You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I did a search for a DIY/"How-To" guide on removing the stock side skirts and didn't find anything with pics, so I decided to make one as I removed mine. As others had mentioned in the threads that my initial search brought up, it's a pretty simple process that should take you about 10 minutes per side.
Tools: You really only need a 10mm socket (deep one if you got it), a small screwdriver and maybe a pair of pliers.
Overview The picture below shows the approximate location of the fasteners that secure the skirts to the car. There are six (6) 10mm bolts and four (4) "Pop Rivets" along the bottom and ends of the skirt.
Step 1. It's probably easiest to remove the "Pop Rivets" first. There are two in the front (location #s 7 & 8 from the above picture) and two in the back (#s 9 & 10). To remove them, stick a screwdriver in one (or more) of the four slots and "pop" the center cap out. Once it's out far enough, you can remove the pop rivet.
Step 1a. For some reason (more than likely just to be a PITA) Nissan decided to use one of the Pop rivets underneath the car at the front of the skirt (#7) so you kind of have to remove that one "blind". The other three (inside the wheel wells) are simple.
Step 2. Removing the remaining 10mm bolts is very simple. If you have a "deep" 10mm socket this will make life a little easier as the handle to the driver will be below the bottom of the skirt. You can also use a phillips screwdriver if you have one the right size.
Step 3. Now that all fasteners are removed, you can start to peel the side skirt away from the car. Just like removing a door panel, you want to get the right angle and slowly pop the clips that hold the top of the skirt to the car. Start at the front of the car and slowly move backwards. The back three clips are a little different than the front ones, but pop out the same way.
That's it, you're done. BTW, here is a final picture of the inside of the skirt that may help you understand how the skirt is clipped and bolted to the car. Hopefully this helped someone.
__________________ 2004 Honda CBR 600RR current 2009 Suzuki DL650 V-Strom current 2009 Subaru WRX - current 2011 Nissan Pathfinder 4x4 current 1975 Datsun Fairlady Z RHD Project 2004.5 Nissan 350Z (gone, but not forgotten) 2008.5 Nissan Titan(Goodbye my monster truck)
Hey, do you guys happen to have a thread on installing the aftermarket skirts? Like, do you use the factory clips or just 3m the new skirts and drill holes on underside to bolt to factory holes?
Ya thanks, it helped me. I just posted a few days ago asking how to do this.
So taking these sides off doesnt look all that hard..but how hard would it be to put nismo sides on?? Thanks to anyone who could help me out eith this question.
I got NISMO sides at home too, but I still need them to get prepped and painted -- I'm waiting for my NISMO V2 front bumper to get them all painted at the same time. I was going to have a go at both before paying a bodyshop -- installs look pretty straight forward for both. What are your reservations? PM me.
