It's time: BSP Solo car to NASA TT3 Build
Old 11-10-2014, 01:31 AM
03threefiftyz
03threefiftyz's Avatar
17x10/17x11 on 275's.
Old 11-10-2014, 05:16 AM
hajwoj's Avatar
Good thing we went over the car today...
Driveshaft lost a bolt and the others had worked loose:
The service manual requires many of the driveline fasteners to be replaced. Thought this was overkill, guess not.
Old 11-12-2014, 04:39 AM
Flier129
Flier129's Avatar
This is an awesome build, but I'll be sad not to see it at anymore tours.
So you went into TT3 because you didn't want to deal with the rule-set of something like a TTB build?
Old 11-12-2014, 04:43 AM
03threefiftyz
I would have to slow the car down to run TTB, which I don't have any interest in. I want the open P/W ruleset. Current track record at Summit is 1:18.7 from this weekend. I want to get the car down to 1:20 on NT01's over the next couple of trips...then go back to my old friend Hoosier and try and knock a couple of seconds off.
Old 11-12-2014, 12:00 PM
Vq.turbo.DremZ
Vq.turbo.DremZ's Avatar
Exciting Stuff, Glad you are keeping the Z! [Although I would have love your suspension setup if you parted it out]
Old 11-12-2014, 12:18 PM
03threefiftyz
If you are interested in the shock package, I can put you in touch with the builder of my Penske's. I wouldn't have sold them for much less than I got them for anyway...
Old 11-13-2014, 11:42 AM
Vq.turbo.DremZ
Ankeny racing right? Websites currently down, I was also in touch with Joefis for a front splitter, been busy with other things recently though.
03threefiftyz
Yes I can put you in touch if you Ankeny if you want...
Old 11-15-2014, 05:57 PM
03threefiftyz
Kognition chassis mounted wing is now on order .
Old 11-16-2014, 03:37 AM
Fixxxercask
Fixxxercask's Avatar
Is it going to mount to the trunk floor, crash bar???
I am redoing how mine is mounted over the winter to tie it to the trunk floor.
Old 11-16-2014, 06:21 AM
03threefiftyz
Old 11-16-2014, 06:47 PM
SE5spd
SE5spd's Avatar
the rest of that subaru
https://scontent-2.2914.fna.fbcdn.ne...82&oe=54E94277
Old 12-04-2014, 10:21 AM
03threefiftyz
Nismo V3 front cover has arrived. Wing should be here next week. I expect to get cracking on the tear down....next weekendish.
Old 12-04-2014, 11:32 AM
03threefiftyz
Closest thing I have to video of playing around with the viper:
<iframe width="560" height="315" src="//www.youtube.com/embed/bm8R3TaWlVc" frameborder="0" allowfullscreen></iframe>
Old 12-14-2014, 09:44 AM
sag
sag's Avatar
nice. new here, interested in the build. ive been hanging around my nasa friends at the track too much. going from racing 2 wheels to 4 lol and getting a z this week. my roommate races in tt3 and bsp as well!
Old 12-14-2014, 12:02 PM
03threefiftyz
Must be Mayfield....
Old 12-14-2014, 12:35 PM
03threefiftyz
Made a little progress this weekend. Been busy, so not much to date. Got the car down the point I have been dreading....removing the sound material. Nismo V3 front bumper mocked up and got some ideas for the front splitter. Hoping to have all the sound crap and front splitter on by the time the rear wing gets here (not sure when that will be). Going to hack the front lights up and leave nothing but the front cover (painted). Not sure how much of the wiring harness I will go through at least initially, but I already have bunches of unused connections/wires laying around. Also plan to run a bit of flap outer edge of the fender to keep the air off the tires...
Old 12-15-2014, 11:44 AM
  #38
Fixxxercask
That sound deadening stuff took me many hours, but when all done and cleaned up and painted it looks much better than leaving it there.
I will be re-doing my front splitter as well over the winter. I also want to run a flap along the front side of the fender/wheel well. I thought about using some black abs plastic. Any ideas what you're going to use there?
Old 12-15-2014, 12:02 PM
  #39
03threefiftyz
Probably aluminum. Easy to work with.
Old 12-15-2014, 06:33 PM
  #40
terrasmak's Avatar
Received 2,283 Likes on 1,645 Posts
Aluminum is really easy to work with and simple to bend back, mine take a lot of abuse.
Quick Reply: It's time: BSP Solo car to NASA TT3 Build
