DIY: seatbelt assemblies
Old 05-25-2011, 07:30 PM
3hree5ive0ero
Retired Admin
3hree5ive0ero's Avatar
Default DIY: seatbelt assemblies
In order to replace the seatbelt assembly in the 350Z, follow the below steps:
1. take off the plastic trim that runs down the doorway by the door (between the metal and the carpet by your hips when sitting in the car)
2. take off both plastic interior panels under the rear small windows (where the top anchor of the seatbelts are attached)
3. loosen the center divider plastic by first undoing the shifter trim and loosening the 2 screws holding it down, another screw under the coin tray (for 1st gen interior, unsure about 2nd gen), and 2 more on either side closer to the trunk
4. take off center interior panel (where the bose sub and glove box is)
5. undo whatever screws you see blocking the way to the inside of the metal wall (houses the speakers, small storage spaces, glove box, etc) and take out either the metal panel and/or glove box
6. undo the seatbelt anchor bolts at the pillar and by the floor (plastic/vinyl covers slide away/off)
7. undo the yellow clip and 2 bolts holding the seatbelt assembly
8. reverse the entire process*
*The seatbelt assemblies will lock and will not unwind if it's not in the exact orientation as it would be if it were installed in the car.
Old 09-19-2011, 06:40 AM
dere321
dere321's Avatar
Is there any way of rebuilding them after say an accident or do they absolutely have to be replaced. eBay is selling rebuild guides and am curious as to what that might mean.
Old 09-19-2011, 09:04 AM
-Trav-
-Trav-'s Avatar
Id replace them, for the peace of mind alone.
Thanks for the write up OP-and thanks for bumping ^ My belt barely retracts anymore so Ill be all over this. I wonder if this is common on the Z...
Old 01-31-2014, 09:41 PM
2007base350z
2007base350z's Avatar
How the hell do I unplug the yellow plug
Old 02-04-2014, 03:43 AM
omegamanuk
omegamanuk's Avatar
was told cleaning the belt with water and washing powder does the trick, as soon as mines dry ill let you know if it works
Old 03-19-2014, 07:17 PM
freddys 350z
freddys 350z's Avatar
BACK FROM THE DEAD.. but, how the heck do you undo this type of plug?
Old 03-19-2014, 10:01 PM
3hree5ive0ero
Retired Admin
I wish I could remember but I don't even remember what it looked like.
edit-
I found a picture of the seatbelt assembly and you can see where it plugs into. Probably not possible, but can you get a good picture of the actual clip/plug? If I can see it, I might remember how to take it off.
http://i59.photobucket.com/albums/g3...509_212359.jpg
Old 09-06-2014, 07:57 PM
Pinkfrostii
Pinkfrostii's Avatar
Is it okay to try to just break away the plastic piece that goes around the window instead of trying to take apart the whole seatbelt? I already have the rest of the plastics removed except for the piece around the seatbelt.
EnjukuRacing
09-30-2015 06:55 AM
Quick Reply: DIY: seatbelt assemblies
