Spddracer/CuztomPartZ Aluminum Engine Undershrouds are READY!
#141
How did I miss this? Nicely done - ordered. THANK YOU! Does the hardware kit include new "retainers" for the bolts to latch on to?
EDIT: Just read that the "j-nuts" are included in the hardware kit - thanks.
EDIT 2: So what about that little front "chin" that scrapes on everything - is that an aero part that attaches to this or do you get rid of it entirely?
And thanks for the order!
#143
If so the pan will fit if the bar normally mounts in this location VS being in front of the control arms.
If it can be moved to the rear of the lower control arm the pan will fit no problems.
http://www.photodump.org/stored30/gtspec.jpg
#147
on
GTSPEC lower Front Tie Brace
Yes that is the correct position and if you can verify by going to GT Spec's website and they have a pic of the brace installed in same location. So If I send you a template of the gap between my longnose bumper and the stock undershroud, can you make me a piece to fit with your shroud? Let me know.
#148
#150
on
Think mine is on the front.. I'll have to double check and fix it if that is the case. I got the undershroud last week, just haven't got around to installing it yet. Waiting until my exhaust comes in so I don't need to put it on a lift multiple times.
#152
I have one bumped and bruised 350Z aluminum underpan shield here for CHEAP! Return that customer could not use came back already mounted and scratched up a bit
A few light marks on it keeps me from selling as new!
First $175 + ship gets it!
SOLD!
SOLD!
#154
on
Wanted to confirm the GT Spec V2 front tie bar will fit if it goes behind the control arm, except the tie bar rubs against the boot for the tie rod (atleast on the G35 Coupe). I took the tie bar off for now cause I'm unsure if it rubbing against the boot is good or not.
The undershroud looks great though!
#155
Thanks for the update. It looks like on GTSpecs website that they do mount it on front of the cross member and not the rear. If you have the Version 1 tie bar that doesnt sit as low the shield works perfect!
All versions of the shields are part of the grand opening sale at www.ZSpeedperformance.com!!
#159
Just installed my undertray on my G35 coupe (has a JWT TT kit, oil pan spacer, and fumoto quick oil drain valve) and it fit perfectly. I am very impressed. The 2 piece design with the nicely slotted drilled holes allows for perfect alignment without any buckling or tension. The quality is so much higher than the OEM piece, I am floored.
The hardware kit is also very nice. The screws go in nicely without catching and ripping apart the bumper like the OEM ones did...
Thank you for providing such a high quality part at a reasonable price!
#160
Thanks for the review! Love the positive feedback! Enjoy!
