DIY for Steering Wheel Removal and Steering Wheel Audio Control Unit Install
Old 07-27-2014, 07:27 PM
  #181
guvars
guvars's Avatar
thread revival!
Im trying to install the steering wheel radio controls into my 03 touring.
i got the 06+ clock spring part number 25567-z33003 from courtesy, and they sent me part number 25567-et025. I was under the impression that with the 06+ clock spring i would be able to have the illuminated controls, and the dimmer feature also. The new clock spring is missing a plug, which causes my slip and VDC light to come on. The new clock spring has plugs for the light/ wiper levers, air bag, and horn. The cruise buttons work with the new clock spring just no illumination and the issue with the VDC. Ive also seen that some people have used part number 25567-cd026 and have had the same the same issue with the missing plug. Does anyone have the part number to an 06+ clock spring that have successfully gotten the illumination on the cruise and audio controls to work on earlier models and with the extra plug?
bmccann101 (07-17-2017)
Old 07-30-2014, 06:51 PM
  #182
guvars
guvars's Avatar
update: can anyone provide a picture of their 06+ clock spring? i need a picture of the back side where the yellow and gray wires plug in. i have a attached a picture of how mine is with the two plugs and picture of the 25567-et025 that courtesy nissan sent me with the missing plug.
Attached Thumbnails DIY for Steering Wheel Removal and Steering Wheel Audio Control Unit Install-photo-1.jpg   DIY for Steering Wheel Removal and Steering Wheel Audio Control Unit Install-photo-2.jpg
Old 01-18-2015, 11:11 PM
  #183
p3mp
p3mp's Avatar
Hello, Took off my steering wheel on my Nissan 350z 2003-2004 I noticed that i only had ONE(1) cable to my airbag. I have read that everyone has two cables.
So i only put in a 2 ohm resistor. Do anyone know if it is 2 ohm on the one cable airbag?
Old 02-20-2017, 12:49 PM
  #184
NismoFairladZ33
NismoFairladZ33's Avatar
Big thanks to GT-3 , this thread help me figure out how to replace my wheel but getting all the wiring and controls to work was a pain in the A$$ but worth it.
To guvars, I used my stock 04 clockspring as our year model will be missing a ground pin. I repined the (370z audio controls) harness and tap the (-) Illumination to ground inside the steering wheel harness.
Old 04-22-2017, 09:14 PM
  #185
Bensalley
Bensalley's Avatar
Originally Posted by gt3
24. Reinstall all pieces in reverse order. The large nut holding the steering wheel in place should be torqued to 22-28 ft-lbs. The air bag bolts should be torqued to 44-121 ft-lbs (No wonder they were so hard to remove!!).
25. Wire and then program the PAC Audio SWI-X per its instructions for Nissan. Use the diagram above to guide your wiring. The program version should be set to 3. I ended up selecting the area behind the shifter to store the unit. This way I can easily get to it to reprogram it if I have to.
Where exactly are you connecting the 3 added wires? Does this setup light the steering wheel controls? Is the, later mentioned, 4th wire (dimmer) necessary for lights?
Thanks a mil
Old 07-11-2017, 02:47 PM
  #186
bmccann101
bmccann101's Avatar
subbed, awesome info...
bought an 06 clock spring for my NON VDC 05 car, and am installing this 06+ steering wheel controls set up soon.
I had all the lighting swapped to white, and the airbag will be done being reupholstered in black alcantara w red stitch by tomorrow.
Also picked up a Joycon adapter to route these controls to an adroid tablet for audio control.
Old 07-17-2017, 04:00 PM
  #187
bmccann101
bmccann101's Avatar
looks like oit threw my slip and TCS light, even though I am not missing a plug, does anyone here still have information on fixing up the following:
05 car w TCS and NOT VDC
06 clock spring
06 steering wheel controls
needs to use cruise audio control and lighting.. would like to retain the dimmer, but if impossible, so be it.
I do still have my 05 clock spring in case its necessary to revert back and re pin.
Old 07-18-2017, 01:04 AM
  #188
amr_electron
amr_electron's Avatar
06 clock spring
Slip and TCS light could be because of the steering angle sensor, Might need re-calibration.
Audio control and lighting should still work fine with the 05 spiral cable if you do the needed wiring correctly.
bmccann101 (07-18-2017)
Old 07-18-2017, 08:46 AM
  #189
bmccann101
bmccann101's Avatar
I really hope the airbag / horn I have on this steering wheel I had just bought doesn't have an internal ground problem.. I spent quite a bit of coin having it reupholstered lol
Ill check into the clock spring reset issue.. sounds logical and easy to fix. Hadn't wired anything up yet, but the fact the horn didn't work along w the lights had me worried a bit.
Old 09-12-2017, 02:37 PM
  #190
bmccann101
bmccann101's Avatar
update, the slip light disappeared now that the engine runs again.
Old 09-13-2017, 08:31 AM
  #191
KingBaby
Hardest Setting
KingBaby's Avatar
***PFM***
I hate electronics
bmccann101 (09-18-2017)
Old 10-26-2017, 04:46 PM
  #192
bmccann101
bmccann101's Avatar
Guys I am so sorry to rehash what has already been covered in bits and pieces here already, but i can't seem to gather the information I need completely w my research has here. :
I have a 2005 w no vdc.. Means my clockspring plug situation is simple...
I have 2006 illuminated steering wheel controls..
I have purchased a 2006 clock spring spiral cable assembly..
I have the radio shack connector pins listed here as well.. What I don't understand is what three pins (and specific location on the car side plug) that I need to add to my 2005 car side plug in order to power up my illuminated controls, ground the audio control, and run audio controls out.. Which is which.. Which location, and what direction should the plug be read in whatever diagram you've (potentially) replied with? (plug side, harness side etc.. Like the fsm)
Old 12-13-2017, 07:54 PM
  #193
bmccann101
bmccann101's Avatar
Guys.. Really hoping for a thread reply here.. Again I have an 06 steering wheel w audio controls.. An 06 clock spring cable.. And a 2005 vehicle.. The cruise control works as is.. But I can't figure out what wires to add to the car side of the clock spring plug to allow the dimmable illumination and audio control wiring... Can someone please assist? I've been here for a decade.. Hoping to get a bit of insight here, would really appreciate it, as I'm totally stuck.
Old 12-16-2017, 03:24 AM
  #194
kno
kno's Avatar
Hey brian, i believe the car already comes prewired for that. All you have to do is add the steering wheel controls. I dunno how pre 06 z works but this was the case on my base 07.
Old 12-16-2017, 03:27 AM
  #195
kno
kno's Avatar
Im working on my cars electrical, i can snap a pic of the wires on my illuminated steering wheels cables if its of any help
Old 12-16-2017, 06:43 AM
  #196
kno
kno's Avatar
I dunno if any one every visits this site anymore. But here ya go i hope it helps.
Old 12-16-2017, 06:44 AM
  #197
kno
kno's Avatar
This is from the steering wheel conteols
Old 12-16-2017, 08:04 AM
  #198
bmccann101
bmccann101's Avatar
I do appreciate the pics. But for an 05,there are less wires.. And I need to know what they actually need in terms of voltage too.. Hoping to get a reply from one of the guys who's done the swaps into 05 and older..
Old 12-16-2017, 09:27 AM
  #199
kno
kno's Avatar
Gotcha gl dude thats martini z is gonna be beast ✌
Old 02-07-2021, 02:11 AM
  #200
akuma69
akuma69's Avatar
bmccann101 i've done this for my 05 z. Need help?
Quick Reply: DIY for Steering Wheel Removal and Steering Wheel Audio Control Unit Install
