SPC Toe Bolt install write up with pics courtesy of Protocav. - Page 4 - MY350Z.COM Forums
Thread Tools Search this Thread
Old 01-19-2007, 01:55 PM   #61
Skrilla
Skrilla's Avatar
Quote:
Originally Posted by redlude97
Whats the point though, they only cost like $40 now, the savings couldn't be that significant
LOL...I don't know maybe $25-$35 to spend on something else...there are a couple movies I'd like to see or dinner or 1/4 tank of Gas (LMAO) or welding spool or shilelding gas or NOS refill or can of fiberglass resin or .5" plate of aircraft quality aluminum or brazing sticks or stone type grinding bits...
...anyway the size would make it a little easier to maybe put something together...anybody know ?
Skrilla is offline   Reply With Quote
Old 04-20-2007, 07:22 PM   #62
blaque
Quote:
Originally Posted by MIAPLAYA
BTW he is more then happy to install these for you if you live in Socal
Mods can I get a sticky for this thread and a cookie for protocav?
http://members.***.net/turbonetics35...oltinstall.pdf
The link is dead. Anybody have a copy saved? Thanks.
blaque is offline   Reply With Quote
Old 04-24-2007, 12:04 PM   #63
ExtaZ33
Bump... the link is dead! Somebody help me!
ExtaZ33 is offline   Reply With Quote
Old 04-24-2007, 12:12 PM   #64
ExtaZ33
Thanks for fixing the link.
Old 05-01-2007, 11:11 AM   #65
MIAPLAYA
MIAPLAYA's Avatar
Quote:
Welcome...
MIAPLAYA is offline   Reply With Quote
Old 05-09-2007, 10:53 AM   #66
dutchboy350Z
Finally some go
dutchboy350Z's Avatar
SPC camber/toe kit vs stock
Alignment before SPC Camber/Toe kit was installed.
Alignment after. Back to stock spec.
New SPC camber arm.
toe bolt being installed.
dutchboy350Z is offline   Reply With Quote
Old 05-10-2007, 05:25 AM   #67
ExtaZ33
Thanks!! My car is on jackstands already and I'm installing these tonight. I'll try to get some pics up too. I need air tools!
Old 05-24-2007, 04:30 PM   #68
OH6 G35
OH6 G35's Avatar
Subscribing...
OH6 G35 is offline   Reply With Quote
Old 05-24-2007, 04:49 PM   #69
Theatrix
Professional
Theatrix's Avatar
Quote:
Originally Posted by Super Avan Z33
someone said the 04 up Z's toe bolt slot is already big enough to fit the SPC toe bolt in, has anyone done install the SPC toe bolt by themselves?
The whole is large enough for the bolt to fit on any year. That's not the point. You need to elongate in order to allow the bolt to travel far enough to pull the arm in.
Ideally, this is job for a lift. Once you do first hole, you'll realize you don't need the template. A tip would be to keep the aluminum lubricated while grinding. It is literaly a 15 minute job per side with a dremel, the extention piece and a grinding stone.
Theatrix is offline   Reply With Quote
Old 06-01-2007, 02:36 PM   #70
TuscaniJon
TuscaniJon's Avatar
I just recieved my bolts, there are four... I have the camber arms, which bolt do I put in? al four or just two? Also do I put in the bolts were the camber arm connects to?
TuscaniJon is offline   Reply With Quote
Old 07-16-2007, 02:54 PM   #71
pimpin714style
pimpin714style's Avatar
subscribing
pimpin714style is offline   Reply With Quote
Old 07-18-2007, 10:38 AM   #72
litlechina
wait so the camber bolt doesnt really do anything anymore right? Camber is adjusted by the arm itself. Also, the toe adjustment bolt is on the spring bucket and NOT the bolt holding the camber arm? Im almost 100% sure but just want to be REALLY be 100% sure.
finally, will you need a spring compressor when for when you remove the stock toe bolt/spring bucket?
litlechina is offline   Reply With Quote
Old 07-24-2007, 10:34 PM   #73
DMK
Do you guys know where to find a picture of the template to print out?
DMK is offline   Reply With Quote
Old 08-11-2007, 06:55 PM   #74
Row2K
Row2K's Avatar
I can't understand one thing. If you drill out the whole to a larger size, what will stop the bolt from sliding around in it or moving side to side over time ? Can someone explain ?
Thanks,
Mario
Row2K is offline   Reply With Quote
Old 08-12-2007, 12:31 AM   #75
redlude97
Quote:
Thanks,
Mario
the eccentric washers combined with the stock washer guides on the subframe prevent the bolts from sliding just like stock. The SPC toe bolts just move the bolt further out on the washer for added ajustability
redlude97 is offline   Reply With Quote
Old 08-12-2007, 09:21 AM   #76
Row2K
Row2K's Avatar
gotcha , thanks
Old 08-13-2007, 08:53 AM   #77
trescincuenta
I already have the kinetix camber arms installed. But I cannot get the camber to a low setting because the facotry toe bolt does not give sufficient adjustment to bring the toe back to spec when the camber is where I would want it.
If I purchase the adjustable traction/toe rods they also sell (which the also sell together as a kit) I should be able to bring the toe into spec when I have the camber where I want it correct?
trescincuenta is offline   Reply With Quote
Old 09-23-2007, 11:19 AM   #78
MIAPLAYA
MIAPLAYA's Avatar
The traction/toe bars may help get the toe into spec but will have an affect on wheels caster which you cannot then correct. The only PROPER way to adjust toe on this car is with new toe bolts like the SPC units this write up is about.
Old 10-10-2007, 02:10 PM   #79
bbs350z
bbs350z's Avatar
there are 4 bolts. dont you only need 2?? and both sides of each spring bucket have to be dremeled out correct?
bbs350z is offline   Reply With Quote
Old 10-10-2007, 02:14 PM   #80
redlude97
Quote:
Yes, you only need 2, why do you have 4?
Thread Thread Starter Forum Replies Last Post
JMS Racing Twin Turbo VQ35HR MM'08_350Z VQ35HR 225 03-08-2017 03:50 PM
Oil change with aftermarket oil cooler XM 1 Engine & Drivetrain 11 10-01-2015 10:44 PM
Tags
350z, arms, bolt, camber, coilover, g35, g35driver, instal, install, instructions, pictures, rear, spc, template, toe
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright 2002 - 2008, MY350Z.COM All Rights Reserved.
