DIY for stock non-Brembo to stock Brembo brakes
Old 08-29-2007, 10:45 AM
simonfencer
simonfencer's Avatar
Originally Posted by SolarOrangeZ
possibily a n00bish question but.....if i am ever able to get my hands on some stock brembos, can I do this one brake at a time with the OEM jack stand?
also, for my 2007 350z, which years Brembos will fit?
Chances are one of your coworkers or a neighbor or a friend has a jack you could borrow for the day to do this.
Michla22: thanks for the great write up and pictures. IMHO, that if a person has access to the tools, a spot to work and this write up they could do the job regardless of any mechanical aptitude.
Old 08-30-2007, 10:00 PM
Michla22
Michla22's Avatar
Thanks
Old 09-14-2007, 11:03 AM
gothchick
gothchick's Avatar
+1
If you don't have the tools to do it right, then wait 'til you do... I sure wouldn't want a 3,000+ pound car hovering over me unless I was sure it wasn't gonna come down on top of me. Accidents happen - That's why they're called accidents.
Edit: I was changing my motor oil, tranny oil, and diff oil a couple weeks ago. When I adjusted one of the floor jacks, it moved slightly, but enough for the car to slip off the jack. Fortunately, I had the good sense to use jack stands under the frame on all four corners. The car fell less than 1/2 an inch before the jackstand caught that corner. No damage to the undercarriage, no crushing of my bones~ :-)
Old 10-15-2007, 12:43 PM
dothemath
dothemath's Avatar
Great Job Thanks for sharing.
Old 01-12-2008, 07:10 PM
citymunky
citymunky's Avatar
Good write up, I might need this later down the road.
Old 01-13-2008, 07:43 PM
Bumble_Zee
FREEDOM FIGHTER
Bumble_Zee's Avatar
sorry i'm a noob here any info to where to get the brembo calipers only for cheap? or is there a website you guys know that sells a set for cheap online? the ones i've seen is way to heavy for my pocket... thanks!
Old 01-13-2008, 11:24 PM
Michla22
Michla22's Avatar
Just keep checking for people selling them - eventually you will find a good deal. Just have patience and look everywhere u can.
Old 01-15-2008, 05:39 PM
Deezflip
Deezflip's Avatar
Michla22, do you happen to know how much more(in mm) the brembo calipers sticks out than the non-brembo calipers? A good measurement would be from the face of the hub on the rotors. Front and rear, brembo and non brembo.
You'd be actually be doing me a huge favor I'd been interested in these wheels made to clear non-brembos with about 5-8mm of spoke clearance. If i wanted to maintain that 5-8mm with brembo calipers, how much of a spacer would i need?
DSC01579s.jpg?t=1200451026
Old 01-15-2008, 11:49 PM
Michla22
Michla22's Avatar
I don't have the measurements from my old non-brembo setup however i will gladly take the measurements from my current setup - Give me a couple of days though - just now moving into a new house.
Old 01-16-2008, 09:11 AM
Deezflip
Deezflip's Avatar
ehh it's ok Michla22, i currently have the brembo setup as well. No need to take any measurements. Thanks though. Now for anyone else that has the non-brembos, help me out?
Old 01-16-2008, 09:30 AM
ecorona6
ecorona6's Avatar
Originally Posted by gohandbz88
Something about brake lines always confuse me which way is loosen and which is tighten. Looking at this picture, if I had the wrench on that bolt, which direction do I turn the wrench (left or right) to loosen it?
Lefty losie, righty tighty!
OP...Great write up. The one thing you didnt mention is to sand down any rust on the hub before installing new rotors. The object is to take off any rust caked on that will prevent the new rotor from sitting properly.
Old 02-06-2008, 01:01 PM
Smoove
Smoove's Avatar
What are the torque specs for the caliper? And what are the torque specs for the wheel lugs?
Old 02-08-2008, 12:32 AM
Michla22
Michla22's Avatar
All 2003 info:
Non Brembo (bolts that hold cylinder body to the torque member - caliper to the rack)
Front and rear are 17-22 ft-lbs
Brembo caliper bolts:
Front: 111.4-112.1 ft-lbs
Rear: 53-71 ft-lbs
Lug nuts 80 ft-lbs
Old 02-08-2008, 01:06 AM
mw9
mw9's Avatar
thanks for the write up. I was hoping someone would do this
Old 02-11-2008, 05:24 PM
fklentz
fklentz's Avatar
I just finnished this same mod. I took the brembo calipers to work and bead blasted all the old paint off, then painted them a purple color with some caliper paint and rebuilt the calipers as well, FYI there is a shortage of rear caliper rebuild kits AND they cost more than the fronts, go figure.
After all the work I did I assumed that I'd be able to figure out the right from the left sides, WRONG, they will fit on either side both front and back. I mistakenly opted to install them with the bleeders facing down thinking that it would be easier and cleaner for bleeding them, funny thing about air bubbles, they dont want to sink in the pistons. After bleeding the calipers over and over I realized my error in judgement, swapped them bled them and that did the trick. I don't track my car and to be honest I don't feel any difference from my old brakes but they have way more bling.
Old 03-01-2008, 05:50 AM
ncparamedic
Prodigal Son
ncparamedic's Avatar
Where did you get the rebuild kit??
Old 03-15-2008, 05:28 PM
z-u-later
z-u-later's Avatar
^+1
Old 09-18-2008, 07:06 AM
  #38
Bumble_Zee
FREEDOM FIGHTER
Bumble_Zee's Avatar
can anybody tell me the size and length of the bolts used for the rear calipers? any help would be greatly appreciated!
Old 09-18-2008, 07:41 AM
  #39
jgregory124
jgregory124's Avatar
great write up
Old 12-16-2008, 08:15 PM
  #40
burner
burner's Avatar
I will be coming back to this as soon as I can find a set of decently priced Brembos, thanks!
Quick Reply: DIY for stock non-Brembo to stock Brembo brakes
