Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > Do It Yourself Guides > Body, Interior, Exterior & Lighting (DIY)
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 06-16-2008, 03:11 PM   #1
Greg'Z33
Points: 5,898, Level: 49
Points: 5,898, Level: 49 Points: 5,898, Level: 49 Points: 5,898, Level: 49
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
Default DIY: Z31 retro-look for OIL & VOLTS gauge pods
I always liked the look of the 1984-1989 300ZX center gauge pods with the OIL and VOLTS sitting in little recessed windows and backilt by the cluster lighting, as opposed to the 350Z's with the words just silk-screened on the front of the cluster lid. I decided to modify my 2006 350Z GT to achieve that look. If you want to do something similar, you'll need to buy the oil & volts center gauge cluster from a 1984-1986 300ZX with analog gauges which had orange gauge faces. You can pick them up on ebay anywhere from $10 to $30 from either private sellers or salvage yards. You'll first start by removing your 350Z center console housing to get access to the triple gauge cluster. An excellent write-up can be found here:
http://liljerk.morpheus.net/350Z/dash_removal/
Z31 center gauge cluster:
The OEM cover for comparison:
You'll have to cut out a rectangle in the the 350Z cluster cover the same size as the one on the 300ZX cover. I tried but the results were not up to par so I ended up having a commercial sign lettering shop cut two 1/8" thick overlays in matte black acrylic. The texture and look is almost dead on to the factory plastic. I left my 350Z cover with them so that they could get the dimensions of the openings. I then used some two-part epoxy to secure them inside the cluster cover.
Custom made overlay:
The 300ZX cluster cover is held on by a couple of screws in the back and then secured by four snap tabs. Once the cover's removed, you'll have access to the OIL and VOLTS appliques which you will use in the 350Z cluster cover.
Remove OIL & VOLTS appliques from 300ZX cluster:
Place the appliques so that OIL & VOLTS are centered in the window. I used a pencil point soldering gun to tack weld the applique to the back of the cluster cover:
Finished overlays:
To backlight the appliques, carefully cut out (I used a Dremel with a small drill bit) the gauge pointer cover along the outer perimeter except for the 3 o'clock and 9 o'clock positions. This will allow light from the pointer LED to illuminate the backside of the applique. I do not recommend removing the pointer needle as it will be difficult, although not impossible, to get the proper gauge readings.
Drilled out pointer cover:
You'll need to cut out and place an opaque piece of flat plastic over the cut out pointer cover. This will help diffuse the light. I did not take a picture, but I used a coffee can lid that was transluscent, but not see through. I used small dabs of two-part epoxy to hold it in place. After the epoxy dried, I used compressed air to gently blow the dust and plastic shavings off of the front of the gauges then re-assembled the modified cluster cover and lens back onto the cluster assembly.
Finished product:
I placed the cluster back into the dash and checked to make sure the gauges still worked and to see how well the backlighting looked. The lighting was not perfectly uniform because of the partially obstructed pointer cover but it's not objectionable.
Modified cluster back in place:
With headlights on:
All in all, I'm very pleased with the outcome. This is the way Nissan should have done it, in my opinion.
Greg
Greg'Z33 is offline   Reply With Quote
Old 06-16-2008, 03:40 PM   #2
Paul350Z
Living in 350Z
Paul350Z's Avatar
Nice work!
__________________
Super Black 2005 35th Anniversary
Paul350Z is offline   Reply With Quote
Old 06-16-2008, 03:42 PM   #3
Mike Wazowski
Mike Wazowski's Avatar
Points: 99,594, Level: 100
Points: 99,594, Level: 100 Points: 99,594, Level: 100 Points: 99,594, Level: 100
Today's Activity: 11.0%
Today's Activity: 11.0% Today's Activity: 11.0% Today's Activity: 11.0%
very cool looking
__________________
2004 Honda CBR 600RR current
2009 Suzuki DL650 V-Strom current
2009 Subaru WRX - current
2011 Nissan Pathfinder 4x4 current
1975 Datsun Fairlady Z RHD Project
2004.5 Nissan 350Z (gone, but not forgotten)
2008.5 Nissan Titan(Goodbye my monster truck)
Mike Wazowski is offline   Reply With Quote
Old 06-16-2008, 08:09 PM   #4
grumpysmurf
grumpysmurf's Avatar
very original! You've more patience than most.
__________________
08 350 Enth
90 300 n/a
grumpysmurf is offline   Reply With Quote
Old 06-16-2008, 08:34 PM   #5
Greg'Z33
Thanks for the compliments. What can I say, I'm an old school guy at heart. I like my mods a little on the conservative side and I really wanted it to look OEM. The coupe de grace for me will be getting the 81-83 280ZX Turbo NACA duct driver's side hood scoop and passenger side air duct installed on my 350Z; pics will be forthcoming when it's done.
Greg
Old 06-17-2008, 12:31 AM   #6
BRONZEE
Points: 3,735, Level: 38
Points: 3,735, Level: 38 Points: 3,735, Level: 38 Points: 3,735, Level: 38
Today's Activity: 5.6%
Today's Activity: 5.6% Today's Activity: 5.6% Today's Activity: 5.6%
Great to see the melding of the old and the new together!!! Nice work!!!
BRONZEE is offline   Reply With Quote
Old 06-21-2008, 06:09 AM   #7
Fletch69z
Fletch69z's Avatar
Points: 3,589, Level: 37
Points: 3,589, Level: 37 Points: 3,589, Level: 37 Points: 3,589, Level: 37
Today's Activity: 2.2%
Today's Activity: 2.2% Today's Activity: 2.2% Today's Activity: 2.2%
That's really cool! And I'm impressed that you put that much work into it for such a subtle change. It shows the love that these cars garner, .
__________________
2004 Infiniti G35x Sedan/STS rearmount turbo/Uprev/Motordyne/Megan Racing/Rotorpro
Fletch69z is offline   Reply With Quote
Old 10-15-2008, 10:39 AM   #8
white_sg
some one should do a diy on how to do the led conversion of the interior instead of paying hundreads of dollars to do it.
white_sg is offline   Reply With Quote
Old 10-29-2008, 10:42 PM   #9
sk26dett
sk26dett's Avatar
Points: 2,385, Level: 29
Points: 2,385, Level: 29 Points: 2,385, Level: 29 Points: 2,385, Level: 29
Send a message via AIM to sk26dett
^ wtf?
__________________
2003 Super Black 350z/ 1991 Cherry Red Metallic 240sx Coupe KA-T _GO GATORS!
sk26dett is online now   Reply With Quote
Old 10-30-2008, 11:53 AM   #10
samjcg
samjcg's Avatar
Send a message via AIM to samjcg Send a message via MSN to samjcg
cool but too much work for not much change.
+1 for creativity though
__________________
selling my Z
samjcg is offline   Reply With Quote
Old 10-30-2008, 02:02 PM   #11
MikeisNissan
MikeisNissan's Avatar
Send a message via AIM to MikeisNissan Send a message via Yahoo to MikeisNissan
i second that WTF?!
__________________
REPRESENT UNITY THROUGH VEHICLE
MikeisNissan is offline   Reply With Quote
Old 11-25-2008, 06:19 AM   #12
mi300zx
I know, this is "off topic". However, I need to find the vacuum boost guage routing information for my 1984 300ZX Turbo. Anyone, know where I can find this? My boost guage, is non-op, and I would like to trace this information down. Thanks
mi300zx is offline   Reply With Quote
Old 12-17-2008, 05:10 AM   #13
jewellz
jewellz's Avatar
Points: 3,377, Level: 36
Points: 3,377, Level: 36 Points: 3,377, Level: 36 Points: 3,377, Level: 36
Quote:
if you talking about the factory boost gauge, it's best to leave it alone and buy a boost gauge that actually works. my factory boost gauge reads about 8psi when i'm running 23psi. as far as info goes you can try these sites.
www.z31performance.com
www.z31.com
http://www.az-zbum.com/
jewellz is offline   Reply With Quote
Old 01-23-2009, 06:55 PM   #14
white_sg
response to the wtf's. I was referring to the people doing the z led conversions and charging people money insted of just posting a diy. an off topic statement I know.
__________________
Nismo.Alpine Type R.Rockford Fosgate.TC Customz
My350Z
350 Z
Paid Advertisement
Tags
1986, 300z, 300zx, 350z, center, cluster, diy, gauge, housing, light, rear, size, suspension, turbo, z31
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
