HOW2: Remote Key Fob Programming
Just FYI, you can use it on any NISSAN fob. I took one of my dad's old fobs out of his drawer to his old Armada and it worked, also got one from his Murano and it worked. So, now I have 3 fobs For whatever reason
MrNorwall, is the keyfob for murano a new one like this one?
http://www.nissanusa.com/img/vehicle...ote_keyfob.jpg
maXmood said the new altima keyfob won't work w/ the z but u said any nissan
keyfob works with it so now i'm confused... can anyone please verify? Sorry if this was already discussed.. I've been trying to search but no luck.
on
I just got back from the dealership. The shop manager and I are kinda tight, and instead of charging me $60 to program my remote like they normally would he said he'd take care of it for me. So as the shop manager and I were walking to my car with the new remote, I just asked him out of curiosity how to program the remote, and he told me exactly what is contained in the above post, EXCEPT that the number of times to insert and take out the key was 7 times, but everything else is the same. Hope this helps you guys out that are having problems.
Btw, my car is a 2005 with a model #ASTU15 remote. I don't know if this procedure is specific to my remote/model year, but the way he made it seem, it wasn't. So I think it'll work with other Nissans/model years.
on
Ryan
on
Tried this in my Z350 2003 Track but it did not work - instead of the lights flashing - the doors would unlock and will not enter the programing mode. Any ideas? how i can make it work. I have seen other peole in the net having the same issue but no solution was suggested.
1. Close and lock all doors with the driver’s side power lock/unlock switch.
2. Insert key in ignition and remove it from the ignition key cylinder a minimum of six times within 10 seconds. Your hazard lamps will flash if you have performed this step successfully. (Withdraw key completely from ignition cylinder each time). If this procedure is performed too fast, system will not enter programming mode.
3. Insert key into the ignition cylinder and turn to ACC position.
4. Within 5 seconds, push any button on the keyless remote. Your hazard lamps should flash. (Do not press the button more than one time in the above step). If the button is pressed more than one time, the programming procedure will not be successful.
5. If there are any remaining remotes (including the old ones), unlock then lock all doors using the driver’s side power lock/unlock switch. Within 5 seconds, push ANY button on the next remote. Your hazard lamps should flash. Repeat this step for each keyless remote (including any existing keyless remotes).
6. Turn the key to the OFF position, remove keys from the ignition, unlock doors using the driver’s side power lock/unlock switch and open the driver side door.
Done
Done
General & Tech Moderator
on
quick question i just programmed my key fob. seems like the old factory one works very well compared to the ebay key fob. i have to hold the lock/unlock button on the new key fob to get it to work compared to my old 1 all i have to do is press the button. am assuming this is common with the new fobs?
#39
#40
on
can you show your new fob? im interested in replace the ugly stock one.
