DIY: Black Housing
Old 02-13-2008, 08:57 AM
  #101
Mr.
Mr.'s Avatar
Should I use spray paint that is plastic-specific? I imagine regularly formulated paint would flake over time.
Old 02-13-2008, 09:19 AM
  #102
omega6
omega6's Avatar
Default ThanK you Laosifu
I decided to post pics during the process:
for original post with these pics : https://my350z.com/forum/northern-california/335856-cleared-out-my-headlights-finally.html
16
17
20
21
22
23
24
25
26
29
30
31
32
33
34
35
36
- I didn't have pics when I took part the headlights, cuz my hands and my brothers were busy pulling it part.
- Silcone FTW, no leaks or condensation for 1 month, it's even been out in the pooring rain the past weeks.
- I got chrome single bulbs from ebay: seller: rjcalnan, very cheap!
- LED's from superbrightleds.com $25 a bulb, $15 each flasher unit
- You can buy the reflector in clear or smoked from http://www.ricks2k.com/products/350zdiffusers.php $55, fast and friendly
- I didn't want to black them out, for some reason the '03- headlights look weird backed out for me...
- Thx Eric ZDiRty, for the links and tips
- I didn't take a pic of every process or screw, some of it's str8 foward (if u can build a gundam level 4+, then u can do this)
Laosifu, if you want the links to the pics, I'll be glad to give it to you if you want to place it in the original post.
Old 02-13-2008, 10:10 AM
  #103
Mr.
Mr.'s Avatar
Anyone?
Old 02-13-2008, 10:34 AM
  #104
LaoSiFu
LaoSiFu's Avatar
Any paint should do you really. According to my buddy Tienana who bought my black housing 5 years ago, still perfect.
Omega6,
Thanks for those pictures. Very detail and I would like to use them.
~Robert
Old 02-13-2008, 10:45 AM
  #105
TBDesigns
TBDesigns's Avatar
Anyone in So Cal that has done this and wants to make some cash let me know
https://my350z.com/forum/southern-california/335868-anyone-in-l-a-want-to-remove-my.html
Old 02-13-2008, 12:15 PM
  #106
omega6
omega6's Avatar
Omega6,
~Robert
sure PM me or something, my name is Robert too!
Old 02-14-2008, 04:57 PM
  #107
cheshirecat79
cheshirecat79's Avatar
Anyone?
I used some plastic-specific spray paint that I bought at Home Depot. It had pictures of lawn chairs and **** on the front but it ended up working fine.
I definitely recommend scuffing the inside with sandpaper and laying down primer. I put about 4 coats on mine.
Old 02-16-2008, 11:47 AM
  #108
Kgc_102
Kgc_102's Avatar
Can anyone give me some advice on how to get the grey plug that is attached to the headlight off? Its the piece that you actually plug in the blue connector from the car. I have all the bulbs loose, but I can't get the dang grey piece off. Any help?
Old 02-17-2008, 03:38 AM
  #109
omega6
omega6's Avatar
I had trouble pulling that out too, I just pulled really hard and it came out.
Before, I tried placing a flat head in that little slot thinking there was a clip, but that didn't work either. If I can remember i had to squeeze it on both sides went and pulled really hard. GL
Old 02-17-2008, 02:32 PM
  #110
LaoSiFu
LaoSiFu's Avatar
first time removing is always difficult. Just need to put your muscle to work.
Old 02-17-2008, 02:36 PM
  #111
Kgc_102
Kgc_102's Avatar
Oh I got it.....but at the expense of the little side clips that hold the clip on there, nothing a little super glue couldn't fix. Thanks for the info though! The guide was a real help. It was a little daunting at first, but a little patience and elbow grease will get you through! Thanks for the guide!
Old 03-01-2008, 08:05 PM
  #112
ares
Veteran
ares's Avatar
man, that was nerve racking, I tried at 7min, didnt budge, gave it another 3 and it came apart. little hard getting it started, but once it broke open, easy enough.
I painted darn near everything, I never use the high beam anyway. I also painted the metal lens holder thing, part of me wants to paint the whole thing, HID reflector and all, but Im worried it will absorb too much heat and damage it somehow.
Old 03-02-2008, 08:32 AM
  #113
ares
Veteran
ares's Avatar
meh, looks great, but Im not satisfied.
time to pull out the LEDs and get creative. lots of room in the headlight to have fun with.
Old 03-02-2008, 08:07 PM
  #114
Mr.
Mr.'s Avatar
I painted mine this week and they came out gorgeous thanks to this DIY. Unfortunately I didn't do a proper sealing job on the drivers side and after I washed the car, water got into the headlight and now the HID wont turn on. Can anybody speculate what type of damage occurred? I took out the bulb and it didn't look burnt out. I really hope I didn't fry the circuitry... FYI this is a 2008 headlight, and the turn signal/parking light still works.
Old 03-02-2008, 08:23 PM
  #115
LaoSiFu
LaoSiFu's Avatar
Check your ballast. It might has excess water in there that needs to be try.
~Robert
Old 03-02-2008, 08:27 PM
  #116
Mr.
Mr.'s Avatar
~Robert
Thanks man, I'm praying it's that simple.
Old 03-02-2008, 08:37 PM
  #117
LaoSiFu
LaoSiFu's Avatar
let me know if that works
~Robert
Old 03-02-2008, 08:54 PM
  #118
Mr.
Mr.'s Avatar
~Robert
Will do.
Old 03-04-2008, 02:17 PM
  #119
Mr.
Mr.'s Avatar
Ok, there's definitely water in the ballast. I removed all the torx bit screws, but I can't get it open using light pressure. Is there a method of opening it, or should I just force it?
Old 03-04-2008, 02:26 PM
  #120
LaoSiFu
LaoSiFu's Avatar
wait are you taking off the ballast or opening the ballast?
since there is water in the ballast, just shake off the water off and leave it out in the hot sun to dry. crossing my fingers for you that should work.
~Robert
Quick Reply: DIY: Black Housing
