Thread Tools | Search this Thread |
#1 |
are these compatible among the different auto organizations that host track events? (ie. speedventures, speedtrials, redline, etc.)
i want to buy one but want to make sure i can use it at these track days hosted by various organizations. TIA. kv |
#2 |
depends on the frequency from the transmitter... I'm guessing the organizations could tell you if your transceiver is compatible with their lap-timing equipment.
Another option is to provide your own transmitter, the one that corresponds to your transceiver. Usually when you buy one of those lap timers, it includes everything you will need. I've been to many track events where drivers will line up their transmitters along the front straightaway. Hope that helps. PeteH
__________________
2003 Daytona Blue Track model 350Z |
#3 |
We have a very good data system that we are selling. Its a MychronGold 3+ auto that logs all sorts of great data and you can download onto a PC. The system retails for $899 but beats a lot of other systems that cost twice as much. The dash displays lap times, RPMS, wheels speed, and has alarm lights for temps or preasure. It can log throttle position, RPM, Speed, G's and a ton more. It will draw a complete track map and you cna then over lay laps to see where you gain or loose time.
We have installed about 10 of them in our PCS customer cars. Cheers We are a dealer for the Mychron dash's BJ@350EVO.com |
#4 |
BJ,
That sounds like a deal.
__________________
'71 240Z, '78 280Z, '07 Nismo 350Z #0007 Silver Alloy
#5 |
Speedventures uses AMB transponders
http://www.amb-it.com/ Norther California Racing Club ( http://www.ncracing.org ) uses the Hot Lap system, and there's probably some others out there as well. I've seen the Mychron3+ Gold for less than $660, but I don't know too much about the place that sells it. here's a link to the store: http://www.racearsenal.com/data_acquisition.htm They also sell an AMB transponder, but Speedventures uses the 260 which is the Auto racing version while the 160 is the Kart racing version. It looks like there are a few different systems out there, and they aren't compatible with eachother, so unless you stick with a single group (or know exactly which timing system the groups you run with use) you may want to get your own full system (like that Mychron dealio) or just rent from the different groups. -D'oh! |
#6 |
The Mychron 3+ for $660 is the kart dash series. The auto Mychron 3+ Auto has more memory and has different sensors.
