Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > General > Motorsports > Autocross/Road
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 10-16-2009, 01:56 PM   #1
halfrice
Points: 1,938, Level: 26
Points: 1,938, Level: 26 Points: 1,938, Level: 26 Points: 1,938, Level: 26
Today's Activity: 0.8%
Today's Activity: 0.8% Today's Activity: 0.8% Today's Activity: 0.8%
Default Need help choosing right width/offset track wheels
Background: building NA z for HPDE events, car is lowered on jic flt-a2's and has aftermarket camber arms.
Looking to get a set of 17" enkei rpf1's and wrap them in 275/40/17's, Choices:
17x10 +18 or +38
17x9.5 +18 or +38
17x9 +22
Original plan was to run 17x10 +18 all around but starting to hear it may be to aggressive of an offset for the fronts. Anyone have any experience with this setup for track? Also noticed people tracking with 17x9.5 +18 all around, or could run 17x9 +22 all around, and the last possible setup would be 17x9 +22 f and 17x10 +18 r (with different size tires up front), but original plan was to get away from the staggered setup and go with a square setup. Now im having trouble deciding which way to go and wanted some opinions from people here who actually track their z's and not for just show. Thanks in advance.
halfrice is offline   Reply With Quote
Old 10-16-2009, 02:51 PM   #2
reserved
Know it all
reserved's Avatar
Points: 3,418, Level: 36
Points: 3,418, Level: 36 Points: 3,418, Level: 36 Points: 3,418, Level: 36
Today's Activity: 3.3%
Today's Activity: 3.3% Today's Activity: 3.3% Today's Activity: 3.3%
I have the same suspension as you.
I run 17 x 9.5 +18 with absolutely no issues.
__________________
07 ZR: Daily driver.
03 Z: Track car.
reserved is offline   Reply With Quote
Old 10-16-2009, 10:29 PM   #3
scotts300
scotts300's Avatar
Points: 6,568, Level: 53
Points: 6,568, Level: 53 Points: 6,568, Level: 53 Points: 6,568, Level: 53
Today's Activity: 22.8%
Today's Activity: 22.8% Today's Activity: 22.8% Today's Activity: 22.8%
Which 275/40/17? Hoosiers run wide, and should be on a 17x10 minimum. In my experience, 17x10 +18 with a 275 tire will likely rub, as my 17x10 +20 (net) with Hoosier 275s just rub on the outside a tad.
The 17x9.5 +38s can work, but you'll need to be careful about front brake clearance issues with the 17" RPF1s. The barrel on them gets thinner, meaning that your total inner diameter shrinks, which caused problems with my Brembos on the front.
__________________
Quote:
Originally Posted by solidfish View Post
Hey scott. Thanks for the ride by the way. Your car and driving is sick. Literally, I was sick. It was like riding a mad rollercoaster. The car turns like its on rails. And the braking was unreal. So many times I thought we were going to fly off the track. Absolutely nuts, but it was great fun.
scotts300 is offline   Reply With Quote
Old 10-17-2009, 02:10 AM   #4
halfrice
was planning on running toyo r1r's
Old 10-17-2009, 05:36 PM   #5
MPD47
Points: 2,383, Level: 29
Points: 2,383, Level: 29 Points: 2,383, Level: 29 Points: 2,383, Level: 29
Today's Activity: 1.8%
Today's Activity: 1.8% Today's Activity: 1.8% Today's Activity: 1.8%
Get 9.5's and run 265's all the way around if you are NA with bolt ons.
__________________
-Mike
MPD47 is offline   Reply With Quote
Old 10-17-2009, 06:01 PM   #6
reserved
Know it all
reserved's Avatar
Quote:
why not 275's ??????
__________________
03 Z: Track car.
Old 10-17-2009, 07:16 PM   #7
terrasmak's Avatar
Points: 4,699, Level: 43
Points: 4,699, Level: 43 Points: 4,699, Level: 43 Points: 4,699, Level: 43
Today's Activity: 56.2%
Today's Activity: 56.2% Today's Activity: 56.2% Today's Activity: 56.2%
Actually wider rubber is usually better
__________________
2010 Redline Time Attack Enthusiast RWD 3rd place Overall
terrasmak is online now   Reply With Quote
Old 10-18-2009, 11:23 AM   #8
racerbob4
Points: 2,821, Level: 32
Points: 2,821, Level: 32 Points: 2,821, Level: 32 Points: 2,821, Level: 32
Today's Activity: 5.6%
Today's Activity: 5.6% Today's Activity: 5.6% Today's Activity: 5.6%
You didn't say if you have the Brembo brake calipers on the car. We run Brembos' with the SCCA T2 setup which is 9x18 + 35 fronts and 10x18 + 38 rears with 285/30 tires on all four corners. We put ARP wheels studs on all 4 corners. We had to use a 22mm spacer on the front to clear the brakes and 10mm spacer on rear only to get the tires out further. I can get you 15% off on any Enkei wheel + shipping. Let me know if I can help you. We have raced on Enkei's for 4 years now.
racerbob4 is offline   Reply With Quote
Old 10-18-2009, 01:12 PM   #9
sektor 11
sektor 11's Avatar
Points: 1,403, Level: 21
Points: 1,403, Level: 21 Points: 1,403, Level: 21 Points: 1,403, Level: 21
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
from what I've been reading this is the setup to have (with camber arms). Hopefully this spring!
__________________
signatures are gay.
sektor 11 is offline   Reply With Quote
Old 10-18-2009, 09:22 PM   #10
MPD47
Quote:
As a general rule of thumb, sure. Personally I like to be able to rotate the car a good deal so with a basically stock power setup and a lighter and stiffer than stock car I've been happy with 265's on all four. Allows nice controllable trail braking and I can power over if need be. But hey, it's what I've personally been happy with. Not for everyone, or every driving style, or every setup. Next year I'm going to 285's on all 4 but I'm also increasing power by 200+whp!
I merely suggest 265's as it's a nice balance point and if you over tire a car (I have no idea the OP's skill level) you tend to mask driving flaws.
__________________
-Mike
Old 10-21-2009, 09:48 AM   #11
betamotorsports
betamotorsports's Avatar
Points: 2,510, Level: 30
Points: 2,510, Level: 30 Points: 2,510, Level: 30 Points: 2,510, Level: 30
Today's Activity: 0.4%
Today's Activity: 0.4% Today's Activity: 0.4% Today's Activity: 0.4%
spam.
__________________
John Coffey
betamotorsports is offline   Reply With Quote
Old 10-22-2009, 03:40 PM   #12
sfarrah
sfarrah's Avatar
Points: 4,082, Level: 40
Points: 4,082, Level: 40 Points: 4,082, Level: 40 Points: 4,082, Level: 40
Send a message via AIM to sfarrah Send a message via Yahoo to sfarrah
i have the exact setup you're asking about (17x10 + 18 rpf1) and it works great and fits over 13inch stoptechs front and rear. I rolled the fenders as a preventative measure so I can't say for certain if it was needed or not.
__________________
12.8@107.8mph ALL MOTOR! SPL Parts 6pt roll cage, APS Plenum, JWT Clutch and FW, 5Zigen FN01RC, Hotchkis sways with SPL adj end links, Moton Clubsports, Torvec LSD, 5Zigen ProRacer A-Spec, SPL solid diff bushings, SPL Camber/Caster Arms, rear Camber and Mid-Link w/Swift springs, Stoptech 13" front+rear BBK-Hawk Pads
sfarrah is offline   Reply With Quote
Old 10-23-2009, 03:31 PM   #13
sektor 11
sektor 11's Avatar
Quote:
have you lowered the car at all? suspension?
__________________
signatures are gay.
Old 11-03-2009, 12:49 AM   #14
crug75hid
i have been using 17*9.5+18. they are really work fine for mine. might be some washer problem
crug75hid is offline   Reply With Quote
Old 11-03-2009, 04:01 AM   #15
mw9
mw9's Avatar
Points: 3,683, Level: 38
Points: 3,683, Level: 38 Points: 3,683, Level: 38 Points: 3,683, Level: 38
Today's Activity: 5.0%
Today's Activity: 5.0% Today's Activity: 5.0% Today's Activity: 5.0%
Quote:
I will have to get with you in the beginning of the year, looking for some enkei's. Thanks again. Can't the suggestions coming, income tax check, here I come.
__________________
KJR pulley, motordyne 5/16 spacer, rogue short shifter, all amsoil fluids, JWT popcharger, 350evo rear sway, CT-1 front sway AAM ypipe, helix tps, UTEC, Tokico HP blue, Tein S
mw9 is offline   Reply With Quote
Old 11-03-2009, 08:49 AM   #16
Redrobin350
Points: 2,745, Level: 31
Points: 2,745, Level: 31 Points: 2,745, Level: 31 Points: 2,745, Level: 31
Quote:
It's in his sig. With a SPL parts sticker on the door pretty safe to say he'll limit himself to parts listed on their web site. Not a fan of Clubsports, sorry.
Redrobin350 is offline   Reply With Quote
Old 11-06-2009, 01:31 PM   #17
sektor 11
sektor 11's Avatar
Quote:
Duh. Clearly I can't read.
__________________
signatures are gay.
My350Z
350 Z
Paid Advertisement
Tags
17x10, ares, car, enkei, finding, offset, picking, rims, rpf1, teejansteewan, tps, wheels, width
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
