and tire size affects this as well.
a wider front track makes the car (all things being equal) want to oversteer and a wider rear makes it want to understeer. so you can modify the track width to effect a change in the handling based on what you notice.
on
Originally Posted by JGTC_350z
Hi guys, was over a discussion with a friend that he was saying that the front wheels of any car should always be wider than the rear to make it turn easier . is this right?
on
would you guys run the H&R 25mm trak spacers for track usage?
Motormouth: thanks a lot , so at least now i know my friend is BS'ing me =) .
again, widening a track is almost always a good thing, gives the car stability and increased lateral grip. it looks really cool too. but at the same time, it CAN mess up your balance. I don't know how much of a change it would take to actually notice a problem though. there are some real experienced guys here who might be able to point to some reference material for you though.
I can imagine if you kept the front at a 8.5 +30 and went to a 10.5 +20 rear you could have some issues with push and you can probably fix it in other ways (camber, tire sizes), but the cause for the change could have been the change in track width.
it is a very interesting question that you are posing and I bet some race alignment shops could help you out. maybe talk to whoever you are going to have do your alignments and tuning.
Originally Posted by scotts300
A correct set-up will not need any spacers. You can run 17x10s at all 4-corners with 295FR and 315RR, 275FR and 275/295RR, etc., etc.
Originally Posted by Motormouth
I don't think he mentioned what offsets his rims are. he might not need to mess around with the offsets at all.
seagrasser
10-11-2015 03:27 PM
