Tutorial: Leather Power/Heated Seat Swap!
Old 10-27-2010, 05:16 PM
  #81
labelworkshop75
labelworkshop75's Avatar
Still no luck. The OP states something about hooking his switches up to a yellow white and black wire? I though you said Blue and White? I think we have some conflicting information. I may just try tapping into those three the OP lists? I am lost!
Old 10-27-2010, 05:40 PM
  #82
corrado15
corrado15's Avatar
Have you tried using a multi-meter to check if there's voltage going into the blue or white wire from the switch when it's in the high or low position? I'd definitely recommend doing that before connecting the switches as you've suggested above.
Assuming you're using 03 seats, the wiring information I've given is correct. I've taken a look at the wiring diagrams in the FSM again and double checked the info I've posted. I'm confident it's correct (I can read wiring diagrams), backed up by the fact that mine are working perfectly.
I'd recommend that you download the FSM and show the wiring diagram in the 'SE' pdf file to an electrician before going any further or doing what you're suggesting above.
Good luck.
Davy.
Old 11-12-2011, 10:23 AM
  #83
labelworkshop75
Bump for an old but informational thread. About to attempt this project again. I noticed that my heaters do "start" to warm but barley get warm and then seem to fade out. I have feeling it is a power issue with sooo many connections to that power out let behind the seats. I'm thinking that we are simply overloading that small power outlet with both the powered and heated components of the 2 seats. May try running a separate power line from the battery for just the heaters. A buddy of mine told me that the heaters in the seats use a boat load of power and that it's most likely not getting enough power from the small power outlet behind the seats.
Anyone that has successfully attempted this please chime in.
Thanks!
Old 06-08-2012, 10:48 AM
  #84
terrasmak's Avatar
Received 2,284 Likes on 1,646 Posts
Originally Posted by 350zion
So theres no relay? I always thought that this circuit had to go thru some kind of relay to work but guess not.. Thanks man ima try it as soon as I get a chance
The relay sits under the 12v plug to the side of the glove box. I swapped my leather seats into a friends enthuast and am trying to figure out how to make the heaters work. I swapped a set of heater controls and OEM wiring into his car, but the heaters wouldn't work yet. Today playing with my car(stripping tar mat under the rear enclosure I noticed two relays, turned my seat heater switch on, pulled the relay, my heater switch lost power. Now to figure out if his car is pre wired for the relay.
Hope this helps someone, will post more results once I get his car back over to my place.
Old 06-11-2012, 09:59 AM
  #85
terrasmak's Avatar
Relay installed and the heated seats work. His car is an 04 enthuast , swapped to my power leather seats with heaters.
You will need the relay, buttons and the short harness from the seat heater controls to the chassis.
Old 08-10-2012, 08:48 AM
  #86
TPete19
TPete19's Avatar
Just picked up some power/heated leather seats to put in my '07 base. Gonna try to find some time this weekend to start wiring them up.
Thanks to Terrasmak and Corrado15 for the help already!
Old 08-14-2012, 08:59 AM
  #87
TPete19
TPete19's Avatar
I just swapped heated, power, leather seats (no side impact airbags) from a 2004 into my 2007 base. I have yet to wire them up but I'm reserving this spot for my lessons learned.
- First off, you'll need to disassemble the bottom cushions of each seat in order to move the weight sensor over. This is very easy to do as the sensor is pretty much just a thin membrane type sensor that sit between the cushion and fabric. Four bolts under the seat to remove the pan. Then a bunch of hog-rings that you can remove with pliers if you don't have the specific removal tool. The one small challenge is that you'll need to cut a slot in the rear part of the seat foam for the sensor brain. Easy enough since you'll just need to imitate the position from the seat that the sensor came from. After you've done that, just use zip-ties to reassemble both seats (about 20 ties per seat).
- The base model in 2007 does not have an extra harness for power or heaters. I've ordered a set of used switches and the attached harness which should make wiring the seat heaters pretty straight forward.
- I'll be following Corrado and Terrasmak's advice in this thread for the wiring and will update once I've completed my wiring.
Old 09-20-2012, 07:42 AM
  #88
labelworkshop75
In for update. Its been years and I still have not got this working.
Old 09-20-2012, 08:15 AM
  #89
TPete19
TPete19's Avatar
I wired it all up but had a short somewhere. I haven't had the time to dig back into it.
Old 01-08-2013, 11:46 AM
  #90
Kimosabe
Kimosabe's Avatar
Hey guys,
I am picking up a set of the OEM power seats soon. I'm not too worried about the heater, just want to power them for movement. The thread doesn't say how, but that it's easier than hooking up the heaters. Can someone tell me what I do to get at least movement power to them? Also, will it trigger any airbag or seat belt lights?
Old 10-14-2014, 03:20 PM
  #91
DeusExMaxima
DeusExMaxima's Avatar
Im doing something slightly different. I have an 05 Roadster that had heated seats. I swapped in some factory cloth nismo seats with no heat. I want to remove the heating elements from the original seats and install them in my cloth seats.
Old 08-24-2016, 07:29 AM
  #92
NR350z
NR350z's Avatar
Rebirthing this thread as Im currently getting ready to purchase a set of power, heated, leather seats for my '03 Enthusiast... The seats are from an '03 as well. Im really not THAT electrical savvy, but I've installed my fair share of head units.
Not worried about the heating aspect of the seats, more-so the powered function (obviously) however, correct me if I'm wrong, the '03 Burnt Orange Leather seats have airbags, and the cloth do not? I'm not worried about the air bag function but would just powering the seat cause me to throw an air bag light on the dash? I wouldn't think it would since the car isn't expecting a response from the seats to throw the light, just wondering before tackling this job.
Thanks in advance for the great write-ups here, definitely will help greatly.
Old 08-28-2016, 06:58 PM
  #93
NR350z
NR350z's Avatar
Anyone? Just need to know which wires to tap, all I want is power to the seats, I have supplied a picture of the underside of both pass and driver seat, along with the plug I suspect I need to tap but not sure. PLEASE HELP!!!
Drivers side:
Passenger side:
Old 01-01-2017, 10:13 PM
  #94
nizmo_0385
nizmo_0385's Avatar
Originally Posted by JasonZ-YA
I have purchased OEM heated seat switches at junk yards in perfect condition (once wiped down) for 35 - 50 bucks before.
I will be installing aftermarket heated seats in my 08 Xterra using the switches for that oh-so nice oem look...lol
-J
bump anyone know if my 07 nismo has a harness hiding under the carpet? I'm about to purchase a set of leathers from and 07 touring
Old 01-02-2017, 08:53 AM
  #95
NR350z
NR350z's Avatar
I've been told that they are, but my 03, that was supposed to have them, didn't, but only one way to find out. I pulled my seats and pulled back the carpet, and nothing there, but good luck, otherwise just wire them up.
Good luck
Old 01-02-2017, 08:55 AM
  #96
nizmo_0385
nizmo_0385's Avatar
Good luck
If they were there how would I check. gonna pull seat ow where do I pull carpet to check
Old 01-02-2017, 09:11 AM
  #97
nizmo_0385
nizmo_0385's Avatar
started to pull seats and this harness is hanging free. is this for the power seats? is it also for the heat portion?
Old 01-02-2017, 03:56 PM
  #98
NR350z
NR350z's Avatar
Looks like it, should plug and play right into the bottom of the seat towards the front of the seat of you look at the above pics I posted, don't worry about the yellow plug, thats for air bags, should be wired in your center console for the buttons for the heater, should all work cohesively. Although, tough to see exactly where that harness is at under the carpet, but its usually taped to that bar thats raised, right behind or close to right behind the seats.
You're lucky, mine wasn't pre-wired for seats... wish it was
Old 01-02-2017, 03:59 PM
  #99
nizmo_0385
nizmo_0385's Avatar
thanks man. seats are out not pulling carpet yet because seller went MIA. so may or may not happen ... bummed.
Old 01-02-2017, 07:40 PM
  #100
nizmo_0385
nizmo_0385's Avatar
I got the seats.
Quick Reply: Tutorial: Leather Power/Heated Seat Swap!
