DIY - Lower Control Arm Bushing Replacement - Translink - Page 5 - MY350Z.COM Forums
Thread Tools Search this Thread
Old 02-07-2010, 08:41 PM   #81
JasonZ-YA
JasonZ-YA's Avatar
Quote:
Originally Posted by twitch579 View Post
Just changed mine out. Bought totally new arms. I got a smoking deal on them so thats why I did it. The other bushing that mounts to the strut was beat down pretty hard also. I also changed all my shocks at the same time too. The car feels stable on the road again, no more scary wobbling at high speeds. Just as stable as a rock like when it was new!!
There are lot of people that wouldnt want to mess with pressing out the bushings and doing the whiteline route as you did...
share plz where you got the arms for others??
-J
JasonZ-YA is offline   Reply With Quote
Old 02-08-2010, 03:28 AM   #82
twitch579
Got them from a Semi-Local dealer. I actually had 2 sets! It was a back door special and I would rather not expose the dealer.
The first set I got was for a G35 Sedan. I thought that the control arms were the same but there actually not. Where the ball joint goes into Control arm is smaller on the G35 Sedan. The nut will not go on far enough and you wont be able to get the cotter pin in. I'm not sure about G35 Coupes.
Got some Z arms and just bolted them right up. While I had the car in the air I dropped out the struts also and threw in some new ones. Mine have 98,500 on them lol!
twitch579 is offline   Reply With Quote
Old 02-08-2010, 05:20 AM   #83
JasonZ-YA
JasonZ-YA's Avatar
^^ cool...........essentially the same thing will happen down the road again if you keep your z long enough........since you got the new arms and they are just oem bushings in it again.
at least now you have a spare set that you can prep with whiteline bushings with no down time next time it happens......
maybe you can sell them cheap to someone wanting to do the install too......???
-J
Old 02-08-2010, 10:08 AM   #84
twitch579
Old 02-08-2010, 10:23 PM   #85
Miggz
Thanks for the DIY^^, looking forward to doing this within the next few weeks.
Miggz is offline   Reply With Quote
Old 02-09-2010, 04:05 AM   #86
JasonZ-YA
JasonZ-YA's Avatar
Old 02-09-2010, 04:05 AM   #87
JasonZ-YA
JasonZ-YA's Avatar
it never ends huh.....
-J
Old 05-05-2010, 06:39 PM   #88
JasonZ-YA
JasonZ-YA's Avatar
Quote:
Originally Posted by archebald23 View Post
whew.. never knew its this complicated. i was planning on replacing my control arm kit via DIY but so many things can go wrong. i think ima pass on this one any just send it to a garage.
go wrong? ok...
well its up to you, you have to size the job and evaluate your capabilities...
You can save yourself a lot of money if you remove the translink yourself and simply take the translink and the new bushing to a shop and JUST have them remove the old and install the new bushing....
come back home and reinstall it?
I know many people dont OWN a press, nor are willing to buy one just to do "this" job...
-J
Old 05-06-2010, 03:31 AM   #89
Z1 Performance
Former Sponsor
Z1 Performance's Avatar
There really is nothing complicated about it at all - it simply comes down to having a little bit of mechanical know-how and the right tools for the job.
That being said, we have a tool that we have just made which will make it a total DIY for the home mechanic. It's not that cheap but it is less expensive, and a helluva lot more convenient than the labor will be at a shop to do this job. Plus you won't be at the mercy of a shop to do it for you on your day off or a weekend, when you should be out using the car. We'll be posting info on our blog in the next day or 2 and linking it in our Whiteline classified ad in the Vendor - Suspension section.
Z1 Performance is offline   Reply With Quote
Old 05-06-2010, 03:34 AM   #90
JasonZ-YA
JasonZ-YA's Avatar
A Z1 approved "Franksocket"
-J
Old 07-06-2010, 06:44 PM   #91
go kart
go kart's Avatar
well u were right, i need to replace the one on my drivers side. im gonna order the whiteline set. this might be a dumb question but do i need to get an alignment after?
go kart is offline   Reply With Quote
Old 07-07-2010, 04:05 AM   #92
JasonZ-YA
JasonZ-YA's Avatar
Quote:
I wouldn't say you "need" one.........as fixing this issue puts the translink arm back centered as it was supposed to be............given the last alignment done was done when it was centered??? so if your not sure, then i would say its a good idea....
-J
Old 07-20-2010, 06:49 PM   #93
go kart
go kart's Avatar
k so once everything was finished i noticed that my steering wheel was angled to the left a bit. im guessing it means i def need that alignment? the car had an alignment done about 2500 miles ago so it was probably done with the bad bushing... thanks again for your help man
Old 07-21-2010, 04:22 AM   #94
JasonZ-YA
JasonZ-YA's Avatar
yup, seems like it, as if alignment was done with a bad bushing it would throw everything off correcting that arm with the whitelines...
I would recommend going to a chain store like NTB or Firestone and getting there 5 year alignment, etc............the Z needs it often...
-J
Old 08-12-2010, 07:19 PM   #95
kurtdaniel
The first set I got was for a G35 Sedan. I thought that the control arm kit were the same but there actually not. Where the ball joint goes into Control arm is smaller on the G35 Sedan. The nut will not go on far enough and you wont be able to get the cotter pin in. I'm not sure about G35 Coupes.
thats right,,i have that experience too..i bought a set for g35 but it was smaller..
kurtdaniel is offline   Reply With Quote
Old 10-14-2010, 05:35 PM   #96
SlipZ
SlipZ's Avatar
guys, do you have the franknsocket for this DIY. Im planning on doing mine pretty soon.
thanks,
-C
SlipZ is offline   Reply With Quote
Old 10-14-2010, 05:48 PM   #97
JasonZ-YA
JasonZ-YA's Avatar
^ I have one that i ship out.......you just gotta please be decently quick about shipping it back as others pm me for it here and there??
-J
Old 01-20-2011, 10:17 AM   #98
tyau
Does the ball joint slide out from the transverse link (aka lower control arm) easily on our cars???
In the past, removing the arm was a pita because the ball joint had to be hammered or pryed out which damages the ball joint and the boot.
My bushings are fine, but I don't want to risk damaging my ball joints yet just to swap out bushings.
tyau is offline   Reply With Quote
Old 01-20-2011, 10:20 AM   #99
AcidJake75
Living in 350Z
AcidJake75's Avatar
^^nothing a deadblow hammer cant tap out - but honestly they do come out quite easily..
AcidJake75 is offline   Reply With Quote
Old 01-20-2011, 10:22 AM   #100
JasonZ-YA
JasonZ-YA's Avatar
^ yep, easy, Ive never had one stuck...if anything a light tap with a rubber hammer and off it comes......with as many as i have done, i would be surprised if one was stuck..
-J
Thread Thread Starter Forum Replies Last Post
FS: 2003 Touring Edition 350z-6MT-2Tone-40K Miles - $14k - NJ ars88 Zs & Gs For Sale 18 04-04-2016 07:52 AM
Up to Date Coilover Review/Recommendations for a balance of track/drift/slam Lt_Ballzacki Brakes & Suspension 13 10-24-2015 08:56 AM
Oil change with aftermarket oil cooler XM 1 Engine & Drivetrain 11 10-01-2015 10:44 PM
Replacing Tail light issue. 350z82 Exterior & Interior 19 10-01-2015 06:25 PM
Tags
1996, 2003, 350z, arm, avenger, bar, bushing, bushings, control, diy, g35, g35driver, lca, lower, nissan, rear, removal, replaements, tracking, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright 2002 - 2008, MY350Z.COM All Rights Reserved.
