380RS pedal install
This proves the point that it *is* very quick and *simple* - It's also irrelevant if the Z already has aluminium pedals, this isn't used for that reason, it's to aid heal & toe down-shifts, which i missed since moving to the states :/
Stepped up the game a bit and went with SRP pedals. Great grid pattern gives me no slip with wet feet.
What I have is their normal width gas pedal (they offer an even wider version). You have to drill / bolt the pedals once removing the oem factory covers, which allowed me to shift the brake pedal to the right a bit.
Heel toe downshifting is now effortless, easily the best sub $200 mod i've done to the car.
on
Thanks for the post, Maxx, it's always nice to see a visual for stuff like this. I just bought mine off ebay from Fontana Nissan, $36 shipped and they sent it the day I ordered it (Z1 doesn't stock them anymore because they didn't sell any.)
Looking forward to better H&T feeling on track.
I used to work at the smyrna, tn plant building the altima, altima coupe and maxima and all of their pedals are installed/uninstalled in the same manner- I assumed the Z was the same but the confirmation is nice
What I'm excited about is the part itself- I didn't know it existed but now I'm going to be dreaming all week about the beneficial feel of this pedal... so glad i stumbled across this thread. I didn't hesitate to order one of my own. Thanks for the post, OP!
Just installed mine.
This thread was very helpful, even if it was simple, it kept me from doing a lot of head scratching about how to do it. Made it quick and easy. Installed in under 30 seconds probably.
Thanks for taking the time.
I have an 08 base with the rubber pedals, is it the same steps for me or do I need to do something different? I think it might look weird with 1 metal pedal but I feel it could help at the track.
The pedal will really help for heal and toe, i had my doubts comparing them side by side, but after using it, it's perfect, exactly what it needed.
As for the plastic pedals, hmm, i think i read somewhere that it's missing the little plastic bit to secure it, try a quick search or look on one of the vendors sites, i think they have a description.
Thanks for your help. After some research I concluded I am not going to do it. Apparantly the entire gas pedal assembly is different on the base (I do not know why) so I would need to modify for the pedal to fit correctly, which I am not going to risk on something important like the gas pedal. It's a shame because I would love to use this pedal.
http://www.z1auto.com/prodmore.asp?m...or&prodid=3669
There is the option to order the extra part, it's not a modification per sé, just a different part you add back.
Yes, that's what i'm referring to.
#38
I know exactly what you are saying, I need an extra part. However, after reading some older threads apparantly the assembly thickness is different on the base, so even with the correct parts installed, the pedal has play and does move a certain amount, which scares me. I wish someone can confirm who has a base. If its good the. i will definitely order from them, thanks again for the info!
#39
The throttle shaft diameter is just a little too small, so the pedal has some allowance for lateral movement. Just wrap that area of the shaft with a few turns of black electrical tape (which you can't see, anyway), and you're fine. Did this on my '08 base when I installed the RS pedal. This pic shows the difference in the metal versus plastic pedals in that area:
End result in a 2008 350Z Base model:
Old:
http://www.flickr.com/photos/111739693@N04/13128131405/
New Pedals + JDM:
http://www.flickr.com/photos/111739693@N04/13128183183/
Huge improvement in looks,.. but is highly functional as well. Better grip, better "feel",. and heel toe on down shifts is much easier.
Thanks for the info!
Gruppe-S
Body Interior
13
05-16-2016 10:42 PM
