Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > Do It Yourself Guides > Body, Interior, Exterior & Lighting (DIY)
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 01-13-2008, 01:59 PM   #1
Mr.
Points: 1,705, Level: 24
Points: 1,705, Level: 24 Points: 1,705, Level: 24 Points: 1,705, Level: 24
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
Thumbs up Home Fabricated License Plate Bracket
This is an alternative to the Z-Bracket/zipties/drilling your bumper. I was running zipties since I bought the car and was not satisfied with the appearance, so I decided to make this. This mod is cheap, easy, gets the job done, and looks clean. It's worth mentioning that this DIY is meant for 06+ bumpers. 05's and under may have to drop their bumper, but I don't know how much clearance you guys have. Let's begin...
Tools:
-Drill with 1/4inch drill bit intended for metal drilling
-Saws-all[you can substitute this with a hacksaw, dremel tool, chopsaw(easiest), or any other tool that can cut through metal; a metal file can even be used]
-Four 8inch by 1/4inch bolts with their matching 1/4inch nuts (try to find galvanized ones to prevent corrosion); You could get away with using slightly shorter bolts if you can't find 8inchers. I didn't pre-measure, so I went with the longest bolts I could find with a 1/4inch diameter
-A piece of aluminum(no shorter that 1 1/2feet and no thinner than 1/8inch. I found a 4foot by 1/8inch piece as I was walking through Home Depot. You can substitute the aluminum with another metal or plastic, but this may create more difficulty. Aluminum doesn't corrode and is a very soft metal, so it's easy to work with.)
-Safety glasses
-A marker
-Your license plate.
Here is a picture of the materials.
Step 1 : Use your license plate as a template to mark off the holes(that you will drill) and end points(where you will cut) on the aluminum like this
Step 2: Drill the holes with your 1/4inch drill bit. When you are done your aluminum piece will look like this
Step 3 : Cut the aluminum into two pieces across the lines that you marked off with your saws-all/cutting device. Optional step - grind or file the pieces to clean up the sharp edges. This is what you will end up with
Step 4 : Test fit your parts by assembling them off of the car. Back view
Front view
Step 5 : Put one of the 8inch bolts through either one of the top corner holes in the license plate. Now take one of your aluminum pieces that you drilled/cut and slide it through the middle gap between the two bars in the bumper(don't let it drop!) and push the bolt through the hole that you drilled. Once you have done this, take your nut and secure it from the back side. (Optional step : if you're worried about scratching your bumper where the license plate touches it, you can lay down a bead of silicon caulking or rubber weather stripping on the two bars to act as a cushion) It will look like this
Step 6 : Do the same for the bottom corner. It will look like this
Step 7/8: Repeat step 5 and step 6 on the opposite side. You're done! Admire your work
I wear a men's size large glove, and my hands endured only minor scuffs. You can do it!
__________________
2008 Magnetic Black Enthusiast 6MT
Mr. is offline   Reply With Quote
Old 01-13-2008, 06:10 PM   #2
DaveZ06
DaveZ06's Avatar
nice project, but maybe consider putting some eletrical tape on the screws?? looks like you could be scratching your bumper.
__________________
DaveZ06 is offline   Reply With Quote
Old 01-14-2008, 09:52 AM   #3
Mr.
Quote:
Deleted my original response. Scroll down to see a close-up of the bolt.
__________________
Old 01-14-2008, 03:28 PM   #4
Mike_G
Mike_G's Avatar
Points: 2,187, Level: 28
Points: 2,187, Level: 28 Points: 2,187, Level: 28 Points: 2,187, Level: 28
Today's Activity: 0.4%
Today's Activity: 0.4% Today's Activity: 0.4% Today's Activity: 0.4%
Or some black surgical tube/vac line would clean it up nice...
__________________
If It doesnt have a motor,Its not a sport. Its just a game...
Mike_G is offline   Reply With Quote
Old 01-15-2008, 03:25 PM   #5
kelsey_kaye
LoL.
kelsey_kaye's Avatar
Points: 2,033, Level: 27
Points: 2,033, Level: 27 Points: 2,033, Level: 27 Points: 2,033, Level: 27
Today's Activity: 5.0%
Today's Activity: 5.0% Today's Activity: 5.0% Today's Activity: 5.0%
you really could just use long enough bolts that are only threaded at the ends.
kelsey_kaye is offline   Reply With Quote
Old 01-23-2008, 03:46 PM   #6
Mr.
I made a mistake when I said that the bolt touches the top. It doesn't. There is about 1/4 inch of space between the the bolt and bumper. The picture was taken at an angle that doesn't show the gap. Here is a close-up view
__________________
Old 03-14-2008, 09:50 AM   #7
SA Z-boi
SA Z-boi's Avatar
Points: 2,744, Level: 31
Points: 2,744, Level: 31 Points: 2,744, Level: 31 Points: 2,744, Level: 31
Today's Activity: 13.7%
Today's Activity: 13.7% Today's Activity: 13.7% Today's Activity: 13.7%
I did this DIY with my Euro plate it it came out awesome, Ill post pictures when I get them. thanks for a good write up
__________________
03 PPW PERFORMANCE Z|HKS |JT-X|JWT|CRAWFORD|RH-PRO R5|8000K HID|ULTIMATE RACING|EVO-R|JAPTRIX|NITTO|MASTERGRADE|ING +1 N-SPEC|NISMO|TANABE|STILLEN|SPC|
SA Z-boi is offline   Reply With Quote
Old 03-14-2008, 06:03 PM   #8
Mr.
Quote:
__________________
Old 03-29-2008, 06:21 PM   #9
krnzzang84
krnzzang84's Avatar
Points: 1,686, Level: 23
Points: 1,686, Level: 23 Points: 1,686, Level: 23 Points: 1,686, Level: 23
LOL never got pulled over because of no front license plate/tint.
__________________
2003 Chrome Silver Track Edition with 009 Trans.
krnzzang84 is offline   Reply With Quote
Old 03-29-2008, 06:30 PM   #10
Mr.
Quote:
I've been pulled over, but let off with a warning for tints, and I know someone that got pulled over for no front license plate. It depends on where you are and who you're dealing with. I'd rather not get hassled, or deal with the thought of possibly getting hassled. LOL.
__________________
Old 08-22-2008, 10:35 AM   #11
nasty350
nasty350's Avatar
where is the pic?
__________________
04 350z Silver
nasty350 is offline   Reply With Quote
Old 12-07-2008, 05:35 PM   #12
SA Z-boi
SA Z-boi's Avatar
__________________
Old 01-02-2009, 04:55 AM   #13
Mr.
Came out nice
__________________
Old 02-28-2009, 10:39 PM   #14
fatjoe
Points: 2,047, Level: 27
Points: 2,047, Level: 27 Points: 2,047, Level: 27 Points: 2,047, Level: 27
Today's Activity: 0.7%
Today's Activity: 0.7% Today's Activity: 0.7% Today's Activity: 0.7%
Default hey! Hey!! HEY!!!
I just registered my car in Texas yesterday. It's amazing that I made the same thing today for my Z and came on the site to see that someone had the same great idea.
My Z is going to benifit from it because I mounted in front of my INJEN cai. This will shield some of the rain.
Nice write up. The only difference is with mine, I put the brackets the long way behind the plates and cut some rubber the same shape as the plate to prevent the plate from scratching the bumper.
If someone else tries this, go to Home Depot and you'll find some metal braces for the backing in the area where the wood is. It has pre-drilled holes for $.89.
fatjoe is offline   Reply With Quote
My350Z
350 Z
Paid Advertisement
Tags
350z, bolts, bracket, diy, drill, drilling, euro, evo, front, g37, holder, license, magnetic, mount, plate, plates, putting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
