What is the best front sway bar for autox?
Old 11-17-2014, 11:07 AM
jc_350z
jc_350z's Avatar
Default What is the best front sway bar for autox?
I'm going to be doing autox next year and i'm planning to run in the CS group. I was informed I could use a front sway bar and right now im looking at the best option for my Z. Any inputs would be great! thanks.
-2003 touring edition
Old 11-17-2014, 03:33 PM
Sleepiedaze
Sleepiedaze's Avatar
stock.
Old 11-17-2014, 04:13 PM
Spike100
Spike100's Avatar
You said: “I was informed I could use a front sway bar…”. So, do they not allow a rear sway bar?
Old 11-17-2014, 04:19 PM
350Z/370Z Tech Moderator
MicVelo's Avatar
Received 3,253 Likes on 2,314 Posts
Default Front bar mod only? Hmmmm......
You're only allowed a front bar modification? Interesting.... because autocross "likes" oversteer, it's odd because to promote oversteer, you want to take out front bar (which is why sleepiedaze's suggestion of stock is actually dead on).
Adding more bar upfront with no changes otherwise is going to make your car plow.
I would not rely on someone telling you what is and what is not allowed....get the *CURRENT* SCCA GCR (general competition rules.... presuming you are referring to SCCA C-Stock) and read up on what is allowable for that class.
FWIW, I run a set of Hotchkis bars (F&R adjustable through mounting holes - increase/decrease lever for stiffness) BUT...I don't autocross. I'm a road guy and have mine set up for a bit more neutral-to-oversteer with rear bar bias - mounted on hole 2 and front on hole 1. (Working with a NON-adjustable spring/shock setup) But again, that's me. You will need to experiment with what works for your driving style and type.
Have fun!
Mic
Old 11-17-2014, 04:30 PM
jc_350z
jc_350z's Avatar
Thanks for the replies!
Old 11-17-2014, 04:37 PM
jc_350z
jc_350z's Avatar
Have fun!
Mic
I got this information from another forum..
"Change, replace or remove ONE sway bar. One of the two bars must remain *OEM and attached though it is your choice of which one to modify"
So i just wanted to know what would work best to reduce oversteer, Ive done some practice events and the back just tries to go everywhere.Very new to this. Just don't want to spend money buying parts i won't really need. I've been told that this forum has a lot of drivers doing autox and can help make a choice of what has worked for them.
Old 11-17-2014, 04:38 PM
jc_350z
jc_350z's Avatar
***Change, replace or remove ONE sway bar. One of the two bars must remain *OEM and attached though it is your choice of which one to modify "
Old 11-17-2014, 06:41 PM
steidz
steidz's Avatar
Couple things to think about.
Replacing the front bar with something big.
Hotchkis, Stillen... The main idea is to keep the car from rolling too much. The front tires needs a lot of neg camber but a stock car has maybe one degree. So by reducing roll you improve the contact patch of the front tires. The car will push so you have to adjust your driving style for it.
Do you have good tires?
Thats the first place to spend your money. Buy an extra set of stock rims and put on some good tires. Hancook RS3's are a great choice. BRG rivals and Dunlop star specs are other options. Its a waste of time to try and tune your car's handling without having proper tires.
Does your car have the Vlsd or is it open. The Vlsd is not great but in stock class it will be a must have also.
If you're just starting out. I would get tires first, race as much as you can for the first half of the year and then see what you want to do. Stay stock, STU etc. and then start planning your build.
Welcome to the addiction.
Good reading - https://my350z.com/forum/autocross-r...ross-350z.html
Scott, 03 350Z STU
Old 11-18-2014, 09:35 AM
03threefiftyz
03threefiftyz's Avatar
The main thing a front sway does for a Z in CS has nothing to do with body roll. It is all about load transfer to help the rear tires, which are working hard because of the worlds crappiest diff.
Old 11-19-2014, 03:53 AM
Zmandriving
Zmandriving's Avatar
I would change front. There will be no benefit from a stiffer rear sway bar with oem front. I also have hotchkiss sway bar and it is a great option. Also whiteline makes a nice swaybars too. I would recommend upgrading your endlinks when you do this upgrade. You will blow right through your oem endlinks with upgraded sway bar. Mine lasted about a month and I was not autocrossing. I like Powergrids for endlinks or spl pro endlinks.
Old 11-20-2014, 06:36 AM
SnoXRacer183
SnoXRacer183's Avatar
Big front sway bar is required or you'll be spinning your inside rear wheels every corner. Stock front, with disconnected rear bar wasn't enough.
Old 11-20-2014, 08:41 PM
eracer
eracer's Avatar
I second this statement. I run an EVO front sway bar at full stiff and run into this problem. I can't lay power down coming out of the turns. Front still loads up enough to lift the rear resulting in lost traction. Factory vlsd sucks.
Obadabot
06-18-2023 11:31 PM
11-01-2015 05:25 PM
Quick Reply: What is the best front sway bar for autox?
