Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > General > Motorsports > Autocross/Road
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 09-25-2009, 09:45 PM   #1
Stillen Z
Points: 1,062, Level: 17
Points: 1,062, Level: 17 Points: 1,062, Level: 17 Points: 1,062, Level: 17
Today's Activity: 0.8%
Today's Activity: 0.8% Today's Activity: 0.8% Today's Activity: 0.8%
Default Track day overheating
My '04 350 overheated while on track today. When the temp needle rose to the last hash mark, the rev limiter (at least it felt like the rev limiter) began to cut in at around 5k revs. As soon as the engine cooled off a bit after a lap or so of more casual pace, the car ran fine. Until it heated up again, then the same thing happened.
Yes, I should have been more observant of the temp. No doubt about it. I am now. I wasn't then, so enough on that.
My question is: did the engine management kick in the rev limiter to protect the engine when the temp got high enough?
Stillen Z is offline   Reply With Quote
Old 09-26-2009, 05:14 AM   #2
Points: 9,431, Level: 65
Points: 9,431, Level: 65 Points: 9,431, Level: 65 Points: 9,431, Level: 65
Today's Activity: 99.9%
Today's Activity: 99.9% Today's Activity: 99.9% Today's Activity: 99.9%
Yes. ECM function is similar for input from sensors such as engine coolant temperature sensor. ECM will cut fuel. The actuator is the fuel injector. The ECM will not allow the motor to run past 1,500 RPM. Applicable codes are :
P0117
P0118
P0125
__________________
370Z 2009 Sport Package
davidv is offline   Reply With Quote
Old 09-26-2009, 05:39 AM   #3
racerbob4
Points: 2,821, Level: 32
Points: 2,821, Level: 32 Points: 2,821, Level: 32 Points: 2,821, Level: 32
Today's Activity: 5.6%
Today's Activity: 5.6% Today's Activity: 5.6% Today's Activity: 5.6%
We use Red Line water wetter in our radiator. There is also a larger radiator available but we haven't put one in yet. We also use Red Line synthetic oil, maybe some heat is taken off in that way too.
racerbob4 is offline   Reply With Quote
Old 09-26-2009, 05:41 AM   #4
Z Infidel
Z Infidel's Avatar
Points: 2,556, Level: 30
Points: 2,556, Level: 30 Points: 2,556, Level: 30 Points: 2,556, Level: 30
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
Sounds like you may need to invest in an aftermarket oil cooler.
__________________
When it comes to money.... Z > food.
Z Infidel is offline   Reply With Quote
Old 09-26-2009, 06:22 AM   #5
JasonZ-YA
JasonZ-YA's Avatar
Points: 30,508, Level: 100
Points: 30,508, Level: 100 Points: 30,508, Level: 100 Points: 30,508, Level: 100
Today's Activity: 3.2%
Today's Activity: 3.2% Today's Activity: 3.2% Today's Activity: 3.2%
Send a message via AIM to JasonZ-YA Send a message via Yahoo to JasonZ-YA
Looks like Davidv answered your question....
What cooling mods do you have?
Aftermarket radiator, oil coolers, oils..etc.??
The Redline water wetter is a great suggestion, i have used that stuff before and it helps!
-J
__________________
04 PPW Touring - My favorite mod is my short Dodge Avenger antenna
JasonZ-YA is online now   Reply With Quote
Old 09-26-2009, 09:21 AM   #6
ADMAN
ADMAN's Avatar
Points: 4,397, Level: 42
Points: 4,397, Level: 42 Points: 4,397, Level: 42 Points: 4,397, Level: 42
Today's Activity: 0.7%
Today's Activity: 0.7% Today's Activity: 0.7% Today's Activity: 0.7%
out here in the heat!!! Welcome. What part of AZ?
ADMAN is offline   Reply With Quote
Old 09-26-2009, 10:48 AM   #7
Stillen Z
Quote:
P0117
P0118
P0125
Whatever was going on, it allowed the car to rev to about 5k. I wasn't limited to 1,500.
-J
Stillen aluminum radiator, Stillen oil cooler, Stillen power steering cooler. The motor is stage 2 Stillen supercharged.
Old 09-26-2009, 12:31 PM   #8
mhoward1
The secret Mod
mhoward1's Avatar
Points: 23,576, Level: 94
Points: 23,576, Level: 94 Points: 23,576, Level: 94 Points: 23,576, Level: 94
Today's Activity: 33.1%
Today's Activity: 33.1% Today's Activity: 33.1% Today's Activity: 33.1%
The M45 and MP62 units are notorious for heat soak. Keeping it cool on a road course is going to very hard.
Does the unit have an intercooler? If not the intake heat will heat up the rest of the system.
__________________
Marty Howard
Former President - Triangle Z club
Track Events Stewart and Logistics Coordinator
TZC/THSCC track program
Become a fan of MH Motorsports
http://www.facebook.com/home.php?#!/...s/264814350042
mhoward1 is online now   Reply With Quote
Old 09-26-2009, 12:41 PM   #9
Stillen Z
Yes, it's intercooled.
Just prior to the track day problem, I had the coolant changed by a shop I trust. I therefore assumed the cooling system was filled to capacity. Nothing was leaking at the track, so I dismissed low coolant as the problem. But, now that things are cool and I could easily check the coolant level, I found the radiator took 1/2 gallon of water.
Is the system being down 1/2 gallon enough to cause the overheating? Also, there doesn't appear to be an overflow tank. Does that make any sense or am I just missing it despite having looked fairly carefully?
Old 09-26-2009, 01:46 PM   #10
Ataru074
Ataru074's Avatar
Points: 2,912, Level: 33
Points: 2,912, Level: 33 Points: 2,912, Level: 33 Points: 2,912, Level: 33
Today's Activity: 7.1%
Today's Activity: 7.1% Today's Activity: 7.1% Today's Activity: 7.1%
Send a message via AIM to Ataru074 Send a message via MSN to Ataru074
you might want to invest few bucks in a REAL water and oil temperature gauge... keep running until the ecu kicks in isn't a brilliant idea if you want your engine to survive for a while. at least you can diagnose the issue and understand what needs better cooling.
__________________
Magnetic Black Nismo Z #867... 101% stock
Ataru074 is offline   Reply With Quote
Old 09-26-2009, 01:55 PM   #11
Stillen Z
Quote:
In my original post I already admonished myself for failing to pay attention. It happened. I already said it won't happen again.
Now how about we figure why it overheated, starting with whether being down a 1/2 gallon on coolant will do it.
Old 09-26-2009, 02:22 PM   #12
0jiggy0
0jiggy0 jiggy00
Points: 3,176, Level: 34
Points: 3,176, Level: 34 Points: 3,176, Level: 34 Points: 3,176, Level: 34
Today's Activity: 23.8%
Today's Activity: 23.8% Today's Activity: 23.8% Today's Activity: 23.8%
Send a message via AIM to 0jiggy0 Send a message via Yahoo to 0jiggy0
Is it possible they didnt properly bleed the coolant system of air? I hope so else your losing coolant somewhere internal.... But you would have seen white smoke.
I'm going with not properly burped just off what you said.
__________________
MY350Z.COM just got a little bit better with big uncle TX gone
0jiggy0 is online now   Reply With Quote
Old 09-27-2009, 03:52 AM   #13
Ataru074
Ataru074's Avatar
if you have the stock radiator cap it opens at 0.9 bar... that could be a reason.. for what I have seen the stock needle doesn't move a hair at boiling point... so your fluid was boiling and generating pressure big time.
I never lost 1/2 gallon.. but 1/4 yes, during the summer, than I changed the "mix" using 80% water, 2 bottle of water wetter and rest regolar coolant and 1.3 bar nismo radiator cap... and almost no water loss.
I forgot.. I also added a 19 row setrab oil cooler and I haven't disconnected the stock oil to water heater/cooler.
__________________
Old 09-27-2009, 07:45 AM   #14
Stillen Z
I'll try it. Thanks.
Old 09-27-2009, 03:51 PM   #15
Stillen Z
I ran a couple more sessions today. Topping up the radiator helped, but it still overheated so the problem is something more complex. Dang.
I have a 1 bar cap. It's not the 1.3 that was suggested, but it's better than the .9 OE cap. I'll try the water wetter, as well, before I start on more expensive stuff. What a pain in the neck it's going to be trying something, then going to the track to see if it works. If it didn't work, then try something else and wait for the next event to see if it worked, etc.
Old 09-27-2009, 05:57 PM   #16
mhoward1
The secret Mod
mhoward1's Avatar
My guess is the oil temp is creeping up before the water temp ever does. The extra compression and higher intake temps are allowing the oil temp to creep up. How big is your oil cooler? Thought about a remote oil filter and an accusump system to add more quarts to the overall setup?
__________________
Marty Howard
Old 09-28-2009, 11:28 AM   #17
scotts300
scotts300's Avatar
Points: 6,568, Level: 53
Points: 6,568, Level: 53 Points: 6,568, Level: 53 Points: 6,568, Level: 53
Today's Activity: 22.8%
Today's Activity: 22.8% Today's Activity: 22.8% Today's Activity: 22.8%
There is your problem. I see VERY few FI'd 350Zs on the tracks that can manage the heat. I don't have any special solution that hasn't been mentioned (or you don't already have), but you are in good company. Ask Steve, since you seem to have a good repertoire with them.
__________________
Quote:
Originally Posted by solidfish View Post
Hey scott. Thanks for the ride by the way. Your car and driving is sick. Literally, I was sick. It was like riding a mad rollercoaster. The car turns like its on rails. And the braking was unreal. So many times I thought we were going to fly off the track. Absolutely nuts, but it was great fun.
scotts300 is offline   Reply With Quote
Old 09-29-2009, 08:49 AM   #18
Zazz93
Zazz93's Avatar
Points: 1,617, Level: 23
Points: 1,617, Level: 23 Points: 1,617, Level: 23 Points: 1,617, Level: 23
I think they are right about the heat soak issues and the FI package. Tracking a hot setup like that may require several custom mods to cut the heat issues. Once you've checked off the basic items, consult Stillen for problems they could have run into when testing.
__________________
MIKE ~ 2005 350Z 6MT
Zazz93 is offline   Reply With Quote
Old 09-29-2009, 09:05 AM   #19
97supratt
97supratt's Avatar
Points: 5,063, Level: 45
Points: 5,063, Level: 45 Points: 5,063, Level: 45 Points: 5,063, Level: 45
Today's Activity: 1.8%
Today's Activity: 1.8% Today's Activity: 1.8% Today's Activity: 1.8%
Send a message via AIM to 97supratt Send a message via Yahoo to 97supratt
What coolant/water setup are you running? You should invest in evans, since it's used in racing. I would also suggest the racing radiator cap.
__________________
06 & 07 350z **gone**/01 z06 **sold**/05' Black Opal Metallic E55 / 93' Mica Blue RX7 R1 *Race Build* www .track-star.net
97supratt is offline   Reply With Quote
My350Z
350 Z
Paid Advertisement
Tags
2004, 350, 350z, coolant, g35, gtr, losing, oil, overheat, overheating, stillen, summer, synthetic, track, trackday
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
