Body Interior Seats, shift knobs, etc.
FS: Greddy is back with their new "Multi D/A Gauges"
Old 05-11-2012, 01:26 PM
Gruppe-S
Vendor - Former Vendor
Gruppe-S's Avatar
Default Greddy is back with their new "Multi D/A Gauges"
Greddy has come out with a single gauge that does everything!
Everything the popular brands do plus a
LOT MORE! Here are a couple highlights!
· Hybrid analog dial with integrated digital display.
· Monitor up to 3 different readings on just one easy to view unit.
· The Multi D/A Gauge uses the latest generation electroluminescent display.
· Ideal size and style for visibility.
· Available in two main Analog types: Oil Pressure and Turbo Boost
· Specs: 62mm Diameter, 45mm depth
Includes:
Wireless Remote Control, Sensor Center Unit, Main & Power Harness, Boost Sensor or Oil Pressure sensor, Sensor Harness, and Gauge Holder
Set adds: 1x (Water/Oil) Temperature Sensor & Sensor-Harness, 1x (Oil/Fuel) Pressure Sensor & Sensor-Harness.
  • Numeric and Bar-graph digital readout can display 2 additional readings
  • Selectable 7-color LED Backlighting (white, yellow, green, blue, light-blue, purple, red)
  • Animated Start-up Sequence
  • Peak Hold Recall
  • Warning Point Alarm
  • LED Illuminated back Logo
  • Voltage reading via power harness
  • Water-resistant Center Unit, labeled and pre-wired for optional sensors
*OPTIONAL SENSORS SETS AVAILABLE:
(Oil Pressure, Fuel Pressure, Water Tempature, Oil Tempature, EGT)
- For easy sensor installation also see our:
Water Temp Adapters, Tapped-Oil Drain Bolts and Oil Block Adapters.
Multi D/A Gauge Set Boost,Temp,Press 62mm Dia. Turbo (Boost) Dial 16001710
Multi D/A Gauge Set Press,Temp,Temp 62mm Dia. Oil Pressure Dial 16001711
Multi D/A Gauge Boost 62mm Dia. Turbo (Boost) Dial 16001700
Multi D/A Gauge Press 62mm Dia. Oil Pressure Dial 16001701
Boost Sensor Set Multi D/A 4mm Dia Opt. Boost Press Set 16401920
Pressure Sensor Set Multi D/A 1/8PT Optional Oil or Fuel Press Set 16401921
Tempature Sensor Set Multi D/A 1/8PT Optional Water or Oil Temp Set 16401922
EGT Sensor Set Multi D/A 1/8PT Optional Exhaust Gas Temp Set 16401923
Boost Sensor Multi D/A 4mm Dia Replacement Boost Press Sensor 16401900
Pressure Sensor Multi D/A 1/8PT Replacement Oil or Fuel Press Sensor 16401901
Tempature Sensor Multi D/A 1/8PT Replacement Water or Oil Temp Sensor 16401902
EGT Sensor Multi D/A 1/8PT Replacement Exhaust Gas Temp Sensor 16401903
Boost Sensor Harness Multi D/A 1.5m Replacement Boost Press Sensor Harness 16401910
Pressure Sensor Harness Multi D/A 1.5m Replacement Oil or Fuel Press Sensor-Harness 16401911
Tempature Sensor Harness Multi D/A 1.5m Replacement Water or Oil Temp Sensor Harness 16401912
These will be in stock and ready to ship as soon as Greddy receives them in early July.
We will be placing pre-orders from now till they are in stock.
Gauges start as low as
$405 W/ FREE 3day shipping.
Gruppe-S is offline
Old 05-11-2012, 01:42 PM
konrad
konrad's Avatar
Price of 16001710
konrad is offline
Old 05-11-2012, 02:50 PM
Gruppe-S
Gruppe-S's Avatar
pm'd^^
Gruppe-S is offline
Old 08-02-2012, 12:45 PM
Gruppe-S
Gruppe-S's Avatar
Looks like Dynamic Autosports is doing Giveaways for the month of August. All you have to do is go to this link:
http://tinyurl.com/cc8j4ag
Click "LIKE" on any of the pictures that you want to win. At that point you are entered to win at the end of the mont. we will have a drawing here and contact you via facebook when you win! good luck everyone!
Gruppe-S is offline
Old 08-02-2012, 01:29 PM
AdvanZ33
Senior Super Moderator
AdvanZ33's Avatar
Link no bueno.
AdvanZ33 is offline
Old 08-02-2012, 01:42 PM
Gruppe-S
Gruppe-S's Avatar
fixed. sorry
Gruppe-S is offline
Old 08-02-2012, 02:28 PM
AdvanZ33
AdvanZ33's Avatar
Still doesn't work for me...I want a chance to win free stuff!
AdvanZ33 is offline
Old 08-02-2012, 02:49 PM
Gruppe-S
Gruppe-S's Avatar
ok this time for reals!
Gruppe-S is offline
Old 08-02-2012, 02:57 PM
AdvanZ33
AdvanZ33's Avatar
Done and done. Thank you sir.
AdvanZ33 is offline
Old 08-23-2013, 05:01 PM
midz350
midz350's Avatar
Price for the boost set. Boost,Temp,Press. And does the boost read to 2.0 bar only or make it all the way to 2.5 bar?
My STRI DSD SLM-II set sensors are not working anymore and couldn't find replacement sensors for them.
midz350 is offline
Old 08-23-2013, 05:08 PM
Gruppe-S
Gruppe-S's Avatar
midz350, i have 2 SMI gauges from Greddy left over. Water and Oil temp complete gauges. let me know what you have and i will see if the sensors are avail
Gruppe-S is offline
sales@czp
09-23-2019 03:30 PM
11-01-2015 05:25 PM
EnjukuRacing
09-30-2015 06:55 AM
Quick Reply: FS: Greddy is back with their new "Multi D/A Gauges"
