The Tire DB - Posts about Track and AutoX tire brands
Old 04-24-2008, 07:06 AM
  #141
07JimmyZ
07JimmyZ's Avatar
^^^ any updates? how is the RE01R's on your setup? i'm kinda confused dave, on the first page you say that you are not running a staggerd setup for autox, but on this page you say that you are running the 03-05 track wheels which our obviously different widths 8-8.5. i'm assuming you are just running the same tire on both widths? I should be getting a set of 03-05 track wheels early next month and I'll be doing the same as you, wanting a good set of street tires so I can drive to the track and back without having a trailer.
Old 04-24-2008, 08:18 AM
  #142
DavesZ#3
DavesZ#3's Avatar
Didn't mean to confuse you - the tires are not staggered. Wheel size really doesn't mean much especially since there is only a ½" difference.
I haven't gotten the RE-01s yet but from what I saw at the recent Divisional event, they are pretty popular and seem to have performed very well. I'm waiting until after June 1st to buy them. There is a rebate offer in the current SCCA magazine for $100 off a set of them but it doesn't kick in until 6/1/08.
Old 04-24-2008, 09:03 AM
  #143
07JimmyZ
07JimmyZ's Avatar
cool thanks, I noticed that on tire rack it says for the 265/45/18 the rim width range is 9-10.5, wouldn't mounting that be a problem on a 8" rim? wouldn't that also bulge out and cause excess rollover? or would you want that for a better contact patch? sorry for all the questions, just trying to understand and learn.
Old 04-24-2008, 09:46 AM
  #144
z-u-later
z-u-later's Avatar
265s are fine on 8"-8.5" rims. I've mounted 275s on 8" rims before without issues.
Old 04-24-2008, 10:02 AM
  #145
JasonZ-YA
JasonZ-YA's Avatar
what tires do you use buddy...
- J
Old 04-24-2008, 12:05 PM
  #146
z-u-later
z-u-later's Avatar
I've got two sets for the track: Toyo RA-1s (245/40/18) & Hankook Z211s (275/40/17).
Old 04-24-2008, 03:08 PM
  #147
DavesZ#3
DavesZ#3's Avatar
Actually, if you look at the guys who were running the Z at the nationals, they were running 285's on 18" wheels.
I've been mentally running this debate for the last couple of weeks - is it better to have wide tires without optimal sidewall configuration or narrow tires with idea sidewall config? Some people have told me that the idea is to go as wide as possible (bulging sidewalls) to get the most traction. Others have said it's better to go with the smaller width to get the flat sidewall as it handles better. On a tight course, the smaller tire would seem to handle better. Open an open course, you'd want the extra traction for the higher speeds.
With the RE-01s, there's not a whole lot of difference as the choice would be between 255/35/18 or 265/35/18.
Old 04-25-2008, 07:36 AM
  #148
thekinn
thekinn's Avatar
bump for more input. good thread.
Old 04-25-2008, 10:00 AM
  #149
dampy
dampy's Avatar
i agree w/ dmoffitt.
tire: michelin ps2
size: 255/35/18 front and 275/35/18 rear
wheels: enkei gtc-01
pressure: 38 psi (hot)
wear rate: 3 track events/1 autox - lots of meat left (85%).
mods: not much (intake, exhaust, springs, shocks)
positive reviews: probably one of the best street tires! grips well and feels good. also tried toyo t1rs and falken 452s on the track, but does not compare.
negative reviews: EXPENSIVE!!!
Old 04-25-2008, 11:57 AM
  #150
OPTIMO
OPTIMO's Avatar
At Summit Point (Main) last month I ran:
2006 Z Track.
Car: 100% stock except fluids.
Brakes: OEM Brembo. OEM pads.
Wheels: Stock Rays 5 spoke (GT wheels I think, not sure).
Wear Rate: Didn't measure. Not sure when they were put on the car. Bought it 2 mo ago.
FRONT:
Bridgestone Potenza RE050A
245 40 18
REAR:
265 35 19
Review: I thought these tires were very nice at SP. After reading this thread I realize I have too much air in them (44-45 psi hot).
These tires were awfully interesting once it started to rain and even more so once it started to sleet. Once it started to snow, well, it was time to pack up.
The tires look to be in great shape still. I'll have the wheels off this weekend most likely so I'll take a better look, but I like this tire thus far. Keep in mind, I run in Green and am a rookie in cars at HPDEs. Karts on the other hand...
Old 04-28-2008, 08:17 PM
  #151
Morris
Morris's Avatar
Originally Posted by SinCity350Z
Tire Brand:- Bridgestone Potenza RE050A Pole Position
Size:- 285/30/18 Front 295/30/18 Rear
Favorite psi:- ~34 hot
Mods:- Check www.DoubleDown350Z.com way too much to list.
Wear rate:- 4 time attacks and you can't even tell they have been beat on.
Review:- Best street tire I have ever driven. Grip is unbelieveable for a street tire. Won my class on them at California Speedway .
+1 of this tire. I wanted the MX's again, but they were not available. I have to say I am glad. Excellent on dry and wet pavement (1 day was a rain day)!
Old 04-28-2008, 09:30 PM
  #152
mavtais
mavtais's Avatar
+2. Potenza 050A is a great tire. I've had mine since my last post to this thread, and they still look new!!! 140 treadwear is a very conservative rating for these Bridgestones. Next, I'm going to try the Pole Position versions, but these just keep on going so that won't be for a long while.
Old 04-29-2008, 07:03 AM
  #153
gixracer
gixracer's Avatar
i got a set of 050A's as replacememnts for my feathers.
i had about a days work of tracking and a couple of auto-x's with no chunking. they did ball up pretty good though. for a summer light trackday tire they aren't that bad. they just get noisy at about 8/10's of their limit. they dont' overheat too bad either.
overall good tire.
Old 04-29-2008, 07:32 AM
  #154
AznSky
AznSky's Avatar
Sorry to go a bit off topic, but what is everybody running as far as wheels (xx by xx +xx) and tire sizes (xx/xx/xx)? I'm looking at 17's, but may consider 18's in order to clear a BBK in the future. Just about to start tracking
Old 04-29-2008, 09:29 AM
  #155
scotts300
scotts300's Avatar
Originally Posted by 97supratt
Anyone have any experience with toyo t1r's at the track?
They suck on the street - they'll be worse on a track.
Old 04-29-2008, 09:30 AM
  #156
scotts300
scotts300's Avatar
Originally Posted by tmak26b
yup. i could overheat the azenis, but they dont have nearly as much oil coming out as the stock 040
For the RT615s, you must keep the tire pressure at 39psi or lower...
Old 04-29-2008, 09:32 AM
  #157
scotts300
scotts300's Avatar
My favorites:
RT615s
RE-01R
Mich PS2
BS S03 (if you can find them)
RT615s are hard to beat for bang-for-buck for your 255/40/17 application. The RE01Rs will probably be a bit faster, but you'll pay for it. I love, love, LOVE the PS2s, but they are costly to replace.
Old 04-29-2008, 04:51 PM
  #158
Nihilation
Nihilation's Avatar
If anyone likes the Bridgestone RE050A Pole Position you should definitely check out the Sumitomo HTR ZIII.
TireRack rated it better than the RE050A PP's and it's MUCH cheaper. Lots of tire sizes to select from too.
http://www.rightfootdown.com/?p=37
Old 04-29-2008, 06:19 PM
  #159
mavtais
mavtais's Avatar
Oh yeah, I read that too, but that test was on the Pole Positions, not the regular 050A http://www.tirerack.com/tires/tests/...y.jsp?ttid=101. Same tread design and everything, but I can't figure out what the difference is other than a slight price increase for the regular 050A. Hmm.. why would the Pole Position be cheaper? Is it because it is not an OEM tire? Other cars with 050A OEM tires: MX-5, BMW 335, Tacoma X-Runner... There is something about the 050A that is great, or else I don't think auto manufacturers would spec it out so often, especially if it was not a cheap tire.
I wonder how well the HTR ZIII will hold tire pressure. I have the same air in my 050A since I got them. Each time I check my tire pressures (every Saturday morning before pulling out of the garage) they remain where I set them: @ 36 psi. That really says something about the quality of these tires.
Old 05-01-2008, 07:25 PM
  #160
AznSky
AznSky's Avatar
Default track wheel/tire sizes?
Hey guys, this may be a noob question. But I'm looking into recommendations on a track wheel/tire setup. Not looking for brands or what type to buy, but sizes.
I'm looking at either 17" or 18" wheels. I currently have 17x8 ASA's, so I may keep those but it depends on if I can clear a BBK in the future
Thinking of the following:
17x8's all around (current)
Tire size: unknown
OR
17x8.5 +?? FR
17x9.5 +?? RR
Tire Size: unknown
OR
18x8.5 +20 FR 245/40/18
18x9.5 +20 RR 275/40/18
OR
18X9.5 +?? FR 255/40/18
18X10.5 +?? RR 285/40/18 or 295/35/18
Sorry, this is all new to me. Any advice would be greatly appreciated. Thanks!!
Quick Reply: The Tire DB - Posts about Track and AutoX tire brands
