Aftermarket Hub, QR, & steering wheel install DIY
Old 04-01-2011, 09:08 AM
DB8
DB8's Avatar
nice write up, +1......
just one question, I just put in my momo today as well. Felt 100x better than stock, but my "auto signal shutoff" is NOT WORKING now, any idea?
thanks in adavance
Old 04-09-2011, 08:27 PM
ffwturboZ
ffwturboZ's Avatar
Originally Posted by xirtam
Thanks for the write up. I recently installed the NRG short hub and quick release. I'd like to turn off the annoying SRS light. Does anyone know what resistors I need to do this?
2.2 ohm? 1/2 watt?
I had recently installed my Sparco steering wheel using the NRG adapter. The kit brings just one resitor, you will need two. Do a search on ebay like I did and pick another one up for about 12 bucks. Then do a search here. There is a step by step on how to reset the SRS airbag light...Problem solved
Old 04-09-2011, 10:26 PM
xirtam
xirtam's Avatar
Smile
I ended up picking up a couple of 2.2ohm 1/2 watt resistors from Frys electronics. Worked like a charm. $1.98
Old 06-21-2011, 08:36 PM
AcidJake75
Living in 350Z
AcidJake75's Avatar
Thanks to this write up...I know my car is dirty- thats just how I roll..
Old 06-27-2011, 06:38 PM
Johnnyone
Johnnyone's Avatar
thxs OP for the write up, I just used this thread to reference my install.
And thxs to you for posting up what u used on the other resistor. My nrg hub and QR only came with with one resistor.
Only prob i have i my wheel is a lil crooked. This may be due to the hub install, will have to look at it later when i have some sunlight.
Old 07-26-2012, 12:06 PM
ALO8
ALO8's Avatar
the original post states an extra resistor? im about to order rapfix 2 with short hub, i know it comes with one resistor, do i need to get an extra resistor to have 2 total?
Old 08-04-2012, 11:33 AM
DCAA
DCAA's Avatar
Post
I traded my stock steering wheel with my friend's NRG hub/NRG wheel recently and after installing the hub/wheel I realized that my turn signals weren't engaging/disengaging where they used to previously. I've tried searching for a fix but to no avail, does anyone know how to right the problem? Thanks.
Old 08-09-2012, 10:10 AM
NY350zG
NY350zG's Avatar
Anyone ever figure out the solution for the turn signal problems?
Old 08-19-2012, 03:41 PM
DCAA
DCAA's Avatar
Straighten out your wheels, remove the hub, move the 'nipple' on the steering column switch to the 12 o'clock position, re-install your hub and all should be right.
Old 08-20-2012, 12:59 AM
mw9
mw9's Avatar
nice write up
Old 08-21-2012, 12:37 PM
Z33Garage
Z33Garage's Avatar
anyone got an answer for sDavis issue? I have the same thing.
Old 12-23-2012, 01:26 PM
samsniss350z
samsniss350z's Avatar
Fantastic install helped a lot by the addition of the photo's. I just have one question that you can perhaps help me with. My standard wheel has buttons mounted on both sides of the silver brushed inserts. On the right hand side i have three switches for cruise control and the left side for adjusting volume, answering the phone and changing CD track or altering radio channel, any idea as to how i can overcome this and mount my favourite OMP wheel??
Old 06-27-2013, 01:51 AM
Mrmrssuarez
Mrmrssuarez's Avatar
Did you get the horn to work also while installing this steering wheel??
Old 07-14-2013, 04:24 PM
Airkilo
Airkilo's Avatar
I just recently installed my NRG Hub and Quick Release. Now just wondering how do I wire it up to make the horn work. The "grey horn wiring harness" only has one attachment. What do I do with the other connection. does it ground some where on the hub?
Thanks
Old 07-15-2013, 02:25 PM
Citrus
Citrus's Avatar
There was a wire on the horn button that my wheel came with that plugged into the wire coming out of the grey harness.
Old 07-16-2013, 06:49 AM
Airkilo
Airkilo's Avatar
I have 2 connectors coming from my Horn to the quick release, than 2 more coming from the quick release (Male and Female) to the Grey harness. Now 1 connector plugged into the grey harness and one is free not connected to anything. Not sure what to do with this one connector. I'll take pictures once I get a chance.
Old 07-17-2013, 03:29 PM
Thats13guy
Thats13guy's Avatar
I have the same issue with the two wires coming from my nrg wheel and was also curious as to wether the black wire was a ground or what. Thanks in advance
Old 07-26-2013, 06:18 AM
  #38
Scabd
Scabd's Avatar
There is a gray metal ring that comes with the quick release...maybe the hub. You have to use one of those to establish a ground for one of the wires and then connect the other wire from the horn all the way through the quick release. That ways when you push the horn button it grounds out and causes the horn to go off.
Old 07-31-2013, 06:19 AM
  #39
Airkilo
Airkilo's Avatar
great thanks for the help.
Old 08-07-2013, 09:09 AM
  #40
That monkey 07
That monkey 07's Avatar
http://www.conceptzperformance.com/C...2766.249.73.37
Quick Reply: Aftermarket Hub, QR, & steering wheel install DIY
