DIY: Jack ramps for lowered cars - Page 3 - MY350Z.COM Forums
Thread Tools Search this Thread
Old 03-07-2008, 12:31 PM   #41
VO...
Administrator
VO...'s Avatar
Quote:
Originally Posted by key_darren
thanks Vo!!
NP
VO... is offline   Reply With Quote
Old 04-13-2008, 08:28 AM   #42
ed350
ed350's Avatar
Smart Fella...
ed350 is offline   Reply With Quote
Old 04-13-2008, 10:39 PM   #43
jeffie7
jeffie7's Avatar
Not as cheap as boards but I do like them a lot.
jeffie7 is offline   Reply With Quote
Old 04-14-2008, 05:09 PM   #44
j.arnaldo
j.arnaldo's Avatar
...you guys mean that you've lowered your beasts beyond stock height??? Man, mine's stock, & I just CAN'T do oil changes with regular, light (i.e. plas-
tic) ramps! I've been checking out the jack stands at Pep Boys & Western Auto; some are too expensive, some too puny...What a predicament! I'm gonna have to imitate old ABISHOP, but I ain't got that kinda ability...Deci-
sions, decisions...
j.arnaldo is offline   Reply With Quote
Old 04-14-2008, 05:15 PM   #45
phreaktor
~[;::;]ᵒᴥᵒ)
phreaktor's Avatar
I just drive up a brick and then jack it up.
phreaktor is offline   Reply With Quote
Old 04-14-2008, 05:59 PM   #46
Sc882tt
good job
Sc882tt is offline   Reply With Quote
Old 07-31-2008, 02:26 PM   #47
superchargedg
Damn Noobs
superchargedg's Avatar
Quote:
Jeff they are great but what happens when you want to get an alignment.Most shops have a drive up rack that our cars cant get on when lowered so what do we do then.
superchargedg is offline   Reply With Quote
Old 07-31-2008, 07:37 PM   #48
keosh
keosh's Avatar
ghetto but hey it gets the job done nice job
keosh is offline   Reply With Quote
Old 07-31-2008, 07:53 PM   #49
iamdigital
I'm gonna do the same thing. I bought a set of low angle ramps and they're still to high for my car to get on. I think my front bumper drops down to about 2" off ground. I put a 2x4 in front of the ramp and it barely clears and pita to get up. nice job
iamdigital is offline   Reply With Quote
Old 07-31-2008, 10:51 PM   #50
350ZTheStandard
350ZTheStandard's Avatar
Here is a picture of mine, kinda under the rear wheels.
DIY: Jack ramps for lowered cars-after-fold-0436.jpg
350ZTheStandard is offline   Reply With Quote
Old 08-07-2008, 08:19 PM   #51
CKY881
This will only be able to lift either front or rear, not both eh?
Is there a way of making 4 ramps and being able to lift up all sides? I did a little brain storming but didnt come up with any yet. Anyone?
CKY881 is offline   Reply With Quote
Old 08-08-2008, 11:32 PM   #52
doug
Quote:
Originally Posted by desiZ
I paid 35 bucks for my rhino ramps from kragen that support up to 8000 pounds (more than enough for just the front of the car)
yours are cool, but for 35-18 = $17... too much of a waste of time
i bought a set of these also.. great for changing oil.. the car was a little too low.. but i shoved them under there.. bumper flexes enough for me to get the car up there
doug is offline   Reply With Quote
Old 08-08-2008, 11:34 PM   #53
doug
i don't know what you guys are talking about rhino ramps don't clear.. they work fine with my car.. and my rims are tucked under my wheel well.. i don't even have 1 finger gapped after being lowered.. maybe its because i have 19's?
Old 08-31-2008, 06:15 AM   #54
pangoman
pangoman's Avatar
Quote:
I have 19s with Tein S-tech springs and Rhino Ramps definitely will not work with my car. I built ramps myself just like the other guys. I used 2x12s and 1x12s.
pangoman is offline   Reply With Quote
Old 08-31-2008, 07:24 AM   #55
300zx1985
300zx1985's Avatar
My stock suspension Z bairly clears the rhino ramps. My bumper taps it. I need something like this.
300zx1985 is offline   Reply With Quote
Old 09-02-2008, 07:59 AM   #56
doug
used the ramps again last night.. i had to shove them under a little bit.. but the car went right up.. no problems..
hey i'll take pics if you guys don't believe me.. and my car is lowered with 0 finger gap
Old 09-02-2008, 12:16 PM   #57
350z006
350z006's Avatar
Ramps are great, even with my hotchkis springs...the hard part for me is keeping the ramps from sliding when I drive up them...
350z006 is offline   Reply With Quote
Old 12-27-2008, 06:18 AM   #58
Phreakdout
Phreakdout's Avatar
Suggestions:
- Try placing the ramps on a rubber mat
- Attaching a sheet of rubber to the bottom of the ramps
- Spray something like rubberized undercoating to the bottom of the ramp. (Test this out on something else just in case the coating turns out to harden and just make things worse.)
I use an exercise mat that I should be using for exercising.
Also, I'd suggest you attach a rope handle at the end to make it easy to carry them around or hang them up on the wall.
Phreakdout is offline   Reply With Quote
Old 12-27-2008, 06:40 AM   #59
Phreakdout
Phreakdout's Avatar
If you want to chunk out some big bucks, you can buy this:
http://raceramps.com/portablepitstopramp.html
You can even put in scales! (Which you can see didn't work out too well with this Suby's wheelbase. Not adjustable enough for the scale feature)
I think I'd have to be a serious racer for this $3K setup. My wife would call me nuts if I built this in the garage.
Old 12-27-2008, 08:12 AM   #60
usmanasif
usmanasif's Avatar
Quote:
Any alignment shop worth going to will have ways of getting the car on the rack (2x4s, "drive up" bays, etc.). Why would you want to go to a shop that isn't experienced in aligning lowered cars anyway?
usmanasif is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
My Z Lowered on NF210's James1990 Brakes & Suspension 10 12-16-2015 08:57 PM
Finally building my HR. davidm350 2003-2009 Nissan 350Z 37 10-31-2015 02:28 PM
Nismo Suspension lowers Non-Nismo Z CJs_Z33 Brakes & Suspension 21 09-18-2015 12:06 PM
FS: New Motordyne TDX2, New Popcharger, Bridjit curb ramps ndelgro Mid-Atlantic Marketplace 0 09-07-2015 04:11 PM
Tags
auto, car, cars, diy, drive, forum, homemade, jack, long, lowerd, lowered, measurements, raise, ramp, ramps, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright 2002 - 2008, MY350Z.COM All Rights Reserved.
