Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > Do It Yourself Guides > Body, Interior, Exterior & Lighting (DIY)
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 06-07-2008, 10:38 AM   #1
Points: 3,566, Level: 37
Points: 3,566, Level: 37 Points: 3,566, Level: 37 Points: 3,566, Level: 37
Today's Activity: 0.7%
Today's Activity: 0.7% Today's Activity: 0.7% Today's Activity: 0.7%
Default DIY: How to install Aerocatch hood pins!!
well i thought it would be a good idea to do a DIY on how to install aerocatch hood pins,since so many people asking on how to do(itīs not that hard as it looks like).
i didnīt had a camera near by as i installed the hood pins, so iīll use several pics of cars with them on.but enough talked now weīll go on.
TOOLS NEEDED: a Dremel, several drills and some tools to tighten the hood pins
STEP 1: remove your stock hood and put your new aftermarket hood on by loosen the 4 nuts (ask someone for help, cause itīs nearly impossible to do this on your own).
STEP 2: now through on your new hood and make sure it cleares the strut and other parts of the engine bay.take a look on how the surface bend or not(a helping hand is also needed a second wrench is also very helpfull)
STEP 3: if the hood cleares just try to lock the hood, just to make sure it locks at all. if not take a closer look at the clearence of the hood (maybe you have to cut out some portions of it, if you wnat to.if not use some washers to raise to hood a little bit or just adjust the hood lock assembly)
STEP 4: now would be a good time to have a closer look on where to install the studs at.nissan did a great job on that just use the 2 holes allready drilled (marked on the pic)
STEP 5: put the studs in the holes (the driver side pin needs to be cut down to fit. about 1 cm).you donīt have to tighten them. just trough them in and fine for now.
STEP 6: (hood open as shown on pic) now measure the distance(as shown on the pic).use the upper part of the stud and measure down to the front bumper and the head light(just mark the point where you measured at)
STEP 7: now close the hood and measure out the poitn where the stud should be (you need to remove the stud to be able to close the hood).mark the point and drill your first hole into the hood .itīs regardless what size the drill has, since you just need the hole to look where you have to place the hood pin template.be very carefull while drilling the hole, cause you donīt want to crack your hood(even more careful while drilling into cf.maybe use a drill for wood).now it should look like this.
STEP 8: now open the hood, through the sutds in the holes and close the hood(if itīs possible. if not you maybe have to drill bigger holes) if your fine go on to the next step.
STEP 9: now this is the most important step. now lay down the template which was provided with the aerocatch hood pins (maybe tape it down).
the cross hair has to aim at the center of the studīs head.
and this is the point where i "failed" at. you donīt have to forget that the aerocatch assembly will sit 2cm lower then the template!!!! which means that you have to place the cross hair a little bit more towards the windshield of the car(more off center of the stud).donīt ask me how far, cause i donīt have a f+#king clue .
could be just some mm or even some cm.guess you have to figure out how much or you have to modify the aerocatch hood pins to fit.
STEP 10: now cut out the hole for the aerocatch hood pins using the dremel.
i had to cut trough two seperate layers of fibre glass on my ING`S hood.be carefull while youīre cutting not to damag the hood.just take little by little or the hole could be to big for the aerocatch.
STEP 11: now the moment of truth . this is the point where youīll see if all worked out fine or you just failed. through in the studs (adjust the hight of the stud), tighten them (you have to remove the air box and the water tank to tighten the studs), close the hood and put the aerocatch (in open position) into the hood and have a look if everything fits just fine.if not donīt get pissed, thereīs still a way to fix it(so i did).just modify the aerocatch and the stud (maybe bend it or just remove some material from it).this step could use some time since itīs a try and error one . it took me about 1 h for each side .
STEP 12: now that the aerocatch fits and works fine itīs time to bolt them down.close the hood, through the aerocatch in and close it.mark the 6 holes and carefully drill them.after youīre done use the provided bolts and bolt the aerocatch to your hood.
STEP 13: have a look at your work
now youīre done. youīll maybe have to do some adjustments and youīre really done with it, but thatīs it.
here is a litlle reference how the installed studs should look like.
i hope itīs understandable (sorry for my poor english).
itīs not that hard to install them if you have the right tools by hand and some time to do install.
if thereīre still some questions or i just forgot something, just let me know.
cheers and have fun
__________________
.::VOLK\\KW//INGīS\\AMUSE//StopTech\\ARC//Gruppe-M::.
XM 1 is offline   Reply With Quote
Old 07-11-2008, 10:58 PM   #2
microsteve40
Know it all
Points: 3,925, Level: 39
Points: 3,925, Level: 39 Points: 3,925, Level: 39 Points: 3,925, Level: 39
Today's Activity: 1.4%
Today's Activity: 1.4% Today's Activity: 1.4% Today's Activity: 1.4%
Send a message via AIM to microsteve40 Send a message via Yahoo to microsteve40
This is awesome man! Thanks a lot for this write up!
Oddly enough, I bought the same hood, and I should have it in my greedly little hands by the end of the month!
Where'd you get the aerocatch pins from? I'm looking for a set right now!
microsteve40 is offline   Reply With Quote
Old 07-22-2008, 10:22 AM   #3
got them from a vendor in germany i both the hood from
but i think you could order them direct from aerocatch
__________________
Old 07-22-2008, 11:39 AM   #4
rx7/350z
rx7/350z's Avatar
hugebulge
Points: 3,439, Level: 36
Points: 3,439, Level: 36 Points: 3,439, Level: 36 Points: 3,439, Level: 36
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
good job
__________________
Supercharged Brickyard 350z with a ton of miles and lots of other stuff....
rx7/350z is offline   Reply With Quote
Old 12-16-2008, 05:19 PM   #5
Archaismic
Points: 1,944, Level: 26
Points: 1,944, Level: 26 Points: 1,944, Level: 26 Points: 1,944, Level: 26
Today's Activity: 0.6%
Today's Activity: 0.6% Today's Activity: 0.6% Today's Activity: 0.6%
Send a message via Yahoo to Archaismic
Default mwaaaaa
that's those damned hood pins!... i've been trying to figure out what the hell those were for the longest time (trying to figure what kind of hood pin not simply that they were hood pins)... thanks for that... i have my hood (the evil POS that is it) pinned on at all four corners with cam-pin locking hoodpins... the front ones were easy enough... though we made and mounted some brackets to tilt the stud perpendicular to that part of the hood... the back ones were a little more interesting though... maybe i'll do a right up on that sometime
Archaismic is offline   Reply With Quote
Old 06-15-2009, 12:08 PM   #6
SIR_pierre
Points: 2,329, Level: 29
Points: 2,329, Level: 29 Points: 2,329, Level: 29 Points: 2,329, Level: 29
i would really like to see the pics
SIR_pierre is offline   Reply With Quote
Old 06-16-2009, 08:40 PM   #7
*ICE*
*ICE*'s Avatar
Points: 3,175, Level: 34
Points: 3,175, Level: 34 Points: 3,175, Level: 34 Points: 3,175, Level: 34
Today's Activity: 13.5%
Today's Activity: 13.5% Today's Activity: 13.5% Today's Activity: 13.5%
damn pics are gone!! anyone got a good instruction to do this?
__________________
*ICE* is offline   Reply With Quote
Old 11-24-2009, 03:46 PM   #8
350zfriendteach
gay
350zfriendteach is offline   Reply With Quote
Old 01-04-2010, 07:58 AM   #9
McLovin350Z
McLovin350Z's Avatar
Points: 1,676, Level: 23
Points: 1,676, Level: 23 Points: 1,676, Level: 23 Points: 1,676, Level: 23
can we get the pics back?
__________________
McLovin WTB the 3.3 FD, no pumpkin just the gears
McLovin350Z is offline   Reply With Quote
Old 08-07-2011, 05:56 PM   #10
blAk mAx
Points: 1,802, Level: 25
Points: 1,802, Level: 25 Points: 1,802, Level: 25 Points: 1,802, Level: 25
Today's Activity: 3.2%
Today's Activity: 3.2% Today's Activity: 3.2% Today's Activity: 3.2%
say whaaaat?
__________________
95 modded black maxima, 04 black G35 *If you can't TIP, don't use the service!!!*http://www.youtube.com/watch?v=KWWKzEkr9Iw
blAk mAx is online now   Reply With Quote
My350Z
350 Z
Paid Advertisement
Tags
aerocatch, bolt, g35, hood, infiniti, instal, install, installation, locking, locks, pin, pins, sale, size, vid
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright Đ2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
