DIY: Halo and Clear Lens mod on '06-'08 headlights
#125
on
hey does anyone know what size is necessary if I were to do the SMD LED rings OUTSIDE the housing? Is it going to be the same 95mm?
diodedynamics has 80 90 and 100mm.. any clue as to the proper size and who is the place selling that size? Im not calling Cincity to find out who their source is..doubt theyd tell me anyways...
#126
on
#133
Hey Guys. New to the forum and sorry to be a graveyard digger.. But does anyone know the diameter size of the circle around the projector in the headlight. Looking to epozy a led halo right on top of the plastics arounf the projector housing.
#136
so im looking to do this now and before i order the wrong thing i just wanna make sure i get the right thing. is this the right size Select Diameter:95mm OD, 80mm ID WHITE. op says 95mm but i dont see one that says just 95mm. just dont want to order the wrong thing ya know. if some one can chime in on this it would be great
#140
OK, today I got moisture inside my lights, and I am 100% sure they are sealed, I have glue came out on all sides of the light so there is no leak. Did anyone have moisture right after you did your lights? Could paint gave up some moisture?
