Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > Do It Yourself Guides > Body, Interior, Exterior & Lighting (DIY)
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 03-01-2007, 01:30 PM   #1
03Zilverstone
03Zilverstone's Avatar
Default How to: mold a body kit
My dad bought a crappy Nismo replica back when he was fixing his car. The fitment was horrible, so we put it up in the barn. Well I decided to do a little something with it. I'm going to mold the rear into the bumper cover. The flares on the side skirt will be cut off and molded onto the stock skirts. The fitment was so bad that there was almost no way to get it to look right by fitting the skirt. This will make it stronger than a regular FPR skirt, since it has the urethane backing. I'm not even going to mess with the front bumper cover. It would be a waste of my time to fit it and have it break the first time out. I'll probably pick up a V1 replica from Evo-r. I'll also be adding a G spoiler.
__________________
'03 Chrome Silver Enthusiast (#09337) 19" Ruff Racing 277, Injen Super SES, Nismo sides, V1/TN/custom paint to come
03Zilverstone is offline   Reply With Quote
Old 03-01-2007, 01:31 PM   #2
03Zilverstone
Here's where we start. The bumper cover was off a parts car and I know there are a few dents in it. Those will be fixed after I take care of the flares.
__________________
Old 03-01-2007, 01:33 PM   #3
03Zilverstone
Next you will position the flare on the cover where it needs to go. Use some tape to mark the edge of the flare. You will need to allow an extra half inch or so. You'll see why later.
__________________
Old 03-01-2007, 01:35 PM   #4
03Zilverstone
Now you will drill some holes through the flare about an inch apart on the outer edge. This will aid the adhesion.
__________________
Old 03-01-2007, 01:36 PM   #5
03Zilverstone
Now place the flare on the cover again and mark what needs to be trimmed on the inside part where the fender well is.
__________________
Old 03-01-2007, 01:37 PM   #6
03Zilverstone
Trim the flare and place it up to make sure the cut is right. I used a pnuematic cut off wheel.
__________________
Old 03-01-2007, 01:40 PM   #7
03Zilverstone
Here's where the tape comes into play. You will need to sand down the area that the adhesive will bond to. The adhesive I used recommended 80 grit, but I went ahead and used 36 since I'll be putting some kitty hair on it to get the mold smooth anyway. Also make sure you go down to the urethane. The adhesive will bond a lot better to that than paint. The reason I didn't go all the way through in the middle is because the adhesive probably won't seap that far down, but if it does sanding it will give it a little something to bite to. Also wipe the area down with a pre paint cleaner before you try to bond the flare. I use PPG Acryli-Clean.
__________________
Old 03-01-2007, 01:44 PM   #8
03Zilverstone
Now you'll start to bond the flare to the cover. You'll want to do a section at a time, since the flare won't fit perfect against the bumper cover. I found it best to start at the fender well area. Be sure to hold the flare in place until the adhesive gets hard. Also don't rely on tape. I just put that on there as extra precaution after I held it until I felt it was hard enough.
__________________
Old 03-01-2007, 01:46 PM   #9
03Zilverstone
Here it is with the first section dry. This pic shows why it's easier to do a section at a time.
__________________
Old 03-01-2007, 01:48 PM   #10
03Zilverstone
Now I'm working the rest of the top part. Again hold it until it's fully hard. If you let go to soon the flare will pull out an make that area stick out.
__________________
Old 03-01-2007, 01:52 PM   #11
03Zilverstone
Now that the top is secure we can work on the bottom. This lip is a little off and excessive anyway. I'll just cut part of it off.
__________________
Old 03-01-2007, 01:55 PM   #12
03Zilverstone
Now we've got the driver's side rear flare fully bonded. The other side will be done the same way.
__________________
Old 03-01-2007, 02:19 PM   #13
03Zilverstone
I've got to go to a play now. I'll post updates as they come.
__________________
Old 03-02-2007, 01:19 PM   #14
03Zilverstone
On to the side skirts. We all know how they start out.
__________________
Old 03-02-2007, 01:21 PM   #15
03Zilverstone
I cut it right along the line in the skirt that runs parallel to the door. I also cut it at the bottom right at the edge where it starts to curve back up.
__________________
Old 03-02-2007, 01:24 PM   #16
03Zilverstone
(Not pictured)
Just like the rear flare drill holes every inch or so close to the edge, then sand the inside edge.
__________________
Old 03-02-2007, 01:26 PM   #17
03Zilverstone
Mark off and sand the rocker moulding where adhesive will go. Also trim the ends of the flares to sit flush with the rocker.
__________________
Old 03-02-2007, 01:28 PM   #18
03Zilverstone
Clean the rocker and flare edge and start bonding it doing about a foot at a time. Be sure one section fully hardens before moving on. I found it best to start at the top front.
__________________
Old 03-02-2007, 01:32 PM   #19
03Zilverstone
When done with the top and ends remove the rocker moulding. Now you can bond the bottom section. Because of the excellent fitment of these replicas I have an inch gap in the middle of the bottom side. That will be taken care of later with a little fiberglass mat and resin.
__________________
Old 03-02-2007, 03:42 PM   #20
Mazinger Z
Mazinger Z's Avatar
Points: 9,084, Level: 64
Points: 9,084, Level: 64 Points: 9,084, Level: 64 Points: 9,084, Level: 64
Today's Activity: 1.1%
Today's Activity: 1.1% Today's Activity: 1.1% Today's Activity: 1.1%
Damn where'd you get that kit. Please tell so we don't buy from them.
__________________
35th_SS 6MT
Volk - Borla - Nismo - Motordyne - Hotchkis - Tokico - Fiber Images - Evo R - Data Systems - Fast Intentions - Alpine - Kicker - Infinity
"Kids Shift Gentle"
Mazinger Z is offline   Reply With Quote
My350Z
350 Z
Paid Advertisement
Tags
19, 277, body, diy, fiberglass, flares, forum, kit, lip, mold, molded, molding, ruff, sale, urethane
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
