DIY: Cutting Rear Springmount aka "the springmount mod" - Page 2 - MY350Z.COM Forums
Thread Tools Search this Thread
Old 08-29-2008, 06:18 AM   #21
JasonZ-YA
JasonZ-YA's Avatar
Quote:
Originally Posted by Rowlett
So im wonderin, With the Stock shock, will this be an issue?
Cuttin the rear mount 1/2 inch... or how much should i cut?
Im already on Hotchkis springs...
only cut down whatever amount lower you wish to be......
if you cut a 1/2 inch your gonna drop just about that much more...
some distance is soaked up in the suspension geometry so my advice is to cut a little, then remount and check it out..... and if you want to cut more then do it again.....
-j
JasonZ-YA is offline   Reply With Quote
Old 08-29-2008, 06:19 AM   #22
cheshirecat79
cheshirecat79's Avatar
Rowlett, I do not believe that the cut will hurt your rear shock by itself. However, with your spring change plus the extra half inch, you may end up stressing the shock and end up having to change it earlier.
Looking at your drop though, it looks even for the front and back. I would only suggest cutting the mount if your rear is sitting higher than the front, like with the stock suspension setup.
cheshirecat79 is offline   Reply With Quote
Old 09-11-2008, 08:19 PM   #23
kramykram
kramykram's Avatar
I have mine cut on my sport lines. I love the drop and I have yet to have a single problem in the rear. Now my front is messed up and i need to replace my struts with less than 2k miles on them due to my skunk 2's have a crappy spring rate and being our roads are so bad here in biloxi. Im happy with my rear drop. i might cut the rubber mount down some more or just but some rubber shrink wrap around the top of the spring and completly take the rear mount out to prevent noise.
this was the rear drop with my skunk 2's. i have the same drop with my sportlines
kramykram is offline   Reply With Quote
Old 10-20-2008, 12:30 PM   #24
ipodhustle
ipodhustle's Avatar
Quote:
Originally Posted by FirstZ View Post
I just order a set from nissanpartscheap.com, $45 BUCKS for the rear top pair!
http://www.trademotion.com/partlocat...=5&catalogid=1
this doesn't seem to be a direct link..
anyone have the part number?
ipodhustle is offline   Reply With Quote
Old 10-22-2008, 06:34 PM   #25
redmike_02
redmike_02's Avatar
I did mine a few weeks ago. I also cut out 1/2 in from the spring mount. It took about an hour to cut and install. I'm running Tein Flex with about 1/4 in more adjustment to go in the rear.
redmike_02 is offline   Reply With Quote
Old 11-22-2008, 06:50 PM   #26
speedracer05
I have an 04 stock and did 3/4". I left 1/4" of cusion at the top for spring mount and it leveled it out nice, Stock ride but better weight transfer and loading throught turns.
I used a port-a-band saw at work, took 45 sec. each.
speedracer05 is offline   Reply With Quote
Old 11-25-2008, 07:50 AM   #27
Cide
Cide's Avatar
anyone do with with GF210's?
Cide is offline   Reply With Quote
Old 11-26-2008, 09:20 AM   #28
Parker01
Neat/cheap mod
Just another option for cutting it, if anyone wants to machine it or use a cut off disk you could freeze the upper mounts. When we want to modify a purchased rubber part here at work we have the guys freeze them before machining. Of course you can't do this for anything high tolerance as the part will expand when it thaws, but for applications like the the upper spring mounts that process would work great.
Parker01 is offline   Reply With Quote
Old 12-01-2008, 08:53 AM   #29
Cide
Cide's Avatar
I did mines a couple of days ago.. pretty easy and cheap mod with great results.
b4 i could stick my finger in there and now i cant
Old 12-01-2008, 09:23 AM   #30
Jgrizzle
Jgrizzle's Avatar
How far down in the back can you go before you need to F with camber kits etc? I have the S Techs now but I dont want to start messing around with camber kits etc (which is why i bought the S techs)
Jgrizzle is offline   Reply With Quote
Old 12-01-2008, 09:27 AM   #31
Cide
Cide's Avatar
i have the GF210's and with stock arms the closest i could bring my camber to spec was about 3..lol and thats a 1.2" drop now that i did this to it im going to put it back on the rack and see what happened to my camber.
Old 12-03-2008, 06:10 AM   #32
McLovin350Z
McLovin350Z's Avatar
ok what i need to know is how to measure my front height to my rear so i know how much to cut.
i assume looking at just how the tire and fender match can give incorrect results since everybody has different tire sizes
Oh i have a stock suspension
Im saving for coilovers......i just really need something cool to do with the car.....cuz its cold and i have nothing to do....but work on the car
McLovin350Z is offline   Reply With Quote
Old 12-04-2008, 03:42 PM   #33
Parker01
So... measure for YOUR tires. Honestly how hard is it, put a ruler up to your rear wheel well at the highest point, put the zero at the edge of your fender and follow the ruler until you get to the desired drop height. Take this measurement and chop the same amount off your upper spring mounts and walla. The results will be close enough to what you measured.
Old 12-05-2008, 04:21 AM   #34
McLovin350Z
Thanks Parker01
Your right not hard at all
I just didnt know what was the preferred method of measurement
Old 02-27-2009, 07:59 PM   #35
ZeeForce
Mine are done, cut .5 off, came out perfect the first time.
I have noticed that my rear spring rates have changed being that they are progressive springs, not linear like the stockers. So I had to stiffen the compression with the fronts to balance out for the stiffer spring rate in the rear, if not the car felt like the rear was hopping.
Will get some pics posted up soon.
Koni yellows, with the new revised rear struts for easier adjustments.
H&R springs which have a drop of 1.3 front and 1.0 rear.
ZeeForce is offline   Reply With Quote
Old 02-27-2009, 10:37 PM   #36
ZeeForce
Both the IF & SS were cut. They were also kicked out with wheel spacers.
Old 02-27-2009, 10:40 PM   #37
ZeeForce
Old 03-12-2009, 01:39 AM   #38
Gizmo0803
Gizmo0803's Avatar
has anyone here done this mod while running the nismo s-tune suspension? i'm thinking about doing a 1/2" cut but i don't want it to ruin the nismo shocks prematurely...
Gizmo0803 is offline   Reply With Quote
Old 03-12-2009, 08:37 PM   #39
o2sys
S-tech owners how much are you cutting???
o2sys is offline   Reply With Quote
Old 03-12-2009, 08:56 PM   #40
deviljon
deviljon's Avatar
lol all that for a .5" drop? is that even noticeable? :
deviljon is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
FS: 2003 Touring Edition 350z-6MT-2Tone-40K Miles - $14k - NJ ars88 Zs & Gs For Sale 18 04-04-2016 07:52 AM
Volk TE37SL kch_86 South East Marketplace 1 11-29-2015 07:07 PM
Up to Date Coilover Review/Recommendations for a balance of track/drift/slam Lt_Ballzacki Brakes & Suspension 13 10-24-2015 08:56 AM
Tags
350z, cheap, coupe, diy, fender, g35, ings1, lx, mod, mods, mount, spring, springmount, suspension, tein
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright 2002 - 2008, MY350Z.COM All Rights Reserved.
