DIY: Jack ramps for lowered cars - Page 4 - MY350Z.COM Forums
Thread Tools Search this Thread
Old 12-27-2008, 08:13 AM   #61
SOLO-350Z
'12 TL SH-AWD
SOLO-350Z's Avatar
I have yet to find any ramp to clear my NISMO front end. So changing oil is a B*tch on this car.
SOLO-350Z is offline   Reply With Quote
Old 06-23-2009, 11:50 AM   #62
knils
knils's Avatar
What about just buying a low profile jack? My car is slammed and this fits just fine... good idea though
knils is offline   Reply With Quote
Old 06-23-2009, 07:18 PM   #63
Gibbs
Know it all
Gibbs's Avatar
Quote:
Originally Posted by CKY881 View Post
This will only be able to lift either front or rear, not both eh?
Is there a way of making 4 ramps and being able to lift up all sides? I did a little brain storming but didnt come up with any yet. Anyone?
Just build 4 of these contraptions, and put two in front of the front wheels, and put the other two under the sideskirts in front of the rear wheels.
Gibbs is offline   Reply With Quote
Old 06-24-2009, 07:59 AM   #64
knils
knils's Avatar
Quote:
If these cars are low enough to need ramps in the first place I don't think you will be fitting these ramps under the sideskirts... I don't think you would even bother because if you could fit ramps you could just fit a jack and save you the trouble
Old 06-26-2009, 06:17 PM   #65
ZS14RR
ZS14RR's Avatar
lol nice idea
ZS14RR is offline   Reply With Quote
Old 11-29-2009, 02:10 AM   #66
snobes
snobes's Avatar
Sweet i didnt think of doing it that way.
i found an old railway sleeper and cut it diagonaly with a chainsaw
EDIT: I so pulled that old post out of no where, LOL sorry.
noticed as i clicked send
snobes is offline   Reply With Quote
Old 11-29-2009, 07:26 AM   #67
Dan Garcia
Know it all
Dan Garcia's Avatar
I built a set of ramps out of 2 x 10s for the 1st oil change on the z and they work great,
now I use these on all the vehicles, they sure come in handy. The second oil change on
the z is almost due but might not get to it since winter is here and I will be using my truck and keeping the z in the garage.
Dan Garcia is offline   Reply With Quote
Old 10-07-2010, 03:17 AM   #68
KingBaby
Hardest Setting
KingBaby's Avatar
I cut my rhino ramps....
used them a few times only way was to back up on them...now being lower...I have cut them
KingBaby is offline   Reply With Quote
Old 10-07-2010, 03:24 AM   #69
PikeZ_350
PikeZ_350's Avatar
I have a low-profile jack...and it doesn't fit under my OEM sideskirts. I have to pull up onto a piece of wood just to fit the low-pro under my car! lolz
PikeZ_350 is offline   Reply With Quote
Old 03-14-2011, 11:33 AM   #70
Més
Més's Avatar
do you work for NASA? great idea!!!
Més is offline   Reply With Quote
Old 03-14-2011, 01:01 PM   #71
scrantonz33
Quote:
Originally Posted by Phreakdout View Post
Suggestions:
- Try placing the ramps on a rubber mat
- Attaching a sheet of rubber to the bottom of the ramps
- Spray something like rubberized undercoating to the bottom of the ramp. (Test this out on something else just in case the coating turns out to harden and just make things worse.)
I use an exercise mat that I should be using for exercising.
Also, I'd suggest you attach a rope handle at the end to make it easy to carry them around or hang them up on the wall.
great idea i used the non slip cupboard liner works great.
scrantonz33 is offline   Reply With Quote
Old 07-02-2011, 04:02 PM   #72
Dan Garcia
Know it all
Dan Garcia's Avatar
Default some home made ramps
a must have for those who change their own oil.
DIY: Jack ramps for lowered cars-2011_0630gallerybolts0006.jpg   DIY: Jack ramps for lowered cars-2011_0630gallerybolts0007.jpg   DIY: Jack ramps for lowered cars-2011_0630gallerybolts0009.jpg   DIY: Jack ramps for lowered cars-2011_0630gallerybolts0013.jpg   DIY: Jack ramps for lowered cars-2011_0630gallerybolts0024.jpg
Old 07-02-2011, 09:40 PM   #73
beezee
I did the same thing and sawed them into 2 each for easy storage. Work great. Saw them after building and mark them so each piece goes where it came from. That way you ensure flushness.
beezee is offline   Reply With Quote
Old 07-03-2011, 04:46 AM   #74
Dan Garcia
Know it all
Dan Garcia's Avatar
I was going to add one more 2 x 10 x 12 piece to gain at least 1.5" of heigth but they are heavy with the four piece set up, the fifth would have made them too heavy.
Old 07-03-2011, 10:42 AM   #75
beezee
Here is mine. I used OSB boards like the one stated in thread start. I did cut them in 1/2s right where the 2nd board from the top is ( right at the end of the blue line). So the lower half is exactly the same as the one described at thread start. Putting them together makes it possible for me to go under and have enough room to change my oil. Makes it easier to store with the two pieces. Will add a pic of them cut later. I only use the lower half if I need to get a floor jack under the car.
Old 08-07-2012, 05:26 PM   #76
pro_350z
pro_350z's Avatar
i just made this all last week and it works out perfectly
pro_350z is offline   Reply With Quote
Old 08-15-2012, 05:24 PM   #77
sry110
But....do you all have trucks that allow you to haul home sheets of OSB?
sry110 is offline   Reply With Quote
Old 08-24-2012, 04:11 PM   #78
AbombBRZ
AbombBRZ's Avatar
I pretty much do the exact same thing as beezee
AbombBRZ is offline   Reply With Quote
Old 08-24-2012, 08:17 PM   #79
-miltdoggie-
-miltdoggie-'s Avatar
I just jack up the rear and then jack up the side, but having two jacks helps.
-miltdoggie- is offline   Reply With Quote
Old 08-24-2012, 09:09 PM   #80
Duckeee
I drive on a two step wooden ramp I made from the scrap wood from home depot. Then I get my oem scissor jack to the side then when its high enough I get the floor jack.
Duckeee is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
My Z Lowered on NF210's James1990 Brakes & Suspension 10 12-16-2015 08:57 PM
Finally building my HR. davidm350 2003-2009 Nissan 350Z 37 10-31-2015 02:28 PM
Nismo Suspension lowers Non-Nismo Z CJs_Z33 Brakes & Suspension 21 09-18-2015 12:06 PM
FS: New Motordyne TDX2, New Popcharger, Bridjit curb ramps ndelgro Mid-Atlantic Marketplace 0 09-07-2015 04:11 PM
Tags
auto, car, cars, diy, drive, forum, homemade, jack, long, lowerd, lowered, measurements, raise, ramp, ramps, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
