Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > General > Motorsports > Autocross/Road
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 09-20-2009, 11:28 AM   #1
mistico
Points: 2,123, Level: 27
Points: 2,123, Level: 27 Points: 2,123, Level: 27 Points: 2,123, Level: 27
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
Default Wheesl offset Q (track)
Long story story short, I went to have new NT-01's mounted and discovered one of my wheels is cracked (FN01r-C). The size on these is 18x9.5 +22. I'm having a hard time finding a replacement in the same color and size.
My question is regarding the offset. I'm posting this here because it's related to track use. Will a more aggressive offset put more stress on the hubs and will it change the handling? I know 18x9.5 +12 will fit with the camber settings I have, -3F and -2R but don't want to go that route if not reccomended. I can get a full set of FN01R-C's with +12 offset for about $850 shipped and the same price for +22. Just not sure which offset would be a better option. The car handles perfect right now, but if it can handle even better why not change
Thanks for any input.
mistico is offline   Reply With Quote
Old 09-20-2009, 11:33 AM   #2
terrasmak's Avatar
Points: 4,699, Level: 43
Points: 4,699, Level: 43 Points: 4,699, Level: 43 Points: 4,699, Level: 43
Today's Activity: 57.3%
Today's Activity: 57.3% Today's Activity: 57.3% Today's Activity: 57.3%
Stick with +22 , you don't want to limit your future tire selectionn buy running such an aggresive wheel. Also for the track you should try to keep your offset as close to 30 as possible.
__________________
2010 Redline Time Attack Enthusiast RWD 3rd place Overall
terrasmak is online now   Reply With Quote
Old 09-20-2009, 02:27 PM   #3
Points: 9,431, Level: 65
Points: 9,431, Level: 65 Points: 9,431, Level: 65 Points: 9,431, Level: 65
Today's Activity: 99.9%
Today's Activity: 99.9% Today's Activity: 99.9% Today's Activity: 99.9%
Yes. If you put a 50 pound weight (wheel plus tire) on the hub, the farther you move the weight away from the hub the more stress on the hub. What is the relationship between stress and an additional 10 mm ? I don't know.
Yes the car will handle differently. You have widened rear tracking but left front tracking alone.
__________________
370Z 2009 Sport Package
davidv is offline   Reply With Quote
Old 09-20-2009, 02:40 PM   #4
mistico
Thank you both. I'll stick with the +22 then.
davidv, I would've swapped all 4 corners so both front and rear would've had wider tracking.
Old 09-21-2009, 07:57 AM   #5
mekatoka
Points: 1,896, Level: 25
Points: 1,896, Level: 25 Points: 1,896, Level: 25 Points: 1,896, Level: 25
Quote:
Originally Posted by terrasmak View Post
....Also for the track you should try to keep your offset as close to 30 as possible.
This scares me, I posted a thread recently HERE for wheel selection at track and was suggested to buy +18 and I bought Enkei RPF1's 17x9.5 +18. I use my car mostly for track and all the street miles I put are the ones that I put on when driving to the event.
I still haven't received my wheels yet, should I return them?
I know the stockers have a +30 offset on Nismo
Fyi, you too have replied in this thread
mekatoka is offline   Reply With Quote
Old 09-21-2009, 08:35 AM   #6
betamotorsports
betamotorsports's Avatar
Points: 2,487, Level: 30
Points: 2,487, Level: 30 Points: 2,487, Level: 30 Points: 2,487, Level: 30
Today's Activity: 4.0%
Today's Activity: 4.0% Today's Activity: 4.0% Today's Activity: 4.0%
Why? Track width is one of the easily modified factors of lateral load transfer. Why would you take that mod out of any suspension adjustment?
__________________
John Coffey
betamotorsports is offline   Reply With Quote
Old 09-21-2009, 09:41 AM   #7
terrasmak's Avatar
Quote:
Its to keep your steering geometry correct. when you push the wheels out the tires start to scrub while cornering.
I run +27 up front and +17 in the rear for track. Having the slightly wider rear will cause a little push, but its easy tuned out with suspension.
__________________
Old 09-21-2009, 10:37 AM   #8
mistico
Crap! The wheel size/offset has been discontinued.
Off to find new wheels now.
NT03+M in 18x9.5 +27
RPF1 18x9.5 +15
FN01R-C 18x9.5 +22 same model I have but diff offset. I like these
Any suggestions on that size under 1k.
I remember a member here had discounts on Enkei wheels.
Thanks!
Old 09-21-2009, 10:57 AM   #9
plusONETEN
Points: 1,064, Level: 17
Points: 1,064, Level: 17 Points: 1,064, Level: 17 Points: 1,064, Level: 17
Today's Activity: 2.1%
Today's Activity: 2.1% Today's Activity: 2.1% Today's Activity: 2.1%
the 'ideal' offset changes if you lower your car... depending on suspension geometry, a lowered car will have the same scrub radius with a lower offset wheel as a higher riding car will have with a higher offset wheel...
how much depends on the suspension setup. but it should be noted that if a racing god tells you that 30mm offset is ideal, that 30mm is only perfectly accurate if you have the same ride height. otherwise, you need t find out his scrub radius and then get an offset that will allow you to have the same scrub radius.
of course, you guys have 350z's and since they are pretty low stock, you could probably jut ignore it... how mucb lower could it be?
scrub radius is only for the steered wheels, of course. after you deal with what offset is best for the fronts, make your choice for the rear based on front vs. rear track width.
NT03+Ms and RPF1s are sick wheels too. I plan on getting some of those in 17x9.5+38 for my 240sx
plusONETEN is offline   Reply With Quote
Old 09-21-2009, 11:59 AM   #10
betamotorsports
I can understand scrub concerns if you're running in a spec class (Spec Miata, RX7, SRF, etc.) where every little mph is important but I think for the 350Z being able to adjust LLT front to rear has some advantages.
__________________
John Coffey
Old 09-21-2009, 12:26 PM   #11
scotts300
scotts300's Avatar
Points: 6,568, Level: 53
Points: 6,568, Level: 53 Points: 6,568, Level: 53 Points: 6,568, Level: 53
Today's Activity: 22.8%
Today's Activity: 22.8% Today's Activity: 22.8% Today's Activity: 22.8%
RPF1 18x9.5 +15
Thanks!
You can get a new set of FN01R-Cs in 17x10 +25 for less than that, and allow 275/40s at all four corners. I like the 17s because tires are way cheaper. Of course there are some very good deals out there on used wheels.
__________________
Quote:
Originally Posted by solidfish View Post
Hey scott. Thanks for the ride by the way. Your car and driving is sick. Literally, I was sick. It was like riding a mad rollercoaster. The car turns like its on rails. And the braking was unreal. So many times I thought we were going to fly off the track. Absolutely nuts, but it was great fun.
scotts300 is offline   Reply With Quote
Old 09-21-2009, 12:58 PM   #12
mistico
Quote:
Scott,
I have a 4 wheel 14" StopTech kit and I don't think the 17" wheel clears. Could I test fit one of your FN01R-C's?
Old 09-21-2009, 01:08 PM   #13
mistico
Old 09-21-2009, 02:05 PM   #14
scotts300
scotts300's Avatar
Scott,
You sure could, but I don't think it'll fit as they just clear my 332mm kit.
__________________
Old 09-21-2009, 02:32 PM   #15
guitarist
Points: 1,152, Level: 18
Points: 1,152, Level: 18 Points: 1,152, Level: 18 Points: 1,152, Level: 18
The only thing I'd be worried about in messing with track width is that by adjusting spacing off the hub (as opposed to moving the actual suspension attachment points), you also mess with scrub radius.
But I don't think 5-15mm or so is enough to put undue strain on the hub bearings, so I agree that it's something worth looking into at the least.
And I haven't heard any complaints about scrub radius changes causing lots of undue understeer in that range of offset difference from stock either.
*edit*: should have read further. Other guys covered it.
guitarist is offline   Reply With Quote
Old 09-21-2009, 04:17 PM   #16
mistico
Thanks for the info, Scott. I'll pass on the fitting
Thanks to other posters to for the additional info. Looks like I'll stick with a set of wheels with offset in the 18-22mm range.
Old 09-23-2009, 02:33 PM   #17
mistico
Well, contrary to what I posted above I went ahead and purchased a set of RPF1's with +15 offset. I'll try them out with the 275's up front and see if they fit properly with my setup. I have a weekend at the track coming up so I'll get to see if any rubbing occurs.
They only weight 18.6lbs, a big weight savings over the FN01R-C at 22+lbs
Old 09-23-2009, 02:40 PM   #18
Motormouth
two other thoughts:
- it seems generally people running slicks/track only setups run a smaller diameter, which will increase your ability to run a lower offset.
- getting a rim with a higher offset could allow you to adjust the offset with spacers, to fine tune any fitment issues.
congrats on the purchase and be sure to follow up in this thread.
Motormouth is offline   Reply With Quote
My350Z
350 Z
Paid Advertisement
Tags
17x95, 30, 350z, 38, aggressive, fn01rc, g35, miata, offset, radius, rpf1, scrub, track, wheesl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
