Check Out Our Selection! Sabelt, Takata, Sparco and more at MA Motorsports
Vendor - Former Vendor
From the Street, to the Track MA Motorsports has you covered for the interior of your 370Z. If you don’t see it listed or have ANY questions, feel free to PM or Call me at 410-593-7080 and ask for Daelen
Takata Harness’s
The RACE 4 is the benchmark harness for Track Day/Drift/Show cars. This true racing harness comes with FIA approval, and the exclusive TAKATA aluminum multi-point release cam-lock buckle. Additional features include asmTM system to prevent submarining, 3" shoulder belts, and 2" lap belts.
The Bolt-On version features specialized bendable stainless steel bolt-on brackets (see image) designed to bolt to the stock vehicle seat belt mounting points along with your factory seat belts. The brackets can be pre-bent to optimize installation and to maintain the proper load path of the seat belt under load.
The lap belt Bolt-On attachment brackets are sewn into the lap belts. The shoulder belt attachment brackets are wrapped in and can be removed allowing you to wrap the shoulder belts to a harnessbar or rollbar using the 3-bar adjusters provided.
The lap belt Snap-On attachment brackets are sewn into the lap belts. The shoulder belt attachment brackets are wrapped in and can be removed allowing you to wrap the shoulder belts to a harnessbar or rollbar using the 3-bar adjusters provided.
Takata Racing cult status for the street! Available in traditional TAKATA Green and also in Black!
This belt manufactured in accordance to the European Standard ECE-R 16.04 and Federal Motor Vehicle Safety Standard (FMVSS) 209. It is a legal seat belt for use in street cars in all US states with mandatory seat belt laws. The belt features a center push button release buckle and our shoulder belt asmTM system to prevent submarining. 2" shoulder belts and 2" lap belts with comfort padding.
The Bolt-On version generally bolts to the existing factory mounting points for the front lap belts. The shoulder belts generally mount either to the rear "D" and "E" lap belt mounting points OR they can be wrapped directly to a roll-cage or harness bar.
The lap belt Bolt-On attachments brackets are sewn into the lap belts. The shoulder belt attachment brackets can be removed allowing you to wrap the shoulder belts to a harnessbar or rollbar using the 3-bar adjusters provided.
(DRIFT belts should only be used with seats that have a "pass-through" for the shoulder harnesses such as a stock seat with an adjustable up and down headrest or a race type seat with openings for the shoulder belts. Never use this type of belt with a seat that has an integrated head rest that would require the shoulder belts to be routed around the outside of the headrest. The rear passenger seats must not be used while the DRIFT belt is installed.)
Takata Seats
DRIFT PRO LE Seat
The limited edition TAKATA Drift Pro LE Seat is a masterpiece of automotive seat engineering, creating an amazing light-weight, hybrid composite recliner. With a stunning pure carbon backrest, fine black leather with a subtle TAKATA Green diamond stitch pattern, high-density molded polyurethane foam, polished stainless steel chassis work, and the world's best reclining mechanism - this seat re-defines the category of light weight sport seats.
The seat comes standard with an integrated seat heater for street-driven cars for modern comfort.
STREET PRO LE SEAT
Built from a tubular steel frame, this reclining seat is designed for comfort and support in spirited driving. Equally at home on the street and the track, you will find the bolstering in just the right places. All of this without losing the convenience of a tip-forward design allowing access to the rear seats.
Covered in black Spacer fabric with Carbon Fiber look vinyl patches to protect the heavy wear areas. TAKATA Logo embroidered on front and back of the headrest.
RACE LE SEAT
The limited edition TAKATA Race LE Seat is an incredibly safe, deep sided and extremely rigid seat that still allows freedom of movement for all disciplines. The black Spacer Fabric, stitched in subtle TAKATA Green, keeps you cool. High backed, fully HANS® compatible with increased kidney protection, but relieved below the shoulders for lateral arm movement, this seat allows you to really get over the wheel and take control without any compromise on what is known as one of the most comfortable seats in the industry.
Comes in two sizes, Standard and Wide (+30mm) to ensure a perfect fit for every driver.
Sabelt
Sport Harness
Steel Harness
GT-160 Seat
Fiberglass Shell
GT-100
Fiberglass/ABS Shell
GT-600
Extra Light Carbon Fiber Shell
SW-633
Flat – Suede Steering Wheel
330mm
SW-390
Dished Steering Wheel (90mm depth)
Black Suede Leather
350mm
SW-490
Smooth Leather
350mm
Works Bell
Works Bell Rapfix Short Boss/Hub - Nissan 370Z Z34
SPARCO
EVO
The Evo competition seat has the quality and performance you’ve come to expect from Sparco and the Evo seat line. The Evo was designed and developed with extensive input from some of the most prestigious DTM and ITC championship drivers. Evolved from the Rev seat, the Evo features removable cushions to customize the back rest, height of the leg rest and cushion padding. The cushion colors can also be customized in various colors. The Evo is FIA approved.
*Also available in light-weight Carbon Fiber
PRO 2000
The Pro 2000 is our most popular competition seat. It combines comfort and ergonomics with safety and performance. The non-slip fabric on the shoulder and cushion area and two lumbar support pads improve cockpit comfort. Made from an light fiberglass composite shell and wrapped in a fire retardant fabric, the Pro 2000 features a seat design that cradles the body for greater performance. Available in black, blue and red. The Pro 2000 is FIA approved.
Pro 2000 requires Spacer Kit (#50003) when installing using bottom mount attachment points.
CIRCUIT
The Circuit is an ultra-light competition seat specifically designed for circuit use. Made from aramadic fibers-reinforced fiberglass, the Circuit has an ultra-light shell. The Circuit includes integrated bolsters to protect the head and a unique seat design that helps separate the driver’s leg. This seat can be used with a Hans device for even greater protection. The ultra-light shell is then wrapped in an impact-absorbing and fire retardant fabric that helps hold the body. Available in black, blue and red. The Circuit is FIA approved.
Street Harnesses
Sparco’s full line of high-performance street harnesses is designed for weekend racers and hobbyists. Crafted from high-quality fabric and fitted with durable fasteners, each harness restrains the body for added safety and protection. Our 4-point street harness is made with 2-inch straps that attaches to the frame using snap-in fittings. Each strap attaches in the center via a durable cam lock fastener. Available in black, blue, red, and silver.
Sparco safety harnesses are intended for racing vehicles. Harnesses are not applicable nor intended for street or highway use.
Race Harnesses
Sparco’s full line of harnesses works in unity with our competition seats. Crafted from high-quality fabric and fitted with durable fasteners, each harness restrains the body for added safety and protection. Our 6-point harness features 3-inch lap and shoulder straps that attach in the center using an aircraft-quality quick-release buckle with integrated anti-submarine belts. The lightweight aluminum adjusters allow for smooth, quick adjustments and perfect clamping. Each belt attaches to the frame using snap-on fixings. Available in two styles: pull up and pull down in three colors each: black, blue and red.
FIA and SFI approved.
Steering Wheels
R368
• Diameter - 380mm
• Dish (depth front to back) - 65mm
• Cover Material - Suede
• Yellow leather centering stripe
L777
• Diameter - 350mm
• Dish (depth front to back) - 63mm
• Cover Material - Leather or Suede
• Contrast stitching
• Grey leather centering and accent stripes
L360
• Diameter - 330mm
• Dish (depth front to back) - Flat
• Flat Bottom
Gruppe-S
Body Interior
13
05-16-2016 10:42 PM
