My STU build
Old 04-17-2016, 07:33 AM
  #161
ian99rt
ian99rt's Avatar
Originally Posted by Z1NONLY
You could make a lot of money just shaving down the locking nuts and reselling them. Lol
Thanks again for all your help!
I'd really prefer not making a living shaving people's nuts. More than glad for a friend but if I slip shaving other's than I dont want to hear them scream
Old 04-17-2016, 07:37 AM
  #162
Z1NONLY
Z1NONLY's Avatar
Lol
Old 04-18-2016, 10:32 AM
  #163
3hree5ive0ero
Retired Admin
3hree5ive0ero's Avatar
Nice little update.
Old 04-19-2016, 05:50 AM
  #164
jledford
jledford's Avatar
Do you know the thread pitch on the ball joint mounting rod?
Place like McMaster, Fastenal, etc sell jam nuts that are thinner than normal nuts. If the thread pitch is known it might be as easy as ordering up some nuts from one of those places.
Old 04-19-2016, 05:58 AM
  #165
ian99rt
ian99rt's Avatar
Both ends of the ball joint are 3/4 - 16 thread. The threads into the a arm already have a thin nut, McMaster did not have anything thinner, so milled them down to about 2.5-3 threads ( approx .275" total thickness)
jledford (04-19-2016)
Old 04-19-2016, 07:45 AM
  #166
jledford
jledford's Avatar
Thanks, that's good info to know. Looks like I'll have to modify the standard nuts when I install mine so I don't have to pull them back off later.
Old 05-18-2016, 04:05 PM
  #167
Flier129
Flier129's Avatar
So I'm reading a thing andddd my stomach just dropped. Hope all is well...
Old 05-21-2016, 06:08 AM
  #168
Z1NONLY
Z1NONLY's Avatar
The good news is the alignment was a success. I was able to pax 12th overall at the Bristol Match tour with just average driving.
The bad news is a friend of mine totaled the Z (and almost himself) at ZdayZ, just days later. He is now out of ICU and is expected to be fine.
NA&CH (05-25-2016)
Old 05-23-2016, 08:37 AM
  #169
SilverGLE
SilverGLE's Avatar
Jesus!
Sorry to hear about your friend! Cars are just things, people aren't.
NA&CH (05-25-2016)
Old 05-24-2016, 07:48 AM
  #170
Glenn350zHR
Glenn350zHR's Avatar
Oh no! Sorry to hear about this man. Thank god your friend is ok. I know what your going thru with the car. Happened to me in April. My Z was totaled by a driver not paying attention on the highway that traffic had stopped at a toll booth and he rear-ended me. If you are able to salvage any of your parts like I was you can find another Z. I ended up finding another 2008 base coupe with 30k miles and transferred over all my STU parts in a 4 day build and made it to the Wilmington Pro. Now i am changing out a clutch after that event lol.
where there is a will there is a way
Old 08-08-2016, 05:51 AM
  #171
lufkom
lufkom's Avatar
Just read this whole thread, lots of good info in here. This is my second season driving is CS. I am going to move the car into STU, I am trying to compose a list of parts to start off with, I am learning a lot from all of you, so thank you for sharing! I plan to drive at some national events next year for the first time, hope to see some of you at the events. Again, thanks for sharing your build stories/specs.
~Jayme
Old 12-10-2016, 06:46 PM
  #172
ian99rt
ian99rt's Avatar
For those following this thread:
I got to drive Mike's car with the last setup before it was totaled.
Our autocross test and tune course is approx 37 seconds for the average car as background.
His car felt like it was literally 2 feet shorter and slalomed like a miata, it was simply amazing.
My Z is no longer daily duty so i'll be mirroring his alignment in the coming weeks. I'm also running the exact same revalved koni coilover and swaybar setup.
NA&CH (12-11-2016)
Old 12-11-2016, 01:30 PM
  #173
NA&CH
NA&CH's Avatar
And a Nismo....
Chris
Old 12-11-2016, 02:00 PM
  #174
ian99rt
ian99rt's Avatar
Originally Posted by NA&CH
And a Nismo....
Chris
Donno if your weak springs can handle this setup.
Old 12-13-2016, 02:40 PM
  #175
NA&CH
NA&CH's Avatar
They did fine at states
Chris
Old 12-13-2016, 04:07 PM
  #176
ian99rt
ian99rt's Avatar
Chris
Thats what I get for trying to get the last out of a set of tires. You know full and well with fresh tires I'd have had both you and Chris in the S2k
Old 12-17-2016, 05:42 AM
  #177
NA&CH
NA&CH's Avatar
What if I had fresh tires ??? I think driver mod took over hahaha. It would have better for both of us.
Chris
Old 12-17-2016, 05:46 AM
  #178
ian99rt
ian99rt's Avatar
Chris
I think December's event showed that theory's result.
Old 12-19-2016, 10:05 AM
  #179
dennisb40
dennisb40's Avatar
I want to join the fun. Just picked up an 2007 350z Enthusiast. Planning to do a STU prep within 2 years due to budgetary limitations. I have read through all the posts, tons of good info here.
Plan: Get wheels and tire and LSD this year. Suspension tuning next year.
How bad is the stock suspension on big square rubber?
I want to get a feel for the car and build it smartly.
Old 01-03-2017, 05:08 PM
  #180
Z1NONLY
Z1NONLY's Avatar
Square wheels and tires should take care of the factory understeer, but shocks from 2007 are probably a bit worn at this point and bigger, sticky tires will probably amplify the situation.
That being said, the LSD and tires will probably cut your times better than a new suspension. (As long as your existing shocks are not completely shot)
I would also consider alignment parts. (Adjustable front A-arms in particular) Stock suspension lacks camber and will eat your tires on course.
Quick Reply: My STU build
