DIY for stock non-Brembo to stock Brembo brakes - Page 4 - MY350Z.COM Forums
Thread Tools Search this Thread
Old 10-30-2009, 12:12 PM   #61
Michla22
Michla22's Avatar
Quote:
Originally Posted by o2sys View Post
Also is it necessary to bleed out the entire system first or do it after the brembos are installed???
I don't remember exactly how long but if I had to guess somewhere between 2-4 hrs. And bleed the brakes after the install.
Michla22 is offline   Reply With Quote
Old 10-30-2009, 12:25 PM   #62
o2sys
2-4 hours? wow more than i expected....was it taking your time???
o2sys is offline   Reply With Quote
Old 10-31-2009, 02:37 AM   #63
Michla22
Michla22's Avatar
Yeah I wasn't in a rush , took some soda breaks and picture breaks.
Old 10-31-2009, 03:19 PM   #64
o2sys
took 3 hours just to do the fronts...removing the rotors took majority of the time...will do the rears tomorrow...
Old 12-14-2009, 12:04 AM   #65
beast66
beast66's Avatar
where can I get those caliper bolts for the rear? Pm me if possible.
beast66 is offline   Reply With Quote
Old 12-14-2009, 01:17 AM   #66
Michla22
Michla22's Avatar
pm sent
Old 02-03-2010, 12:12 PM   #67
Worm#21
hello,
i have a question about fitting a brembo kit for my "non brembo 350z".
I have found brembo calipers http://www.allegro.pl/show_item.php?item=903237907
and i want to be sure that;s everything i need to do the conversion.
As far as i can understand from this topic to do the conversion in front i don't need nothing more than only calipers?
the guy is selling only the callipers, brake discs and pads. will it fit whithout any problems.
So far i want to have brembos only in front.
Do i need something more than is on that auction?
i will be greatfull for any answers.
Worm#21 is offline   Reply With Quote
Old 02-03-2010, 02:39 PM   #68
Michla22
Michla22's Avatar
Quote:
Originally Posted by Worm#21 View Post
hello,
Make sure you get rotors as well. One thing I'm not sure about is if the stock non brembo brake lines will attach to the brembo calipers. I know the brake lines are different from the inner fender well attachment to the caliper. Find out if those will work or if you need the brake lines. I just upgraded to braided lines when I did this so I had no issues.
Old 02-04-2010, 11:20 AM   #69
Worm#21
by rotors you mean brake discs? 'cause i am not not sure if i understood well and i can't find exact definition of "rotor".
Old 02-04-2010, 03:04 PM   #70
Michla22
Michla22's Avatar
Rotor =
Old 02-06-2010, 05:49 AM   #71
Worm#21
great thanks
Old 03-11-2010, 02:23 PM   #72
kenyeow
Hi everyone, i am a new member and i hope i'm in the right place.
About the non brembo conversion into brembo for 350z, i bought
both front and rear brembo caliper off gtr34 and the front fits just
fine, but there's no way to fit it at the rear, my mechanics tried gtr33's
brembo as well. Will the brembo from 350z fits a non brembo 350z at the rear?
kenyeow is offline   Reply With Quote
Old 03-11-2010, 02:28 PM   #73
HyperSprite
Mad Scientist
HyperSprite's Avatar
brembo as well.
Yes but the bolts are different.
HyperSprite is offline   Reply With Quote
Old 03-11-2010, 04:12 PM   #74
kenyeow
thanks for the reply, appreciate it.
just another question, is it the same for japanese import and us model
for non brembo at the rear? is so i will be hunting some rear brembo for
my 350z =)
Old 04-13-2010, 01:13 PM   #75
UCIgrad
UCIgrad's Avatar
This is probably a silly question, but thought I'd ask it anyway. Where can I get the rubber caps to cap off the brake line when I disconnect it? Are they special? Looks just like tire caps to me.
UCIgrad is offline   Reply With Quote
Old 04-13-2010, 03:16 PM   #76
Michla22
Michla22's Avatar
nope nothing special ,I actually used the rubber caps that cover the bleeders on the caliper.
Old 04-14-2010, 04:40 PM   #77
exarmyguy
exarmyguy's Avatar
Great write up Michla22, I just did this conversion today and all went pretty smooth. Breaking loose the stock caliper bolts were a major PITA! Especially the rear cuz I didn't have enough room to get any kind of leverage. Had to use brute force to get them off.
And the rubber bleeder caps worked very well in capping off the brake line. Nice tip!
exarmyguy is offline   Reply With Quote
Old 04-14-2010, 05:08 PM   #78
jg425
jg425's Avatar
Great write-up, I just used this to upgrade my brakes, just a note there are two bleeder valves on the calipers, I didn't realize this and almost pulled my hair out cause I couldn't figure out where the air was getting into the brake system.
jg425 is offline   Reply With Quote
Old 04-15-2010, 02:16 AM   #79
Michla22
Michla22's Avatar
Thanks guys. Yeah I didn't go into the bleeding bc there are plenty of other posts on that. What I may do is just add a link on the first post to a DIY bleeding. Personally I use a motive bleeder, makes life easy.
Old 05-01-2010, 05:46 AM   #80
thekinn
thekinn's Avatar
Default stoptech line routing - rubbing
I'm having issues with the new Stoptech SS line rubbing on the control arm.. especially with the wheel turned. Any suggestions? How is the banjo bolt in relation to the caliper? (these are OEM Brembos.. in need of touch up paint.. long story). This is the passenger side with steering turned almost all the way left.. steering unwound a bit by itself)
thekinn is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
FS: Enkei RPF1: 18x9.5, 18x10.5 et 15 w. Nitto NT05 - Like New (used 2 months) Dark Knight Wheels Tires 7 11-11-2015 08:40 PM
Autocross Brake Pads hajwoj Autocross/Road 27 11-01-2015 05:25 PM
Tags
04, 350ztech, 78245, bleeding, brakes, brembo, brembos, coupe, diy, g35, kits, nonbrembo, rebuild, rotors, s2k, sale
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright 2002 - 2008, MY350Z.COM All Rights Reserved.
